Westy tent install: specialty tools and tips
seabright_sc
seabright_sc is offline
PostPosted: Wed Feb 26, 2014 5:06 pm    Post subject: Westy tent install: specialty tools and tips Reply with quote
I know there are a ton of install threads out there, but I thought it would be cool to focus this thread on:
Specific tools (purchased or fabricated) for the job
Installation tips
Not meant to debate warrants of top on vs. off. Just tool/tips that made the installation process go smoothly for you!
djkeev Premium Member
djkeev is offline
PostPosted: Wed Feb 26, 2014 5:26 pm    Post subject: Reply with quote
This or similar........
Many of them actually, 6 pack....... Maybe a case!
Plus
Tape measure
Sharpie
Scissors
Screwdriver
Stubby screwdriver
Power screw driver
Power stubby screw driver
Awl
Cleaner for aluminum strips
Magnetic tray for screws
Helper (find out his/her favorite brew and add it to your inventory)
Patience
Patience
Patience
More patience.
Dave
Ghia
Vanagon
Beetle
PDXWesty
PDXWesty is offline
PostPosted: Wed Feb 26, 2014 6:00 pm    Post subject: Reply with quote
Videos with top/on-top/off instructions:
http://youtu.be/ASC9dZkfxbQ
http://youtu.be/bmSOnYrtV2E
http://youtu.be/30i7dZJIJ20
89 Westy 2.1 Auto
luVWagn
luVWagn is offline
PostPosted: Wed Feb 26, 2014 6:15 pm    Post subject: Reply with quote
Right angle ratcheting screw driver with swappable bits. Great for tight spaces near the rear of the van.
'91 Syncro 16 Reimo Hightop Conversion, eTDI
Vanagon Nut
Vanagon Nut is offline
PostPosted: Wed Feb 26, 2014 7:45 pm    Post subject: Reply with quote
I found the tool below to be very useful for screws. I don't have the brand name handy but you'd likely find this at Harbour Freight. Starts with a "P". Pronto? Anyhow....
Bit direction is determined by which side of head bit is in. You can ratchet normally, or, twist the handle CW/CCW. The latter worked great. IIRC, it was possible to push down on the ratchet head while twisting the handle.
Neil.
1981 Westy air cooled to 15 ABA swap: http://tinyurl.com/y9n4xob8
50 ABA Swap in to '88 Westy: http://tinyurl.com/yap5hpwt
Vanagon VAG GAS engine swap Google Group:
https://tinyurl.com/2f24rmh
VE7TBN
Ahwahnee
Ahwahnee is offline
PostPosted: Wed Feb 26, 2014 9:18 pm    Post subject: Reply with quote
I used this (from Harbor Freight):
To keep the tent from unfolding all over the place while I worked with it, I wrapped it at intervals with strips of paper... then tore them off one by one as I got to that part of the tent:
kamzcab86
kamzcab86 is offline
PostPosted: Wed Feb 26, 2014 9:50 pm    Post subject: Reply with quote
Flexible socket wrench extension:
Painter's tape, Sharpie, and cups: Label all of the hold-down rails as you remove them. Group the screws into cups, label the cups as to where the screws go (lower rails, upper rails, etc.).
Straps: Wrap around the pop-top push-up bars before unbolting them from the roof.
Pop-top shocks, pipe, or some other mechanism to keep roof partially raised while you work (if you're not removing the pop-top).
~Kamz Anxious
2016 Golf GTI S
"I fear the day that technology will surpass our human interaction; the world will have a generation of idiots." ~Albert Einstein
msinabottle
msinabottle is offline
PostPosted: Thu Feb 27, 2014 12:09 am    Post subject: Reply with quote
Far and away the single most useful tool we used. Also the hook remover on my Swiss Army knife, it was dull and yet sharp enough to push the canvas into place without penetrating it.
Best!
'Winston,' '84 1.9 WBX Westy
many ways, but never, never, never in silence."
FNGRUVN
FNGRUVN is offline
PostPosted: Thu Feb 27, 2014 8:06 am    Post subject: Reply with quote
Pneumatic crown stapler for those who have an older van with the staples instead of screws. You can get a cheap one at Harbor Freight. Try to find stainless steel staples.
Also a blow drier or heat gun to warm up the original plastic strip so that you can stretch it as you go. It also allows the staples to penetrate easier.
Be really careful if you use a heat gun and an acrylic tent. You can melt a hole in the material in a nano second. Ask me how I know. Embarassed
"Democracy is two wolves and a lamb voting on what to have for lunch. Liberty is a well-armed lamb contesting the vote." - Benjamin Franklin
seabright_sc
PostPosted: Sat Mar 01, 2014 6:43 am    Post subject: Reply with quote
I've decided to take off top for the job. Looks like I only have one helper to assist. Can top removal be done with two men?
Any other tips out there?
