karmann1st Samba Member
Joined: September 12, 2010 Posts: 93 Location: Florida
Posted: Sat Apr 05, 2014 10:30 am Post subject: 1600 engine shakes when I press the gas pedal & no heat |
Hi Everyone.
I have a KG coupe 1971 with a 1600cc engine and the H30/31 pic carburetor.
The car was sitting for 4 years and didn't work at all because a small ball inside the carburetor not making gas pass thru.
I cleaned everything and placed new seals.
I started and adjusted the idle, volume control screw and bypass screw.
The engine starts perfect and idles ok (no tachometer to say RPMs).
PROBLEMS:
- when I PRESS the gas pedal, everything moves and accelerate the car..BUT the ENGINE SHAKES a LOT.
- After 7 minutes running I stop the engine and NO HEAT on intake manifold.. is NOT even WARM.!
- I used a small Weeder gas tank container as a gas tank, and the gfas is NO GAS after the 7 minutres test... TOO MUCH GAS also??
At the moment my muffler is OUT of the car so I am testing just the engine.
ANY ideas to help me out??
Thank you all in advance.
Alex |
undecidedbear Samba Member
Posted: Sat Apr 05, 2014 12:14 pm Post subject: |
If you have the stock muffler, with that off the engine, the pre heater tubes that run under the intake are not getting heat from the exhaust. So thats why the intake is not getting warm. That could also be causing it to run rich, because the air/fuel mixture is not getting vaporized. But im not entirely sure. Try putting the muffler back on and hooking up the pre heater tubes and try it then. Have you tried timing it properly? Adjusted the valves, points? |
Posted: Sat Apr 05, 2014 2:05 pm Post subject: |
Yes, I changed and calibrate everything... the only major problem is the Shacking of the engine when I press the gas pedal... is like is going to UNSCREW itself.!!! regulating/idling is OK.
Is necessary to have the muffler installed? I just want to check the engine and gear before to unmounted the engine. that is the reason I dint install the new muffler that I have for the car in a box.
Sorry, I do no have the Heating channels/tubes, I eliminate them...
The one that is not getting warm is the one that is under the carburetor and goes to the cylinders probably carrying the mix..
Thank you for the reply.. I appreciate your help a lot! |
MacLeod Willy Samba Member
Joined: February 18, 2014 Posts: 933 Location: Ontario Canada
Posted: Sat Apr 05, 2014 3:38 pm Post subject: |
Start with removing the plugs and checking the wires and distributor cap. Certainly sounds like a misfire under load |
Posted: Sat Apr 05, 2014 5:01 pm Post subject: |
nope, no miss fires...
is just hesitation when gas goes into the carb when accelerating... shaking the engine more than normal.. _________________ Questions? Email me, I always answer all emails, same day or next. |
Posted: Sat Apr 05, 2014 10:37 pm Post subject: |
here are the pictures of my engine setup:
and
John Moxon Samba Moderator
Joined: March 07, 2004 Posts: 13955 Location: Southampton U.K.
Posted: Sun Apr 06, 2014 1:10 am Post subject: |
Don't run your Ghia on the road with all the wrong and missing parts in your engine compartment. Too cold? your engine will be frying without the engine tinware...here's what your 1600dp should look like...
Number one replace your fuel lines with the proper fuel hose and place the fuel filter outside of the engine compartment!
The carb you have is too small for the 1600dp...you should have a Solex 34pict and a stock vacuum distributor.
You need the fanshroud to heat exchanger hoses and an air cleaner set-up. Engine tinware is an essential for the aircooled engine...it separates the cooler top half of the engine from the hot bottom end. Take away the separating tinware and on even a warm day your engine will grind to a halt in a shimmering blue haze...not nice.
You can't tune your engine without the exhaust and aircleaner assembly get it in a state ready for the road and then get the engine running.
Others more knowledgeable will be along shortly to expand on these general observations. _________________ John.
Bobnotch Samba Member
Joined: July 06, 2003 Posts: 22422 Location: Kimball, Mi
Posted: Sun Apr 06, 2014 8:56 am Post subject: |
karmann1st wrote: |
Try swapping plug wire places 3 and 4 on the distributor cap. Right now you have them on the wrong spots. _________________ Bob 65 Notch S with Sunroof
Tram wrote: |
Tram wrote: |
Posted: Sun Apr 06, 2014 11:03 am Post subject: i DON'T KNOW HOW TO QUOTE =BUT I ADDED MY QUESTIONS/PARAGRAP |
John Moxon wrote: |
<<< I KNOW, I HAVE THE CORRECT ONES FOR WHEN I FINISH THE CAR... THIS IS ONLY TO TEST ENGINE AFTRER 4 YEARS SITTING.. I WANT TO BE SURE ENGINE IS OK, IDLE AND TRANSMISSION IS OK ALSO TO TAKE THE ENGINE DOWN TO PAINT TINS, AND DO THE CLUTCH, ETC.. >>>
<<< SOMEONE REPLACED IT WITH THIS 009 AND I WAS READING THE FORUMS AND ARE PROS AND CONS >>>>
<<< LIKE I MENTIONED I DELETED THE FAN SHROUD 2 EXITS SINCE I AM NOT USING THE HEATHERS AT ALL .. i HAVE ALL THE TINS AND RUBBER FOR LATER WHEN I FINISH THE CAR... >>>
<<< I DIDN'T KNOW THAT... THANK YOU... MEANING I CAN'T TEST THE ENGINE AND SHFT GEARS TO TEST IN THE CONDITION THE CAR IS NOW? >>>
Others more knowledgeable will be along shortly to expand on these general observations. |
Posted: Sun Apr 06, 2014 11:06 am Post subject: |
John Moxon wrote: |
<<< BY THE WAY, YOU HAVE A BEAUTIFUL ENGINE THERE.!!! >>>
THANK YOU FOR POSTING. _________________ Questions? Email me, I always answer all emails, same day or next. |
Posted: Sun Apr 06, 2014 11:09 am Post subject: |
Bobnotch wrote: |
karmann1st wrote: |
Try swapping plug wire places 3 and 4 on the distributor cap. Right now you have them on the wrong spots. |
WOW!, Really?? I do not have any miss fire...
is any map, plan, picture on where the wires are supossed to be??
or can you send me a picture of yours working OK?? to [email protected] thank you!!! _________________ Questions? Email me, I always answer all emails, same day or next. |
Posted: Sun Apr 06, 2014 11:23 am Post subject: |
karmann1st wrote: |
John Moxon wrote: |
THANK YOU FOR POSTING. |
Ha! Not my engine but it does belong to a Forum member Erik..."70140". Excuse me for telling you things you may already know but other's view the pictures and read the comments so it's always worthwhile to make what some will consider obvious and other will find enlightening information. _________________ John.
Posted: Sun Apr 06, 2014 11:54 am Post subject: |
John Moxon wrote: |
karmann1st wrote: |
John Moxon wrote: |
Ha! Not my engine but it does belong to a Forum member Erik..."70140". Excuse me for telling you things you may already know but other's view the pictures and read the comments so it's always worthwhile to make what some will consider obvious and other will find enlightening information. :wink: |
<<< thank you John!! I appreciate any input, I clarified everything to also let people know that this is a test setup to try the engine and tranny before taking it down.... what do you think about the distributor wires?? I do not see are wrong connected... also this engine from Erik has the gas filter there in the engine bay... regards, Alex >>>> _________________ Questions? Email me, I always answer all emails, same day or next. |
Loren Samba Member
Posted: Sun Apr 06, 2014 12:45 pm Post subject: |
x2 on the fuel line! replace that ASAP. Have you checked that all the bolts holding the engine to the transmission are tight? Have you checked the transmission mounts? |
Posted: Sun Apr 06, 2014 1:19 pm Post subject: |
Loren wrote: |
please remember that the fuel line is just for a test, not for driving.
all bolts and tranny mount are perfect...
When I press the gas pedal or give gas auctioning the carburetor the engine move to the left and to the right too much... and the acceleration is not constant anymore... I will try to post a video ..don't know how but I will try. thanks for the help. _________________ Questions? Email me, I always answer all emails, same day or next. |
djway3474 Samba Member
Joined: August 19, 2011 Posts: 2582 Location: The Real NDK So Cal
Posted: Sun Apr 06, 2014 1:42 pm Post subject: |
karmann1st wrote: |
Bobnotch wrote: |
karmann1st wrote: |
or can you send me a picture of yours working OK?? to [email protected] thank you!!! |
typically the distributor sits so that #1 is closest to the crank pulley. That is #1 cylinder then going clockwise it goes 1,3, 4, 2. It looks like all your wires are out of place |
iowegian Samba Curmudgeon
Joined: February 16, 2005 Posts: 9829 Location: Somewhere between Dubuque and Keokuk
Posted: Sun Apr 06, 2014 2:09 pm Post subject: |
djway3474 wrote: |
karmann1st wrote: |
Bobnotch wrote: |
karmann1st wrote: |
Close, but no cigar.
The firing order is 1-4-3-2.
#1 & #2 are reversed from what they should be.
It is no wonder that the engine "shakes". |
Posted: Sun Apr 06, 2014 4:30 pm Post subject: |
iowegian wrote: |
djway3474 wrote: |
karmann1st wrote: |
Bobnotch wrote: |
karmann1st wrote: |
OMG.. thank you... Iwill try that tomorrow..
the engine can be damaged because of my error wiring the spark plugs???
idling was ok,,, that is what I questioning... waiting to test that tomorrow
thank you again.!!! _________________ Questions? Email me, I always answer all emails, same day or next. |
djkeev Samba Moderator
Joined: September 30, 2007 Posts: 32625 Location: Reading Pennsylvania
Posted: Sun Apr 06, 2014 5:18 pm Post subject: |
djkeev wrote: |
This photo should help......
Dave |
Great Dave! I was trying to find that map on internet but you got it!!
Thank you again, I had the 1 and 2 reversed as I see on the map ..
I wil check tomorrow!!! Thank you.....
Hopefully my engine is OK after having the engine running for 7 minutes with the wires reversed.
Also perhaps the gas consumption was that.... _________________ Questions? Email me, I always answer all emails, same day or next. |
