Jetta lift kit?
Forum Index -> Water-cooled VW Share: Facebook Twitter
Phshead
Phshead is offline
PostPosted: Sun Dec 04, 2011 8:53 am    Post subject: Jetta lift kit? Reply with quote
Does anybody know if there is a lift kit available for a 2011 Jetta? I'm not looking for crazy, off-road lift. Just an inch or two for some clearance for winter driving. I have a 2011 Jetta Sportwagen.
bowditch
bowditch is offline
PostPosted: Sat Dec 21, 2013 10:29 am    Post subject: Reply with quote
yeah, i'm wondering the same for my winter beater jetta 89. is there a lift kit available for that as well?
82 Westy AAZ
82 Vanagon 1.6D
EvileNV
EvileNV is offline
PostPosted: Tue Jan 07, 2014 11:21 pm    Post subject: Reply with quote
You could easily make some upper strut lift plates, or have some fabricated...personally I would make my own, looks like your 2011 jetta has struts at every corner Smile
Here's a random link that shows front upper strut lift plates so you can get an idea of what I mean http://janeandjohn.org/pages/carry/liftkit.html
VWaddict01
VWaddict01 is offline
PostPosted: Thu Mar 13, 2014 9:10 pm    Post subject: Reply with quote
for your 89 I would try to source a used mk2 golf country suspenion as those were lifted from the factory and should bolt right up to your mk2 jetta
1990 lifted 2wd (for now..) Vanagon "Savanna"
1979 bagged Rabbit L
1977 B1 Passat Estate
2014 Jetta
(Searching for the next air-cooled project)
bubblehead
bubblehead is offline
PostPosted: Sat Mar 22, 2014 2:35 pm    Post subject: Reply with quote
I believe you can fit stock Tiguan springs for your 2011.
Lind wrote:
I think that buses attract weirdos that do weird things in weird places.
zuhaelter_82
zuhaelter_82 is offline
PostPosted: Tue Mar 25, 2014 4:54 pm    Post subject: Reply with quote
Yes, because finding a set of used Golf Country anything, is really easy... Rolling Eyes
64 Type II
MKI Jetta Coupe Diesel
MKI Jetta Sedan w/TD swap
B5 V6 GLS
B7 TDI Passat SE
cfvwtuner
cfvwtuner is offline
PostPosted: Sat Apr 26, 2014 3:42 pm    Post subject: Reply with quote
I would try a set of add on sleeve coilovers, like Ground Control ones.
Then you can get longer springs and set the spring rates too
tjet
tjet is offline
PostPosted: Sun Aug 11, 2019 3:42 pm    Post subject: Re: Jetta lift kit? Reply with quote
I installed a 2" kit from Metalnerd. I also installed all-terrain truck tires.
I did this because I hit a huge hole on my drive home from work. It damaged both front wheels, tore out the OEM underbody splash pan & left fender liner. It also damaged the left front strut upper bearing. I got the idea to lift it while I was installing a pair of quick struts. I also installed a dieselgeek skid plate.
Support the "Right To Repair" bill
https://repair.org/policy
Worth a listen...
https://www.wbur.org/onpoint/2018/11/01/right-to-repair-digital-locks-technology-smartphones-cars
PostPosted: Sun Aug 11, 2019 5:16 pm    Post subject: Re: Jetta lift kit? Reply with quote
Damn, that is mean looking!
Glenn Premium Member
Mr. 010
Glenn is offline
PostPosted: Sun Aug 11, 2019 5:54 pm    Post subject: Re: Jetta lift kit? Reply with quote
I rather a Subaru Crosstrek.
Glenn
Cast Iron and Aluminum distributors rebuilt since 2000.
tjet
tjet is offline
PostPosted: Sun Aug 11, 2019 6:43 pm    Post subject: Re: Jetta lift kit? Reply with quote
Thanks.
Tires are General Grabber AT2's.
Front: 205/75r15 on 15x6 OEM steel rims.
Rear: 225/70r15 on custom 15x8 widened OEM rims (5" backspace).
Yeah, I would get a Subaru, but this diesel gives me 45 mpg. I drive it 150 miles round trip daily to NYC, which is where the bad roads are.
I am going to build an EJ257 for my Syncro, does that count?
Worth a listen...
Mr. 010
Glenn is offline
PostPosted: Sun Aug 11, 2019 6:50 pm    Post subject: Re: Jetta lift kit? Reply with quote
Last time in my Impreza I got 42mpg over a 200 mile drive. I used to commute from Long Island to Leonia, NJ.
Glenn
ach60 Premium Member
ach60 is offline
PostPosted: Mon Aug 12, 2019 9:35 pm    Post subject: Re: Jetta lift kit? Reply with quote
NOPE, NADA, just can't bring myself to do it.
I don't want no foreign car, I want a VOLKSWAGEN !
Good Luck
Al
View user's profile Send private message Yahoo Messenger MSN Messenger Gallery Classifieds Feedback
Mr. 010
Glenn is offline
PostPosted: Tue Aug 13, 2019 4:02 am    Post subject: Re: Jetta lift kit? Reply with quote
It's made in Indiana.
Glenn
hellenic vanagon
hellenic vanagon is offline
PostPosted: Wed Aug 14, 2019 4:45 am    Post subject: Re: Jetta lift kit? Reply with quote
Very nice!
My Passat Syncro g60 has a 2'' lift kit already but with 205 55 15 tires.
Your combo looks much better.
Is there any scrubbing?
The Syncro Heresy
tjet
tjet is offline
PostPosted: Thu Aug 15, 2019 7:06 am    Post subject: Re: Jetta lift kit? Reply with quote
Will let you know. No rubbing noticed yet. I'm still looking for the optimum tire pressure. Right now, I'm running 30 psi in the front and 33 in the rear.
The 2"lift blocks & the 2" taller than stock tires gave the car an oversteer / bump-steer feeling. I had it aligned yesterday and it feels better now.
Worth a listen...
hellenic vanagon
PostPosted: Thu Aug 15, 2019 7:39 am    Post subject: Re: Jetta lift kit? Reply with quote
Thank you very much for your answer.
The Syncro Heresy
Reply to topic    Forum Index -> Water-cooled VW All times are Mountain Standard Time/Pacific Daylight Savings Time
