Pete B Samba Member
Posted: Mon Mar 24, 2014 5:34 pm Post subject: 74 stays in gear ??? |
Anybody have an idea why my 74 stays in gear after shutting it off. Can't get it in neutral even when its off.....Ideas ???? |
Beeble1 Samba Member
Joined: August 14, 2012 Posts: 578 Location: Manteno, Illinois
Posted: Mon Mar 24, 2014 5:38 pm Post subject: |
Can you get it into neutral when it is on? _________________ Beeble1, ‘73 Super (o\_|_/o) 1600cc w/ Dealer A/C
Beeble2, ‘13 Beetle 2.5L Daily Driver
Dealership items from Bishop-Wayne Volkswagen & Turner Volkswagen in Kankakee, IL wanted |
Pete B Samba Member
Posted: Mon Mar 24, 2014 5:54 pm Post subject: |
Nope stays somewhat in gear, can't roll it around. When its running have to pull the e-brake to keep it from driving off |
Joined: June 02, 2011 Posts: 1593 Location: Louisville, ky
Posted: Mon Mar 24, 2014 5:58 pm Post subject: |
adjust the clutch, should be near 3/4 inch of play at the pedal before resistance is felt. |
Pete B Samba Member
Posted: Mon Mar 24, 2014 6:00 pm Post subject: |
Kool I will give it a try.. thnx |
nextgen Samba Member
Joined: August 19, 2004 Posts: 6032 Location: CONGERS, N.Y.
Posted: Mon Mar 24, 2014 6:11 pm Post subject: |
If the car was not driven for a while sometimes and it has happened to, the disc somehow gets stuck to the flywheel. I used the e starter to break it free, by just turning the key and the starter usually break it from the flywheel as the car tries to leap forward. Make sure no one is in front or behind you when you try this........ Once it happened and the bug was locked in a forward gear but it was up against a wall. My friend had to pull the bug away from the wall with his jeep. _________________ email: [email protected]
The TYPE IV UPRIGHT CONVERSION MANUAL
BEETLE MAGNETIC DEFLECTOR SHIELDS
LETS TALK DUBS https://www.youtube.com/results?search_query=joe+cali+ghia https://letstalkdubs.libsyn.com/ep-200-joe-cali-ty...qI3xJTCzjs |
Pete B Samba Member
Posted: Mon Mar 24, 2014 6:16 pm Post subject: |
The guy I got it from drove it regularly, drove it 8 to 10 miles to get it to me. It has been sitting I started dropping the top (1.5 months) |
