airkooledchris Samba Member
Posted: Fri Mar 14, 2014 10:46 am Post subject: using UV dye to track oil leak sources |
So I pulled the drivetrain from my bus last weekend, so I could start dealing with a multitude of oil leaks and general cleanup needed on tinware/battery tray and a host of other engine compartment area needs.
Before I pulled the motor I dye'd the oil with UV dye, then ran it for a few weeks with the dye in it.
I haven't yet drained the oil from the motor, so it's sitting on a stand now and im watching to see where it leaks from. I had a pretty good idea when it was still in the bus, but it's nice to see it without all of the tinware on it and with easier access to everything.
At first glance im sure someone would have assumed that my oil leaks were from the main seal and maybe the oil pressure switch, but neither of those two turned out to be true.
For the one that looks like a main seal issue, it's actually coming entirely from this side of this case bolt:
For the one that looked like maybe the oil switch or oil cooler, it's mostly from the oil filter mount:
And lastly, it looks like the oil cooler itself is weeping as well:
I have to say im a big fan of this method for tracking oil leak sources down. It really takes the guessing work out of it, and might help avoid replacing parts that are still good. (if that main seal isn't leaking, im leaving it alone as it's only a year and a half old or so)
The pushrod tube seals are mostly dry with a few little dribbles here and there, so I may do those since I have such easy access right now. |
tootype2crazy Samba Member
Joined: October 08, 2007 Posts: 1276 Location: St. Louis Missouri
Posted: Fri Mar 14, 2014 4:45 pm Post subject: |
Really cool. I have a lot of experience with type 4 engines both from my own cars and working on others. I have a good eye for seeing where a leak comes from, but this would make it a cakewalk. I might have to add this to my arsenal. _________________ air-cooled or nothing for me
1978 Sunroof Deluxe Bus (daily driver)
1978 Transporter (mom's, making into a camper)
1970 Single Cab 2.1 turbo/EFI 6 Rib, 78 front beam, vanagon backing plates on rear (project)
2001 GTI VR6 (wife's) |
eche_bus Samba Member
Posted: Fri Mar 14, 2014 5:40 pm Post subject: |
I used this dye to find an otherwise impossible to locate oil leak at the back corner of the intake on my Mustang's 428CJ. Due to the location, a close inspection without the dye couldn't find the point of origin. Once the dye was used, within minutes it was made obvious. I wish I could say the repair was as easy - the intake manifold weighs half what a whole 2.0L VW engine weighs, and the pushrods run through the intake so there was plenty of challenge.
Good system. Highly recommended. |
madmike Samba Member
Joined: July 11, 2005 Posts: 5292 Location: Atlanta,Michigan
Posted: Sat Mar 15, 2014 5:07 am Post subject: |
Old skool method,, don't clean it and drive down a dusty road
the leak will clean off the dust _________________ 'Black Ice'Drag Buggy 'Turbo'
Rail Buggy 1915 turbo
poptop tom Samba Member
Joined: July 27, 2004 Posts: 1607 Location: The Hoosier State
Posted: Sat Mar 15, 2014 7:04 am Post subject: |
Hey Chris, how long is usually required to run the engine when using the dye?
And what will be your fix for the leaking case bolt? _________________ '76 Deluxe Campmobile |
Posted: Sat Mar 15, 2014 11:04 am Post subject: |
poptop tom wrote: |
And what will be your fix for the leaking case bolt? |
This was my first attempt with the stuff, so I can't say exactly. It probably just depends on how much of a leak you have. I bet a short highway drive would be good enough for most setups.
As for fixing the leak at that case bolt - I honestly don't know. I saw a thread here a while back with someone having the same problem, but don't recall the fix. I imagine some combination of proper torque on the bolt and maybe some Permatex Form-A-Gasket on the threads? |
udidwht Samba Member
Joined: March 06, 2005 Posts: 3779 Location: Seattle, WA./ HB, Ca./ Shizuoka, Japan
Posted: Sat Mar 15, 2014 8:50 pm Post subject: |
The oil is weeping down the threads of the bolt. Remove the bolt and clean everything well. Then use 'thread sealant' on the threads/bolt and nut. Re-torque _________________ 1972 Westy Hardtop/Type-4 2056cc
96mm Biral AA P/C's~7.8:1CR
71mm Stroke
73 Web Cam w/Web solids
Bosch W8CC plugs
S&S 4-1 w/Walker QP 17862
3 rib 002 Trans
185R14 Hankook tires |
morymob Samba Member
Posted: Sun Mar 16, 2014 3:49 am Post subject: |
U probably could have just set at a fast idle 4 a few mnutes and located the leak, by driving it as u did u just spread oil/dye all over the place making it harder ti pin point leak area. The green stuff will give u a quick visible spot without the uv lamp. We just yesterday tracked ac leak on a tour bus that had been in several 'repair shops??' to locate the freon leak, that is one big monstrosity, hard to get to but in a couple hrs had it located, will make repair monday, used the green stuff. |
aogrady Samba Member
Posted: Sun Mar 16, 2014 6:43 pm Post subject: |
Hi,
Interesting - is this a specific UV dye for oil, or can you use any UV dye? What mix do you use for this?
Regards,
Alistair
1970 Westy. UK |
Posted: Mon Mar 17, 2014 4:00 am Post subject: |
Local flaps has the UV stuff, the pen lite uv lites are pretty mickey mouse, fair if used after dark. Don't have fans blowing on area u look at , seems to work better or maybe just was a larger amt at the time. |
dugfresh Samba Member
Joined: November 04, 2012 Posts: 651 Location: Seattle
Posted: Mon Mar 17, 2014 9:23 am Post subject: |
I had an oil leak that I used corn starch to pinpoint. I just threw it at the likely spots and it sticks to everything... but the leaking oil seeps in and then sorta gels up where the leak is. But it only works where you can get the starch. _________________ 78 Riviera
http://flic.kr/s/aHsjDRJPa1 |
Posted: Mon Mar 17, 2014 3:21 pm Post subject: |
aogrady wrote: |
Hi,
Regards,
Alistair
1970 Westy. UK |
The stuff I used was called Tracerline All-In-One Oil Dye, which is specific for this purpose. Ive heard others state that you can get it at some auto-parts stores as well, but I had to order mine online. |
Posted: Thu Mar 20, 2014 4:37 pm Post subject: |
Thanks for the replys, i'll take a look at that one
Cheers,
Alistair |
Posted: Fri Mar 21, 2014 7:39 am Post subject: |
I was able to pick up the dye, and the glasses/flashlight at my local Auto Zone yesterday.
So most FLAPS should stock them. I had to ask though. They weren't out on the shelves or on display, but stored in the back storage room. _________________ '76 Deluxe Campmobile |
mikedjames Samba Member
Joined: July 02, 2012 Posts: 2736 Location: Hamble, Hampshire, UK
Posted: Fri Mar 21, 2014 1:40 pm Post subject: |
Looks a good idea.
I should have done this - I once found an oil leak by removing all the tinware and then cleaning the suspected area with carburettor cleaner and then starting the engine and running for about a minute.
To get the engine started I had to refit it to the bus as I do not have a spare bellhousing for the starter. And then pull it and fix the leak before putting it back in. |
Tom Powell Samba Member
Joined: December 01, 2005 Posts: 4855 Location: Kaneohe
Posted: Fri Mar 21, 2014 2:23 pm Post subject: |
poptop tom wrote: |
So most FLAPS should stock them. ... |
Autozone has a kit for $80 with more than oil dye. It has cooling and refrigeration dyes and it may not be in stock at your local.
Amazon sells the oil dye, glasses and a UV flashlight for much less, but you may have to buy from more than one vendor and wait a few days for delivery.
Aloha
tp |
