schoonerman Samba Member
Posted: Tue Apr 15, 2014 9:31 am Post subject: AFM allen screw way out |
When checking the AFM I found that the allen adjusting screw to be 13 turns out.
Could this be the reason that it failed aircare on idle?
I also found the plugs to be white on the electrodes
The van runs good otherwise
Any help
Thanks _________________ 87 Westy/Vanagon |
insyncro Banned
Posted: Tue Apr 15, 2014 9:36 am Post subject: |
1.5 revs out from seated is the stock position when new. |
Ahwahnee Samba Member
Joined: June 05, 2010 Posts: 9810 Location: Mt Lemmon, AZ
Posted: Tue Apr 15, 2014 1:15 pm Post subject: |
Mine (84 Digijet) appeared to be untouched when I removed the plug -- it was screwed all the way in. |
insyncro Banned
Posted: Tue Apr 15, 2014 2:33 pm Post subject: |
1.5 on the 2.1s
His sig says 87 Westy |
sea_sick Samba Member
Joined: July 21, 2012 Posts: 113 Location: West Coast
Posted: Tue Apr 15, 2014 3:43 pm Post subject: |
Ahwahnee wrote: |
Same here on a 90. |
Ahwahnee wrote: |
Posted: Tue Apr 15, 2014 10:02 pm Post subject: |
Decided to screw it in to the stated 1 1/2 turns out from the bottom, no noticeable change in engine, took her for a drive and still runs good
Hope I haven't changed the emissions. _________________ 87 Westy/Vanagon |
insyncro Banned
Posted: Wed Apr 16, 2014 4:34 am Post subject: |
If you are looking for better emissions numbers, you need to have the exhaust analyzed while making changes. |
Gauche1968 Samba Member
Posted: Wed Apr 16, 2014 8:11 am Post subject: |
insyncro wrote: |
1.5 on the 2.1s
What is it on 1.9s? _________________ 1984 Vanagon GL
1984 Vanagon Westy |
insyncro Banned
Posted: Wed Apr 16, 2014 8:17 am Post subject: |
Gauche1968 wrote: |
insyncro wrote: |
1.5 on the 2.1s
What is it on 1.9s? |
No clue.
I don't own any brand new 1.9 AFMs to check. |
61Scout Samba Member
Joined: November 06, 2011 Posts: 1297 Location: Shoreline/Yakima WA
Posted: Wed Apr 16, 2014 12:48 pm Post subject: |
61Scout wrote: |
Emissions can be tricky. OP, do you have a print out of the fail sheet? If so, post it up with a picture so we can see. Chances are you many have to address other components beyond messing with the AFM. Have you checked your O2, throttle body, cracks in the boot? etc.
-Kevin |
I've checked all vacuum lines, injector o rings, charcoal canister, throttle body and rubber boot but not the o2 sensor
For the emissions sheet, please check my other post...... failed aircare, bad idle.
I thought I had found the idle fail problem with the AFM screw being way out, that's why I asked if this could be the problem
I have booked a VW shop for next Wed to have them check with their sniffer and make adjustments etc.
Thanks
Mike _________________ 87 Westy/Vanagon |
tschroeder0 Samba Member
Joined: April 14, 2008 Posts: 2096 Location: Boulder CO
Posted: Wed Apr 16, 2014 7:18 pm Post subject: |
if you search AFM signal testing and AFM mixture setting you will get everything you need to know about messing with that box o fun. |
