mwinter Samba Member
Posted: Fri Mar 28, 2014 4:33 pm Post subject: Racks/ Boxes on Air cooled Vanagon Camper |
Hi Folks....new member here and I'm looking to tap into some expertise.
I am considering storage options for a long road trip. I have an 83 air cooled with a newly rebuilt motor that i am going to take coast to coast in June. Id like to get a thule or yakima storage box or maybe some racking or a basket to free up some space inside the van. Id also like to make use of the luggage area.
What is the concensus on that sort of thing with an air cooled van. Will it throw off the cooling, kill mileage, etc? Or am I just worrying too much? What has worked for you folks?
Thx! Awesome site by the way! Im learning a ton. |
furrylittleotter Samba Member
Joined: May 19, 2008 Posts: 1506 Location: West Seattle
Posted: Fri Mar 28, 2014 5:38 pm Post subject: |
I highly suggest you do everything to pare down the weight of your van to an absolute minimum and not add anything to the roof. The air cooled van is anemic enough as it is. If you must add exterior storage I would do it with rear hatch mounted carrier such as this sweet Gary Lee unit…
http://www.telusplanet.net/public/gary2a/rack/rack.htm
Not cheap but I understand they are extremely well made and you can see how versatile they are.
I'm not sure if you are a new owner but if you are:
I also suggest you get a cylinder head temperature gauge, keep stock sized tyres, and never, ever floor the van, especially when climbing hills, just downshift and putt. Do not be surprised if you end up in second gear on some major grades. Plan ahead and stay in the slow lane when major grades are coming, you may even get passed by semi trailers, but you will get there.
Have a great trip…
Neil2 |
danfromsyr Samba Member
Joined: March 01, 2004 Posts: 15129 Location: Syracuse, NY
RocketBox Samba Member
Joined: March 20, 2014 Posts: 354 Location: Boise, ID
Posted: Sat Mar 29, 2014 7:49 am Post subject: |
Just out of curiosity - should the same precautions be taken with a waterbox also? |
a1fa Samba Member
Joined: September 25, 2011 Posts: 585 Location: Central Arkansas, United States
I have an 82 Vanagon Westfalia aircooled... and on top of that, I have a yakima box, and yakima bicycle rack..
No issues... _________________ Learn to ride. Ride to learn. |
a1fa Samba Member
Posted: Sat Mar 29, 2014 7:56 am Post subject: |
one thing to caution you about is the weight you put on top... the pop top will not open easy with any kind of weight.... you may strain your neck..
The way I have mine set up... You could still have your bikes on the rack while raising the roof...
VWinVT Samba Member
Joined: April 21, 2013 Posts: 1541 Location: North East Kingdom
Posted: Sat Mar 29, 2014 8:55 am Post subject: |
I have an 81 Westy. I carry a canoe on top. I will be purchasing this trailer this summer. As was mentioned; correct cooling tin and 'high' rpms going up hill you will not have any problems. Also a cylinder head temp. sensor (Dakota digital) will give you peace of mind. |
VWinVT Samba Member
Posted: Sat Mar 29, 2014 1:17 pm Post subject: |
RocketBox wrote: |
These are big vans with small OLD engines made of aluminum alloy.
Yes, common sense tells us to be modest in adding weight and reducing aerodynamics.
Can it be done? Absolutely. I was just making suggestions.
Neil2 |
Posted: Sun Mar 30, 2014 10:33 am Post subject: |
Thanks, folks! I appreciate the input! |
