steveo61 Samba Member
Joined: April 13, 2011 Posts: 85 Location: Turlock, Ca
Posted: Sat Mar 22, 2014 10:17 pm Post subject: |
Almost there! First year 40 horse! 1961 |
GasOilnSteel Samba Member
Posted: Thu Apr 03, 2014 3:03 pm Post subject: A true 1600 DP |
I picked this up today to get a head start on going broke LOL.
Brian Anthony Samba Member
Joined: October 02, 2006 Posts: 215 Location: Longview TX
Posted: Sat Sep 13, 2014 4:01 pm Post subject: |
1967cc engine for '67 Beetle.
Single port engine.
_________________ 1965 Double Cab
1967 Bug, Sedan
1967 Bug, Convertible
I’m not old, but I once knew a man who was alive during the Civil War, and he once knew Revolutionary War veterans. |
vamram Samba Member
Posted: Wed Sep 17, 2014 5:15 pm Post subject: |
My humble 1600DP from my '72 Super. Correct oil bath air filter, DVDA, so stock except for the degree pulley, the Mexican Bocar 34 PICT-3 carb rather the the German solex, and the alternator rather than generator.
Since I took this picture, I replaced the DVDA w/a different one and connected the intake manifold vacuum to the air filter. _________________ Eventually, "we are what we pretend to be.’”
Give peace a chance - Stop Russian-Soviet Aggression!!
'75 Super Le Grande...waiting it's turn in line behind '74.
Click to view image
Save the Supers!! |
Vanapplebomb Samba Member
Joined: November 03, 2010 Posts: 5411 Location: Holland, MI
Posted: Wed Oct 29, 2014 4:12 am Post subject: |
jamesdagg wrote: |
vugbug68 wrote: |
73 Type 4
Didn't '73 T4's have duel Solex carbs?
jim |
No, only the '68 1700 T4's had carbs. Dual solex 34 pdsit carbs. All later models had fuel injection, at least for the American market. Europe may have been different. I know some of the T4 engines in European 914's came with solex 40 pdsit carbs when all American 914's had FI.
T4 engines used in busses retained carburetion in a slightly modified form through the '74 model year. They still had solex 34 pdsit carbs, but a central idle circuit was used to feed the idle mixture to both manifolds. '75 was the first year for FI on those engines. Speaking of a '75 bus...
_________________ 1800 Type 4 Berrien 295
http://www.thesamba.com/vw/forum/viewtopic.php?t=487021 |
mcdonaldneal Samba Member
Joined: June 13, 2013 Posts: 2649 Location: Gullane, Scotland
APPLEGREENVW Samba Member
Joined: November 30, 2003 Posts: 2388 Location: Seekonk,Massachusetts USA
Bug-nut Samba Member
Joined: December 20, 2015 Posts: 488 Location: Knoxville, TN
Posted: Thu Mar 24, 2016 2:01 pm Post subject: Re: Engine Guide |
My April of '59 Beetle with a December of '59 engine. Wrong coil (Brazilian), home-made vacuum line for dizzy (still searching for the proper one) and I'm not for sure if my generator should be a thin slot or not - mine isn't. I'm sure there's still a few things I'm missing but I've always wanted a 36 hp and now I have one! _________________ 1959 Fjord Blue Volkswagen Beetle
http://www.thesamba.com/vw/forum/viewtopic.php?t=6...highlight=
1962 Austin-Healey Sprite
Snort wrote: |
A 59 Beetle is just an Oval-Window car with aspirations of modernity. |
EverettB Administrator
Joined: April 11, 2000 Posts: 69820 Location: Phoenix Metro
Posted: Fri Mar 25, 2016 10:19 am Post subject: Re: Engine Guide |
EverettB wrote: |
59s are not thin slot generators. |
Thanks Everett. The reason I didn't know was because my generator has "remanufactured" stamped onto the top of it. And also because the PO just slapped whatever would fit onto it on it. I'm glad to hear I've got the correct one _________________ 1959 Fjord Blue Volkswagen Beetle
Snort wrote: |
donny1973 Samba Member
Joined: November 21, 2008 Posts: 317 Location: Palm Beach, FL
Posted: Mon Apr 25, 2016 11:04 am Post subject: Re: Engine Guide |
My '68 vert before and after.
_________________ Who is John Galt?
The Second Amendment is in place in case the politicians ignore the others.
'64 Bug
'73 Thing
'68 Vert Body Off Resto: Click here |
nlorntson Crazy VW Lady
Joined: March 13, 2004 Posts: 3783 Location: Twin Cities, MN
Posted: Thu Nov 10, 2016 3:25 pm Post subject: Re: Engine Guide |
1962 40hp beetle
1949 sedan
btracy Samba Member
Posted: Thu Feb 23, 2017 6:16 pm Post subject: |
mnussbau wrote: |
1974 convertible w/ EGR, and original SVDA, 34PICT3, fuel pump, and throttle dashpot. The coil has a large VW logo stamped on its top end.
i have the same motor, can you seed a more close up picture.thanks. |
LALA4Fire Samba Member
Posted: Fri Mar 31, 2023 8:41 pm Post subject: Re: Engine Guide |
correct 1960 36hp engine with red dip stick!!
