worm burner Samba Member
Posted: Tue Mar 25, 2014 3:04 am Post subject: questions about running car audio? |
I am wanting to run a alpine head unit that has a 100 watt internal amp and I want to run just 4 speakers. I have never owned a bug I've had some rails but they didn't have audio.
Previous owner had a radio wired with some speakers but he took the radio out after it quit playing cds and decided to not replace it My question is can I run my head lights and a stereo and a phone charger all at once with no issue on a standard generator? Is there any modification I need to do to anything? Can I help the system by running a secondary smaller battery? I have a new honda battery sitting around it is a smaller battery out of a civic but it is new. I was wondering if I ran it next to the bigger battery would it assist the extra load ?
Thanks in advance.
DrKeck Samba Member
Posted: Tue Mar 25, 2014 5:03 am Post subject: |
If you look at the wiring diagram it will show a radio on the far right circuit breaker. You don't need to run an extra battery unless you plan on running a lot of power to a custom sound system. If it's jut a basic wiring it will be fine. The phone charger would be as equivalent as using a cigar lighter. _________________ 1966 Beetle
1600cc 50bhp
Daily Driver |
VOLKSWAGNUT Fastest VW Belt Changer
Joined: October 14, 2007 Posts: 11056 Location: Flippin' a Belt........ .... Off-n-On ... NC USA
Posted: Tue Mar 25, 2014 5:55 am Post subject: |
Unless you are adding extra amplifiers.. you wont have any issues.. and wont need an extra battery.
Generators dont charge much at low idle.. So unless you are idling around.. it will be charging.
Now if you have have SUPER HIGH wattage lights and fog lights and are already stressing the max capabilites of the generator, then yes. you may need to consider extra battery... or an alternator conversion.
Most VW generators are rated for 30 amps max..
If you have a stock lighting system .. the 100w radio may add 8-10 amps max (if that at all) at full use volume.
. _________________ aka Ken {o\!/o}
Rebuilt to drive not decorate
Usually and often edited |
Posted: Tue Mar 25, 2014 9:00 am Post subject: |
Awesome. .thanks for the info .I'm not planning on running and more lights than stock so I guess I'll be alright. Excellent. Much appreciated. _________________ A w is just 2 v's....or is it. ? |
TMI Products Samba Member
Joined: February 14, 2014 Posts: 744 Location: Corona, Ca
Posted: Tue Mar 25, 2014 4:58 pm Post subject: |
a 100 watt stereo will actually only put out about 12-15 watts at normal volume.adding a second battery will put a strain on a low apmerage alternator, not sure if that applies to a generator. _________________ Mario De Leon
1965 Turbo Mustang Fastback
1966 Type 3 Fastback
VW Division Sales Manager
[email protected]
TMI Products
1493 Bentley Dr.
Corona Ca, 92879
1-800-624-7960
951-272-1584 FAX |
