Diagnostic Computer- thoughts?
Beeble1
Beeble1 is offline
PostPosted: Sun Mar 23, 2014 7:32 pm    Post subject: Diagnostic Computer- thoughts? Reply with quote
I've been searching around the site and have found many, many, MANY topics about computer diagnosis, computer diagnostics, etc. here are a few:
http://www.thesamba.com/vw/forum/viewtopic.php?t=256918
http://www.thesamba.com/vw/forum/viewtopic.php?t=430421
http://www.thesamba.com/vw/forum/viewtopic.php?t=426941
I know that in some of these topics they have talked about making some sort of modern machine or emulator for PC. (Or mac for all you apple people.)
However, none or these topics actually show that someone has made an emulator for the diagnosis tests. Soooo... Has somebody done it? I've been toying with the idea of doing it myself, but I'm not quite sure how to go about it. I did take the diagnostic report and make it into an excel spreadsheet, so that is a good starting point... I think.
Thoughts? Ideas? Anything?
Beeble1, ‘73 Super (o\_|_/o) 1600cc w/ Dealer A/C
Beeble2, ‘13 Beetle 2.5l daily driver
Bishop-Wayne Volkswagen Kankakee, IL items wanted!
Turner Volkswagen Kankakee, IL items wanted!
View user's profile Send private message Send e-mail Twitter Gallery Classifieds Feedback
theKbStockpiler
theKbStockpiler is offline
PostPosted: Sun Mar 23, 2014 8:04 pm    Post subject: Reply with quote
I have a few questions. Confused
Is this factory vw diagnostic tool supposed to be a dealer version of a 'Sun Machine?
Why would you want to emulate an engine for a obsolete machine? An engine exists and therefore does not need to be emulated.
The only sensor I have ever seen on a carbureted vw is a plug at the flywheel .What would you learn from one sensor?
It looks/seems like a multiplexer with it's highest value meant for marketing appeal of your service shop to me.
My beetle is not competing with your beetle. I have the yellow beetle in my town. There is a red one, a green one ......
Use all safety devices including a mask.Smile
dayot538
dayot538 is offline
PostPosted: Sun Mar 23, 2014 8:14 pm    Post subject: Reply with quote
No possible good can come from involving something as mean-spirited and mischievous as a computer in such an innocent and constructive hobby.
GearheadTourist wrote:
Best approach is to get the rear end up in the air and give everything a shake.
gp98
gp98 is offline
PostPosted: Sun Mar 23, 2014 8:23 pm    Post subject: Reply with quote
dignostic plug in engine compartment on my 72 super is what I believe op
was referring to. More than one test lights, charging system, etc.Mine is still connected, old fashioned yes but so is this 42 yr old car.
Kinda cool early tech. Needed now no, but hey.......
1972 Super Beetle
1961 Dune Buggy,2010 Larz Anderson Class Winner
1971 BSA Lighting
1969 tin top westy
Tim Donahoe
Tim Donahoe is offline
PostPosted: Sun Mar 23, 2014 8:51 pm    Post subject: Reply with quote
VW installed that system as a means to convince would-be buyers and owners that they--the VW Dealer--had the a new-fangled "crystal ball" that they could magically plug in and tell you all you needed to know about how your car was doing. And, after the warranty was up, they charged you for it.
It was all an elaborate hoax, really. Most experienced VW techs didn't need such a diagnostic machine--no matter how futuristic it seemed back then.
Look at your Bently. It shows a number of illustrations with "special" tools that weren't really necessary--but they made you want to think that you couldn't do the job yourself because you lacked the magic tools.
Tim
Joel
Joel is offline
PostPosted: Sun Mar 23, 2014 10:43 pm    Post subject: Reply with quote
Its just basically a continuity tester for a bunch of the main circuits.
The flywheel TDC sensor just let the computer work out the timing as it compared the input from the TDC sensor to the coil low tension which allowed it to computer what the timing was set at.
The factory batterys just had a sensor in them too for one of the center cells for measuring the electrolyte levels.
all pretty primitive stuff and I know its just for novelty value but you can work it out much easier with a test light.
Yes, 60 vital service points... ha, try half that.
Quick little bug, you got a Porsche motor in that?
1974 Germanlook 1303 2.5 Suba-Beetle
bradmkjr
bradmkjr is offline
PostPosted: Mon Mar 24, 2014 2:21 pm    Post subject: Reply with quote
I'm now interested in that printout.. Anyone have a copy of one? or is there copies of them in the gallery?
theKbStockpiler
PostPosted: Mon Mar 24, 2014 2:52 pm    Post subject: Reply with quote
I do remember the wire on the battery and assumed it was for something that was 6 volt. Embarassed I have also seen plug wires that had 2 prongs sticking out of them. I assume that these were the factory correct ignition wires and only the Number 1 cylinder was provided with the diagnostic plug on it.
VWCOOL
VWCOOL is offline
PostPosted: Mon Mar 24, 2014 3:04 pm    Post subject: Reply with quote
AWESOME ad Joel!
Beeble1
Beeble1 is offline
PostPosted: Mon Mar 24, 2014 5:43 pm    Post subject: Reply with quote
Like these? This is what the computer print out looked like.
Beeble1
Beeble1 is offline
PostPosted: Mon Mar 24, 2014 5:46 pm    Post subject: Reply with quote
I know that the computer itself is obsolete, but the test report is kinda cool. I think it's more of a novelty for me.
