Tcash Samba Member
Posted: Sun Nov 17, 2013 7:53 pm Post subject: Youtube Videos |
To link to this thread
Code: |
[url=http://www.thesamba.com/vw/forum/viewtopic.php?t=576989&start=0&postdays=0&postorder=asc&highlight=]Youtube Videos[/url] |
To search this page Ctrl+F search box will appear top right corner.
I am thinking of buying a VW van - YouTube
sling blade
BODY/FRAME/PAINT
73 to 79 Type 2 VW Bay Window Bus Trailer Hitch Part 1
73 to 79 Type 2 VW Bay Window Bus Trailer Hitch Part 2
73 to 79 Type 2 VW Bay Window Bus Trailer Hitch Part 3
73 to 79 Type 2 VW Bay Window Bus Trailer Hitch Part 4
73 to 79 Type 2 VW Bay Window Bus Trailer Hitch Part 5
1974 VW Bus Custom Paint Job
sand blasting
Electrolysis Rust Removal
71 VW Bus Steel Sliding Sunroof - how it works
VW Single Cab dent repair with football
BUS TOURS
Van Life In A Renovated VW Kombi Westfalia
AXLE FRONT/STEERING
Earlybay diagonal arm bushing (radius arm)
Lowering VW Bay Window Bus - Drop Spindle Install
Ball Joint Removal 1979 VW Bus - YouTube
Prepare for installing the ball joints
Install Part 2
Ball Joint Removal - YouTube
Replacing ball joints
Ball Joint Removal on VW Baywindow Bus
▶ VW beetle adjustable ball joint beam - YouTube
How to fit the LiteSteer Power Assisted Steering for VW Camper vans and Classic Cars.
Worn out tie rod on VW bus
VW Camper - how to - change steering drag link
AXLE REAR
Removing Stub Axle Nut
Volkswagen Rear Torsion Adjustment-part 1
Volkswagen Rear Torsion Adjustment-part 2
Schnorr washer replacement/ Nord-Lock
1970 VW Type2 CV Joint Play
VW Axle Re-Build-part 1 - YouTube
VW Axle Re-Build-part 2 - YouTube▶ VW van rear CV joint overhaul and gearbox oil change - YouTube
Rebuild CV joints part 2 - YouTube
Rebuilding CV joints - part 1 - YouTube
BRAKES/TIRES/WHEELS
Volkswagen Hubcap Decals
How to Change Drum Brakes (In-depth, ultimate guide) - YouTube
Bottom of the page are videos/T2 Bay Braking System Parts :: Just Kampers
Front Brakes 1970Westy - YouTube
Front Brakes Westy Part II - YouTube
Brake Booster (servo) repair on VW 1971 Bus - YouTube
▶ How to replace the front Disc Brake Pads on your VW T2 Campervan - YouTube
How to properly Prepare For Brake Maintenance on your VW T2 Campervan - YouTube
How to remove and replace the front brake caliper and brake disc on your VW T2 Campervan - YouTube
Front Brake/Caliper Rebuild on VW Bus - Part 1
Front Brake/Caliper Rebuild on VW Bus - Part 2
Rear Brake Job 71-79 Prt 1 ▶ VW T2 Bay Window Campervan Rear Brake Removal Guide Part 1 - By Justkampers - YouTube
Rear Brake 71-79 Prt 1▶ How to replace the rear brakes on your VW Campervan (1 of 2) - YouTube
Rear Brake 71-79 Prt 2▶ How to replace the rear brakes on your VW Campervan (2 of 2) - YouTube
Rear brake rebuild on VW Bus
www.VW-DIY.com: VW Brakes - YouTube
Making a bubble flare with a double flare tool - Replacing brake lines - YouTube
How to Change a HEAVY Tire and Prevent it Falling Off
CAMPER
Westfalia Baywindow Camper Box with Pail - Bucket
vw camper van beetle type4 2.0L rebuild 01
Westy sink plumbed for BEER
The Car's The Star - VW Camper
DIY SIMPLE BASIC SUPPORT PLATFORM REAR HATCH
DIY 71 Westy Camper Bus Pop Top Canvas Install
VW Bus (Westfalia) Restoration
CLUTCH
1972 VW Bus Type 2 clutch arm
▶ Replacing clutch disc VW bus 1971 Rosie, pulling motor Volkswagen Camper - YouTube
ELECTRICAL
VW GENERATOR INSTALL
Pulley out-of-round
Ignition/starter switch explained
Pertronix Ignitor 3 Distributor Installation for VW's with Kaddie Shack
▶ Change 009 Distributor with Points to Electronic Distributor - YouTube
Bosch distributor: vacuum can test on distributor
Distributor Mechanical advance with rotor installed.
Distributor Vacuum advance distributor test
1600dp bus engine distributor drive play
Kaddie Shack TECH TV: SVDA Distributor Installation
How to remove VW bus ignition cylinder
Bus Part Two How To install A Ignition Tumbler
Pacific Parts Intl. steering coupling conductive grounding horn issue
Aircooled VW electric choke operation
▶ Electrical work on my VW Bus '71: Fix your wires! Volkswagen wiring. - YouTube
T2 VW bus with BMW electric window motor on cable drive
T2vw bus with BMW electric window motor on cable drive part 2
EASYSTEER VW T2 BAY ELECTRIC POWER STEERING CONVERSION DUB EPS CAMPER APPLE FRIENDLY
Electric VW Bus Conversion
ENGINE
Checking End Play at Crank Pulley
VW end play 2
Adjust VW Fan Belt.mov
VW Head Tricks #1 - YouTube
VW Head tricks #2 - YouTube
VW head tricks #3 - YouTube
VW Head tricks #4 - YouTube
VW Head Tricks #5 - YouTube
L'empi Tork Démultiplier en action.
VW 1600 motor rebuild - Part 1 - YouTube
VW 1600 motor rebuild - Part 2 - YouTube
VW 1600 motor rebuild - Part 3 - YouTube
VW 1600 motor rebuild - part 4 - YouTube
Vacuum Leaks(S boot)
proE Animation of a VW1600 engine
Type 4 VW Thermostat Flaps
Type 4 Engine Assembly-part 1
Type 4 Engine Assembly - Part 2
Type 4 Engine Assembly-part 3
Type 4 Engine Assembly-part 4
Vw engine slow-mo
Valvetrain Geometry
Busaru Engine Conversion
VW Van-engine removal - YouTube
1971cc Jake Raby VW Camper Special Type 4 Engine OVWC Engine Clinic
Remove Engine VW Bus
Type 1 Volkswagen engine - seeing if camshaft will walk out.
Type 4 engine top end rebuild
VW 1700 Type 4 engine knocking
▶ proE Animation of a VW1600 engine - YouTube
▶ stop motion engine rebuild - YouTube
▶ Installing a Breather Box on an Air Cooled VW or Dune Buggy Engine - YouTube
Changing Your Old Leaking Pushrod Tubes, Type 1 engine.
1977 Baja Kombi on the dyno II - The Suby EG33 Engine
20 hour buggy engine rebuild part 2 - YouTube
20 hour buggy engine rebuild part 3 - YouTube
engine stumble - YouTube
Hippie Van Man 1979 Volkswagen Bus Engine Rebuild - YouTube
How to Install an Oil Cooler on an AirCooled VW or Dune Buggy Engine - YouTube
▶ Classic VW Beetle Bugs How to Check Engine Compression Motor - YouTube
▶ 20 hour VW buggy engine rebuild: Part one of three - YouTube
Type I (1) Engine Tin Installation Videos
Type IV (4) Engine Tin Installation
Finding TDC Type I Engine
FUEL INJECTION
1978 VW Bus 2.0L Injector Connector Firing Test
fuel pump noise=Bad fuel pump
fuel pressure gauge bouncing=Bad fuel pump
FUEL SYSTEM
#ecobus EP07 Tank sender repair FAIL
#ecobus EP08 Tank sender repair WIN
Bus air cleaner check
Kadron Solex H40/44EIS Tuning and Installation Clinic
Vintage VW Training Film - Carb Adjustment Part 1 - YouTube
Vintage VW Training Film - Carb Adjustment Part 2 - YouTube
Air Cooled VW Stock Carburetors 30 and 34 Picts - YouTube
▶ Locating the Jets in an IDF Carburetor - YouTube
Tuning twin Solex 32 PDSIT carburettors on a VW aircooled
Dellorto / Weber carb secrets #1 - YouTube
Dellorto / Weber carb secrets #2 - YouTube
Dellorto / Weber Carb Secrets #7 - YouTube
Weber Carb Pierce Manifolds VID-01
Weber carb Pierce Manifolds VID-02
WEBER CARB PIERCE MANIFOLDS VID-03
VW Bus Fuel Gauge Sender Repair
Air Cooled Volkswagen Fuel Pressure Adjustment
VW fuel gauge malfunction - YouTube
The Difference types of Stock Fuel Pump for an Air-Cooled VW - YouTube
Replacing the fuel filler neck in a VW Bus
▶ Classic VW Bugs How to fix Beetle Fuel Pump Vapor Lock - YouTube
▶ fixin bus fuel pump on 1971 VW camper - YouTube
Firewall Removal on a VW T2 Late Bay Camper
VW T2 Late Bay Camper Fuel Tank Removal
▶ VW Van Fuel Tank Repair - YouTube
Bench Test VW Fuel Gauge / Vibrator / Sending Unit - volkswagen gas gauge not working - YouTube
Fuel Pump Installation, VW fuel pump trick - YouTube
Fuel pump pusshrod worn down, fixin bus fuel pump on 1971 VW camper - YouTube
GLASS/SEALS
Windshield install (1976 Transporter) Sixer's
VW Bus Installing new window rubber in the cab doors
how to change ¼ light window on VW camper - woolies workshop
Jalousie seal tutorial pt 1
Jalousie seal tutorial pt2
Jalousie seal tutorial pt3
Jalousie seal tutorial pt4
Jalousie seal tutorial pt5
Jalousie seal tutorial pt6
Jalousie seal tutorial pt7
Jalousie seal tutorial pt8
Jalousie seal tutorial pt9
Jalousie seal tutorial pt10
Jalousie seal tutorial pt11
Jalousie seal tutorial pt12
Jalousie seal tutorial pt13
Jalousie seal tutorial pt14
Jalousie seal tutorial pt15
Jalousie seal tutorial pt16
Jalousie seal tutorial pt17
Jalousie seal tutorial pt18
Jalousie seal tutorial pt19
HEATING & VENTILATION
▶ VW Bus Heater Body Replacement - The Bitterroot Rambler - YouTube
BA6 gas heater part 2 - YouTube
BA6 gas_heater.wmv - YouTube
Eberspacher BA6 Gas Heater VW Bus - YouTube
Eberspacher BN4 Gasoline Heater for the Volkswagen Bus
Spark Plug Thread Repair
HEATER TUBES ON A 1976 VW BUS
INTERIOR/SEATS
▶ Classic VW BuGs How to Restore Repair Reupholster Beetle Seat Frames 68+ Part 1 - YouTube
▶ Classic VW BuGs How to Restore Repair Reupholster Beetle Seat Frames 68+ Part 2 - YouTube
MAINTENANCE
Vintage VW Training Film - Valve Adjustments Part 1 - YouTube
Vintage VW Training Film - Valve Adjustments Part 2 - YouTube
▶ Classic VW Beetle BuGs How to Adjust your Valves PT.1 tip Vallone - YouTube
▶ Classic VW Beetle BuGs How to Adjust your Valves PT2 Resto Tip - YouTube
VW Valve Adjust.mov - YouTube
▶ How to replace or adjust the points and condenser on your VW - YouTube
How to remove and replace the distributor cap and rotor arm on your VW - YouTube
How to clean a spark Plug
How to remove and replace the spark plugs in your VW - YouTube
Vintage VW Training Film - Ignition Timing II - YouTube
Vintage VW Training Film - Ignition Timing Part 1 - YouTube
Vintage VW Training Film - Ignition Timing Part 2 - YouTube
VW Ignition Timing - YouTube
▶ Classic VW Beetle Bug Ghia Bus How to Time Set Volkswagen Engine Timing - YouTube
VW Oil Change.mov - YouTube
VW Tune Up made easy - YouTube
SOUNDS
Sound made when Dimmer relay plugged where the Flasher goes
John Muir VW Sounds
TRANSMISSION
Front Shift Rod Bushing Before Replacement
Front Shift Rod Bushing After Replacement
VW Transaxle Input Shaft Removal
Volkswagen Type 2 transmission output shaft play
How to pull a transmission in 3 minutes
002 VW Transaxle Rebuild Part 1 - Tools
002 VW Transaxle Rebuild Part 2 - major disassembly
002 VW Transaxle Rebuilt Part 3 - Shaft Disassembly
002 VW Transaxle Rebuild Part 4 - gear closeup
002 Transaxle Rebuild Part 5 - is not out yet
002 VW Transaxle Rebuild Part 6 - Gear Spin Video
MISC
Why Use ARP Ultra-Torque Fastener Assembly Lubricant
ARP Ultra-Torque Tested on Horsepower TV (HD)
Volkswagen Kombi Last Wishes
▶ Type 2 Detectives Boot Camp Part 1 - YouTube
▶ Type 2 Detectives Boot Camp Part 2 - YouTube
bajabus
Video download courtesy of SGKent.
http://kentcomputer.com/77VW/egr.avi
The Dream Continues - AMAZING VOLKSWAGEN BUSES! - VW Bus & Car Show - Minneapolis
The Dream Begins - Getting Wisdom For My VW Bus - Volkswagen Bus Wisdom.
31 years in a field, vw bus, will it run?
Restoring a 1978 VW Bus
Sunken valve seat
1969 VW Bus Ignition Switch Replacement
How To tighten and replace the fanbelt on your VW
69 VW Bus won't drive!(stripped drum)
'68 Vw bus on dyno
How do VW and Audi Part Numbers Work (From a VW and Audi Parts Expert)
▶ Classic VW BuGs How to Install New Valve Guides in Beetle Ghia Bus Motor Heads - YouTube
How to replace a tire valve without taking off the tire using tool kit.
VW Bus ignition switch eplacement
How to Use a Vacuum Gauge for Diagnostics
Demonstration on voltage drop across a ballast & coil resistor
Excessive End Play
VW Endplay issue I
Setting Crankshaft End Play
Main thrust bearing rotation in case
The Early-Bay Syncro, Sverre t2a allrad im aufbau teil 1
The Early-Bay Syncro ,Technik von Sverre t2a allrad im aufbau teil 2
Shift coupler issue
Vw Westy at JPM on the dyno
VW T2 rusty Window repair
VW BUS T2 Restoration BY ILAN SHERMAN part 1.
Finding top dead center
71 VW Westfalia with DPD A/C unit installed
▶ 1977 Westfalia Campmobile Bus-refresh - YouTube
▶ Air Cooled VW Thrust Repair - YouTube
▶ bajabus - YouTube
▶ bug tech bus shifter - YouTube
▶ Camper Bearings...again - YouTube
VW Generator Replacement PART-1
VW Generator Replacement PART-2
Install Generator PART-3
Final Part-4 Installing a Generator
▶ Classic VW Beetle Bug How To Remove Generator Tip Restore - YouTube
▶ Classic VW Bugs How to Repair Beetle 5 Lug Smooth Rim Clips - YouTube
▶ Classic VW Bugs How to Seal Beetle Motor Oil Leaks - YouTube
▶ Crankcase oil seal change.wmv - YouTube
▶ Dellorto/WeberIDF trouble shooting tips - YouTube
1978 VW Bus Alternator- Don't fry your harness from a dead short!
VW T2: Alternator removal
VW Alternator Kit Fan Install - YouTube
▶ How to remove a driveshaft hub nut without air tools - YouTube
▶ How to remove VW hub - YouTube
▶ How to replace the front wheel bearing on your VW T2 Campervan - YouTube
▶ how to take off and reinstall a sliding door on a VW bus in about a minute. - YouTube
▶ Insallation Tips for Pushrod Tubes for an AirCooled VW or Dune Buggy - YouTube
▶ Installing a Pertronix Ignitor in a 009 Distributor Dune Buggies and VWs - YouTube
▶ VW 1600 motor rebuild - Part 1 - YouTube
▶ VW 1600 motor rebuild - Part 2 - YouTube
▶ VW 1600 motor rebuild - Part 3 - YouTube
▶ VW 1600 motor rebuild - part 4 - YouTube
▶ VW Camper - how to - change steering drag link - YouTube
Steering rebuild on VW Bus
▶ VW Head tricks #4 - YouTube
▶ What a Drag -replace drag link on VW bus '71 - YouTube
100 3651 - YouTube
100_3654.MOV - YouTube
1776 assembly #1 - YouTube
1776 assembly #4 - YouTube
1776 assembly #5 - YouTube
1776 assembly series #2 - YouTube
1776 assembly series #3 - YouTube
1978 Westfalia Hard Start, Won't Idle, Vacuum leaks and double relay fixed.MOV - YouTube
1978 Westfalia Idling,rough idle .MOV - YouTube
Adjust VW Fan Belt.mov - YouTube
AFM Signal Sweep Pins 6-7
AFM Signal Testing Vanagon, tencentlife's media
Ba6 test - YouTube
Beetle Stuff - YouTube
Bn6 first run in years - YouTube
Check out our installation videos for 73 super beetle parts, 72 super beetle parts, parts for VW
Classic VW Beetle Bug How To Find Fix Oil Leaks and Drips - YouTube
CV boot removal from bearing housing VW 73 - YouTube
Dellorto / Weber secrets #3 - YouTube
Dellorto / Weber secrets #4 - YouTube
Done By Jim Vw Clutch Part 1 - YouTube
Done By Jim Vw Clutch Part 2 - YouTube
How to adjust your firing order on your Volkswagen - YouTube
How to dismantle the rear hub on your VW (2 of 4) - YouTube
How to drain the oil when changing the oil in your VW - YouTube
How to install Compufire Ignition for VW in a 009 Distributor, by Airhead Parts - YouTube
How to remove and refit the rear hub seal on your VW (3 of 4) - YouTube
How to remove and replace the condenser on your VW - YouTube
How to remove the front wheel bearing on your VW T2 Campervan - YouTube
How to remove the rear Hub Nut on Your VW (1 of 4) - YouTube
How To Replace the HT Leads on Your VW - YouTube
How to replace the oil cooler in your VW - YouTube
How to replace the rear hub seal on your VW - Final assembly (4 of 4) - YouTube
How to safely Jack Up the rear of your VW T2 Campervan - YouTube
How To tighten and replace the fanbelt on your VW - YouTube
Idle Vacuum Readings, idle6 - YouTube
Install Generator PART-3 - YouTube
Lateral Run-Out Correction Plates - YouTube
Midnight Oil Garage - YouTube
Removable Bus Steering Wheel - YouTube
removing VW beam - YouTube
Save money and time by preparing your VW for it's MOT - YouTube
Stripped VW Oil Drain Plate Stud Repair.mov - YouTube
The Cars The Star on the VW BUS Quentin Wilson - YouTube
The Dub Box - YouTube
Trailer Hitch 68-79/Kris Machado - YouTube
VW Bay Window Camper Buyer's Guide - YouTube
VW Beetle CV Joints - YouTube
vw camper van beetle type4 2.0L rebuild 01 - YouTube
Westfalia Trailer - Anhänger for the VW Bay Window Bus
vw bus shift bushing replacement
VAG 1367 tester - YouTube
notchboy1
Subarugears 5 speed plus EJ25 in VW Kombi bus
Classic VW Bugs How to Restore Vintage Steering Wheels
1973 VW Bus Restoration front panel replacement
Westfalia panel repair, By Last Chance Auto Restore
KONI Adjustment from outside TwinTube
Forgotten Volkswagen Camper Van LIVES AGAIN !!!!!!! VW Bus
This is going into a Split. But the kit fits a bay too.
VW Camper Bed Conversion - DIY German Aircooled Garage #3
VW Bus Scale Model
Vw bus Kombi 4x4 (Brasil)
1970 VW Bus Antenna Replacement - Bitterroot Rambler Bus Trav
73 to 79 Type 2 VW
[url=https://www.youtube.com/watch?v=vChLfl_Xw9Q]How to: VW Type 2 Campmobile Jalousie Louvered window rebuild.
VW Bus Scale Model
73 to 79 Type 2 VW
[url=http://www.youtube.com/watch?v=saCDmyiBmb0]SPARK PLUGS How to Read them (Part 3)
Whitewall insert installation/tech video....
VW Bus Sliding Door Repair Part-1
VW Bus Sliding Door Repair Part-2
Turn Signal Housing, Repairing Stripped Screw Holes
1976 VW Bus drag link steering slop.
1976 VW bus drag link replaced
Checking for vacuum leaks using home made smoke pump.
sloppy steering box
1977 Bay Window VW Bus Steering Damper
Helicoil | Thread repair
The Basics of using a Torsion Adjusting Tool
Busaru
Clutch Freeplay VW Bus
Squacking Bus Rear end-1977 Westfalia rear squeek mystery?(Wheel Bearing)
Lost 3X10 - Hurley Jumpstarts DHARMA Van W/Guns N' Roses
notchboy Samba Member
Joined: April 27, 2002 Posts: 22416 Location: Escondido CA
airschooled Air-Schooled
Joined: April 04, 2012 Posts: 12688 Location: on a bike ride somewhere
Posted: Wed Feb 26, 2014 1:45 pm Post subject: |
Thank you for making these links- having the embedded videos was slowing down my computer! _________________ Learn how your vintage VW works. And why it doesn't!
www.airschooled.com |
TheRealMacGyver Samba Member
Joined: July 13, 2011 Posts: 198 Location: Spring Hill, FL
aeromech Samba Member
Joined: January 24, 2006 Posts: 16925 Location: San Diego, California
Posted: Thu Feb 27, 2014 10:00 am Post subject: |
Once again, great job with the thread Mr. Cash _________________ Lead Mechanic: San Diego Air and Space Museum
Airbus A319,320,321
DC9/MD80
BAe146
Fokker F28/F100
VW type 1 1962,63,65,69,72
VW Jetta
VW Passat
blackivory69 Samba Member
Joined: April 08, 2013 Posts: 309 Location: California
Posted: Fri Mar 28, 2014 12:48 pm Post subject: |
Isn't this a god candidate for STICKY???? _________________ 1970 Double Cab. Stock engine (1600 SP)
1973 Thing (Mexican Safari)
1970 Karmann Ghia Convertible
1969 Buggy |
Tcash Samba Member
Posted: Fri Mar 28, 2014 2:16 pm Post subject: |
blackivory69 wrote: |
Isn't this a god candidate for STICKY???? |
It is in (Tech Tips/ Links)
Thank you
Tcash |
Campin68 Samba Member
Joined: March 22, 2014 Posts: 79 Location: Issaquah, WA
Posted: Fri Mar 28, 2014 8:17 pm Post subject: |
I thought this one was notable, if only because the guy was working on his fuel tank with a burning cigarette in his left hand
http://www.youtube.com/watch?v=ICUjAr0JCV0 |
bigluelok Samba Member
Joined: January 28, 2009 Posts: 55 Location: Altadena, CA 91001
Posted: Fri Mar 28, 2014 10:36 pm Post subject: |
Posting here to keep track of this for later viewing. |
Wasted youth Samba Member
Joined: July 06, 2012 Posts: 5134 Location: California's Hot and Smoggy Central Valley
Posted: Sat Mar 29, 2014 3:34 am Post subject: |
Wow! I kept skipping this thread because I figured it was just a rant about YouBoob or somethin'. Cool! Thanks for that compilation...bookmarked! |
Desertbusman Samba Member
Posted: Sun Mar 30, 2014 4:31 pm Post subject: |
Wow, that's a real long list of vids.
Just be sure and view any of them with extreme CAUTION. I just randomly picked one and watched it. Only watched the one and it had bad info that could be harmful and prevent the engine from running.
Just because it's a video on the internet doesn't mean that it wasn't done by some wanna-be so-called back yard mechanic learning which end of the screwdriver to hold on too. Don't make it an issue of the blind leading the blind _________________ 71 Superbug
71 Westy |
AirAssault2 Samba Member
Joined: April 06, 2015 Posts: 64 Location: Washington D.C.
lucianosanchez Samba Member
Joined: May 04, 2016 Posts: 212 Location: Ventura County
Posted: Tue May 10, 2016 10:15 am Post subject: Re: Youtube Videos |
Thank you for those links! Should come in handy soon _________________ 1983.5 Aussan Brown Westfalia | 2016 to 2020
1983.5 Beige Westfalia | 2019 to Current |
APPLEGREENVW Samba Member
Joined: November 30, 2003 Posts: 2379 Location: Seekonk,Massachusetts USA
HastaAlaska Samba Member
Joined: November 22, 2012 Posts: 1420 Location: Off Grid
Cap10323 Samba Member
Posted: Sat Nov 10, 2018 10:29 pm Post subject: Re: Youtube Videos |
I made this video documenting replacing the front beam, from the point of view of a first timer.
It's not exactly a step-by-step tutorial, but it's pretty inclusive.
_________________ -Ian
'77 Westfalia - 2.0 F.I |
