iamdonquixote Samba Member
Joined: January 28, 2003 Posts: 2041 Location: M*ssholia
Posted: Sun Apr 20, 2014 8:31 am Post subject: Chassis tube diameters / dimensions |
Anyone have the specs on the OD/ID and length of the following chassis tubes:
accel cable tube
heater cable tube
fuel reserve cable tube
choke reserve cable tube
heater tube
clutch cable tube
e brake cable tube
thanks |
flemcadiddlehopper Samba Member
Joined: December 05, 2011 Posts: 2332 Location: Kelowna, BC. Canada.
Posted: Sun Apr 20, 2014 9:09 am Post subject: |
what year?
Gordo. _________________ Everybody Dies....Some Never Live.
Retrograde Garage. Vintage Aircooled, and others. |
Posted: Sun Apr 20, 2014 9:24 am Post subject: |
I assumed they were all the same 55-67 except the shift rod tube.
60' - hence the choke cable and reserve cable tube |
Posted: Sun Apr 20, 2014 9:41 am Post subject: |
I'll try and squeeze under my '67 today and measure up the heater control tubes , throttle tube, and the clutch tube. No heater tube to measure as it was replaced with exhaust pipe.
Posted: Sun Apr 20, 2014 12:17 pm Post subject: |
I wonder if there is some tech doc from VW? |
crowlejo Samba Member
Joined: May 29, 2007 Posts: 53 Location: Wichita Falls, tx
Posted: Wed Jun 04, 2014 9:09 am Post subject: |
Did anybody ever find this out? I also need it. I'm deployed and trying to gather parts for a project waiting for me at home. Everything was cut out of the cargo floor, including the tubes |
MrBusCo Samba Member
Joined: February 13, 2007 Posts: 1561 Location: stoughton, WI
Clara Samba Member
Posted: Wed Jun 04, 2014 6:53 pm Post subject: Re: chassis tube diameters / dimensions |
iamdonquixote wrote: |
accel cable tube
heater cable tube
heater tube
clutch cable tube
e brake cable tube
thanks |
there is no tube for the reserve or choke cable.
They just come in sheaths, which are tied to the bus with metal cable tabs. |
j.pickens Samba Member
Joined: December 03, 2002 Posts: 9791 Location: Exit 7, New Jersey
Posted: Wed Jun 04, 2014 8:21 pm Post subject: Re: chassis tube diameters / dimensions |
Clara wrote: |
accel cable tube
heater cable tube
heater tube
clutch cable tube
e brake cable tube
thanks |
Unless you have a belly pan bus? _________________ Founder and Chairman Emeritus, ECMSAS
BeaterBarndoor wrote: |
i wish more people would actually drive their vws rather than just talking about what they have in the garage. |
Red Fau Veh wrote: |
If you've seen one sunroof swivel seat kombi, you've seen them all! |
Clara Samba Member
Posted: Thu Jun 05, 2014 6:04 am Post subject: Re: chassis tube diameters / dimensions |
j.pickens wrote: |
Clara wrote: |
accel cable tube
heater cable tube
heater tube
clutch cable tube
e brake cable tube
thanks |
Unless you have a belly pan bus? |
mm ... now we need to look under and 61or older belly pan bus. |
Posted: Thu Jun 05, 2014 8:42 am Post subject: Re: chassis tube diameters / dimensions |
Clara wrote: |
j.pickens wrote: |
Clara wrote: |
accel cable tube
heater cable tube
heater tube
clutch cable tube
e brake cable tube
thanks |
Observe: _________________ Founder and Chairman Emeritus, ECMSAS
Posted: Sat Sep 27, 2014 5:28 pm Post subject: |
yeah, this is for as John says "a belly pan bus" |
esde Samba Member
Joined: October 20, 2007 Posts: 5969 Location: central rust belt
Posted: Sat Sep 27, 2014 7:05 pm Post subject: |
I have some chunks of the tubes cut from my 65 saved. The accelerator, heater, and another mystery tube (choke?) are 8mm outside, 5mm inside. The emergency brake tubes are 12mm outside, 10mm inside. The clutch tube for the most part was MIA when I got it, but the holes in the chassis suggest 12mm also. |
lightice Samba Member
Posted: Sun Sep 28, 2014 1:27 am Post subject: |
accelerator cable. 2400mm long, 8mm OD, 1mm wall thickness
clutch cable. 1845 mm long, 12mm OD, 1mm wall thickness.
handbrake cable 1535mm long, 12mm OD, 1mm wall thickness (2req)
heater control cable. 2775 mm long, 8mm OD, 1mm wall thickness (2req)
gear linkage rod. 1475mm long, 30mm OD, 1mm wall thickness |
