auto transmission rebuild+freeway gears+canada
yycwesty
yycwesty is offline
PostPosted: Mon Feb 17, 2014 8:06 pm    Post subject: auto transmission rebuild+freeway gears+canada Reply with quote
Any advice on a reputable group who would rebuild my transmission and upgrade the gears to freeway flyer gears.
In Calgary but willing to travel..Any thoughts on roughly what I should expect to pay
Cheers
Al
IdahoDoug
IdahoDoug is offline
PostPosted: Mon Feb 17, 2014 8:16 pm    Post subject: Reply with quote
Seems like the flyer ring gear is 1500, and there are only a few left. I've heard its a good mod and will consider it one day.
rubbachicken
rubbachicken is offline
PostPosted: Mon Feb 17, 2014 8:37 pm    Post subject: Reply with quote
can't recommend anyone to do the rebuild, these are the gears for better freeway cruising Cool
contact AA transaxle, if they can't i'm sure they could set you on to a place that could
lucy our westy
lucy's BIG adventure
meet 'burni'
ThankYouJerry
ThankYouJerry is offline
PostPosted: Mon Feb 17, 2014 9:07 pm    Post subject: Reply with quote
AA does not do autos.
Seems like GTA (German Transaxle of America - Bend, OR) is one of the only (and maybe best?) options.
Here is GTA's current pricing:
Rebuilt Auto Trans $1595.00
Turbo Upgrade 800.00 (optional… includes: 4 gear planetary; larger direct reverse drum; extra clutch in forward clutch and an RV stall converter).
Core Deposit 750.00
FAS cooler kit 299.95 (optional)
Shipping (B to B) 335.38
1990 Multivan - "Ohana"
1.8T, Auto w/3.27 R&P + Peloquin TBD
Wildthings
Wildthings is offline
PostPosted: Tue Feb 18, 2014 12:12 am    Post subject: Re: auto transmission rebuild+freeway gears+canada Reply with quote
Cheers
Al
Unless you are adding a lot more engine torque, you may end up going slower and using more fuel instead of going faster and going further on a tank full. A stock engine is barely adequate with stock gearing. Crying or Very sad
Maybe first try running a set of 205r14 or 27-8.5r14 tires to see how you will like the longer gear set.
yycwesty
yycwesty is offline
PostPosted: Tue Feb 18, 2014 7:48 am    Post subject: Reply with quote
Hi Wildthings..Sorry forgot to mention I have the 2.5 subie with 16" wheels on the van.
Thank you Jerry - Awesome price break down..Appreciate that
insyncro
Banned
insyncro is offline
PostPosted: Tue Feb 18, 2014 7:50 am    Post subject: Reply with quote
GTA for autos.
?Waldo?
?Waldo? is offline
PostPosted: Tue Feb 18, 2014 8:47 am    Post subject: Reply with quote
You'd want to add the $1500 for the taller R+P on top of that.
advantageaction
advantageaction is offline
PostPosted: Tue Feb 18, 2014 10:41 am    Post subject: Reply with quote
You might give Walt Sanson a call at Lees Tranmissions in Vancouver... http://www.leestransmissions.ca They rebuilt my automatic and did a great job on it. Though VW is by no means their specialty, they have experience and as i said, did a great job at a good price on mine. I have a 2.5 Subie as well. YVR is a lot closer than YYZ and just an all-round better place to visit!
madspaniard
madspaniard is offline
PostPosted: Tue Feb 18, 2014 11:43 am    Post subject: Reply with quote
Rebuilt Auto Trans
Turbo Upgrade (optional… includes: 4 gear planetary; larger direct reverse drum; extra clutch in forward clutch and an RV stall converter).
FAS cooler kit
My tranny has all of that plus a modified rabbit valve body that changed the shift points, really cool, it shifts up at higher rpms squeezing more out of the engine. I also have a lower stall (400 rpm lower) torque converter.
JeffRobenolt
JeffRobenolt is offline
PostPosted: Tue Feb 18, 2014 11:56 am    Post subject: Reply with quote
I wish they had that ring and pinion when I built your trans!, might of never got rid of the auto!!
People talk about modifying the governor to change the shift points. That is for wide open throttle shifting.
The Rabbit valve body changes partial throttle shift points, which is good because with the Subaru in it you don't have to have it to the floor at all times anymore.
Jeff
For OEM Subaru and SixStar parts and harness modications
AVsubaruconversions.com
madspaniard
PostPosted: Tue Feb 18, 2014 12:02 pm    Post subject: Reply with quote
Jeff
I have a 3.7 R&P sitting in a box waiting for the engine conversion. I replaced your shaved governor with a used stock one. The tranny I bought from you is really really nice and smooth.
Alaric.H
Alaric.H is offline
PostPosted: Wed Feb 19, 2014 4:20 am    Post subject: Reply with quote
I will be having my auto rebuilt soon for a 91 tin top would a 2.1 with DJ pistons and 1.4 roller rockers work with the higher R&P?. Stock size tires will be used. It will have head work and a RMW exhaust most likely a cam as well.
yycwesty
yycwesty is offline
PostPosted: Wed Feb 19, 2014 2:32 pm    Post subject: Reply with quote
Hi Madspaniard..
Did you have your work done at GTA?
Cheers
Al
madspaniard
PostPosted: Wed Feb 19, 2014 5:14 pm    Post subject: Reply with quote
probably not a good idea
Smiro wrote:
dagriztx wrote:
Would this work for ej22, or is this only 2.5 and bigger?
Thanks
I had a 3.73 with my 2.2L and it dropped my RPMs by 500. This custom 3.27 maybe too tall for a 2.2L. It would be fine for flat areas but once you drive up grades it will slow you down. You will have to drop it into second to keep the RPMs up. Do you have a camper or Tin top? It would be marginal for a tin top but it would tough with a camper. Hope this helps.
Regards,
from last page of this thread
http://www.thesamba.com/vw/forum/viewtopic.php?t=431013&start=180
madspaniard
PostPosted: Wed Feb 19, 2014 5:15 pm    Post subject: Reply with quote
yycwesty wrote:
Hi Madspaniard..
Cheers
Al
the short answer is yes, GTA can do all the work mentioned above.
yycwesty
yycwesty is offline
PostPosted: Wed Feb 19, 2014 6:43 pm    Post subject: Reply with quote
Perfect..Thank Madspaniard. have emailed them
Cheers
Al
