7T3Thing Samba Member
Joined: March 30, 2014 Posts: 28 Location: Upstate New York
Posted: Sun Mar 30, 2014 7:45 pm Post subject: New to VW Thing, have questions |
My son's first car is a '73 Thing we just brought it home today. Numbers matching (I'm told), Sunshine Yellow, off the road, garaged since 2004, very solid except the top, of course. My son will be the third owner.
Plans are for a driving restoration, maybe deeper work during next winter.
I'll start with a few simpler questions:
The owner said this Thing had an optional 'swing axle', that was both desirable to VW enthusiasts and great for traction. What are the details of this? Distinctive feature to identify?
The front bumper ends appear to bolt to a bracket welded to the front fender. The welds are quite rusty, and don't quite look 'factory'. Owner mentioned original bumpers were just the straight section across the front. Again, details?
On restoration, what color were the floors originally? Body color? How were these painted during construction, each component separately (floor, body, etc) or all together with only primer between panels?
Read 1973 Thing wheels are Thing specific. what is the identifying feature to look for?
Thanks in advance for the help. More questions to come.
Looking forward to creating a quality representative to the Thing legacy.
Searched a little for other restoration threads, some great work going on here.
Thanks,
Dave _________________ Working with my son on his 1973 Thing |
Ferretkona Samba Member
Joined: December 03, 2005 Posts: 1306 Location: Columbia, CA
Posted: Sun Mar 30, 2014 9:29 pm Post subject: |
VW Things produced before 1973 were swing axle. Never a option on any year. Swing axles were borrowed from type 2 buses. Gear reduction boxes provide a bit of lift. If you look under rear axle swing axle vehicles have the large chunky boxes close to wheels. If you have a swing axle the Thing may be older than advertised.
Floors were black.
All bumpers had the returns that bolt to fender. _________________ 74 181 Thing
2008 Ford Sport Trac V8 4x4
2008 Ford Escape V6 |
JayC Samba Member
Posted: Mon Mar 31, 2014 6:30 am Post subject: |
Hi Dave, welcome to the board. Sounds like you found a nice Thing. Somebody will say it, so how about me... Pictures
The main support for the bumpers is on the underside of the apron with the ends being supported on brackets on the fenders.
If you really do have a swing axle, that would indicate it isn't a 1973 or it doesn't have the original transmission / axles. Check the VIN number in the trunk or stamped on the tunnel. There are a lot of threads here that detail how to decode it and understand year, etc.
The wheels were thing specific, 14 inches. Check the wheel / tire sticky at the top of the thread for all the details.
Good luck with project. Years and years ago I learned most of what I know working with my dad. I know when I started my restoration, this site has a bunch of good people that are always will to provide help and advice.
jay |
Bashr52 Samba Member
Joined: July 16, 2006 Posts: 5666 Location: On an island in VA
Posted: Mon Mar 31, 2014 8:02 am Post subject: |
Hey Dave, where are you located? I'm also in upstate and just finished the restore on my 73. |
NOVA Airhead Samba Member
Joined: July 20, 2005 Posts: 5221 Location: Richmond, VA
Posted: Mon Mar 31, 2014 8:23 am Post subject: Re: New to VW Thing, have questions |
7T3Thing wrote: |
Thanks,
Dave |
Also there really isn't any numbers matching on these cars. The engine ID number was not matched to the VIN as was done with US cars. The best you can do is insure the engine ID is appropriate for the year of the car.
In my view the swing axle is not as good a design as the fully independent set up but that is my opinion.
Also this thread may be of help:
http://www.thesamba.com/vw/forum/viewtopic.php?t=586354&highlight=number _________________ Ghia Owner Emeritus |
Posted: Mon Mar 31, 2014 5:34 pm Post subject: |
I figured someone would ask for pics. Posted late last night, was in a hurry.
Here's a couple of side shots.
It has the gas heater, which I suspect makes it a 73. Title is for 73. VIN says 73.
I'm not familiar with VW axles, so I can't tell if it's a swing axle or a swing shift. Is there a number on the axles somewhere? Anyone have pics of a swing axle? Distinguishing features?
Thanks,
Rev. Scott Samba Member
Joined: June 04, 2006 Posts: 770 Location: Philo, Ca.
Posted: Mon Mar 31, 2014 7:36 pm Post subject: |
Good looking car. Those would appear to be Thing wheels. Welcome to the forum. _________________ "I haven't seen one of those since I was shootin' at 'em!" |
GI Joe Samba Member
Joined: April 28, 2005 Posts: 2012 Location: Athens, TN
Posted: Mon Mar 31, 2014 8:05 pm Post subject: |
7T3Thing wrote: |
Thanks,
Dave |
Great looking Thing!!
Easiest way to tell a swing axle, from an IRS(independent rear suspension) is the rear axle boots....
If there is a boot on each end of the axle, it's IRS, if the boot is only on the transaxle end, then it's a Swing axle..... I'd guess this is a standard IRs car, as your rear ride height is saggy..... Like most Things...
Sounds like your seller was either misinformed, or simply confused on terminology himself.
Welcome!! _________________ '74 Thing, "Our Thing"....
http://www.thesamba.com/vw/forum/viewtopic.php?t=4...p;start=60
'71 Beetle RPU
http://www.thesamba.com/vw/forum/viewtopic.php?p=8080337#8080337
www.NLEOMF.com
Respect, Honor, Remember |
Deckard Samba Member
Joined: April 07, 2012 Posts: 296 Location: Knoxville, TN
Posted: Wed Apr 02, 2014 5:54 pm Post subject: |
It does look like a stock '73, with a repaint job at some time or another. VW Things have a thin black plastic bead between the fenders and the car's body, and since yours is yellow it is is probaly painted over. You also have a roll bar, which was a dealer option. The exhaust is non-stock.
The top also has some white tabs or something in the rear over the metal loops. |
Posted: Thu Apr 03, 2014 7:58 am Post subject: |
Dave, pm sent.
Thanks |
