adamjjohn203 Samba Member
Joined: March 18, 2012 Posts: 187 Location: Bainbridge Island, WA
Posted: Tue Apr 22, 2014 10:05 pm Post subject: |
I have full coverage with windshield replacement. It was a hundred dollar deductible for the job, but I paid an extra hundred for rust clean up, sealant and filling the hole. _________________ '87 Westfalia
2000 Volvo V70 "eVOLVOd" |
Steve M. Samba Member
Joined: July 30, 2013 Posts: 6829 Location: Fort Lauderdale, Fl.
Posted: Wed Apr 23, 2014 8:15 am Post subject: |
adamjjohn203 wrote: |
I have full coverage with windshield replacement. It was a hundred dollar deductible for the job, but I paid an extra hundred for rust clean up, sealant and filling the hole. |
just out of curiosity. Who is manufacturer of new windshield, tinted top band or clear glass? |
Posted: Wed Apr 23, 2014 9:25 am Post subject: |
The manufacturer is Fy here is a shot of the info. No tint stripe on top.
srmpf Samba Member
Posted: Wed Apr 23, 2014 9:53 am Post subject: rebuilt the rear bench |
not today but over the last few weeks I rebuilt the rear bench. I don't like the setup and color scheme of my 82 (brown!) and will rebuild the whole interior (more info in this thread). the rear bench seemed to be the easiest part, so why not start with that.
This is is how the old one looked like:
Fabricating is pretty straight forward: use the old ones as a template. I've used 1/2" plywood for the bottom part and 3/4" for everything else.
Never laminated anything before or used a router but that's not really difficult to learn. I'm going with the grey color scheme of the later vanagons and also upgraded the locking mechanism with one from a 87 that showed up in a local salvage yard. Here's a picture of the final result - back:
and a picture from the front. both starter and house battery live there as well as the inverter/charger under the batteries. I've also relocated the 110V outlet
Lessons learned: a) practice laminating and using the router on a piece of scrap wood and b) 3/4" plywood is too heavy. I'll go with the 0.5" for the cabinets. |
Posted: Wed Apr 23, 2014 1:56 pm Post subject: Galvanized trailing arms. |
I went and picked up the trailing arms from the plating people!
Then dropped them off to be powder coated. The guy said they would be done tomorrow so it's looking good for this weekend to install them.
Jake de Villiers Samba Member
Joined: October 24, 2007 Posts: 5911 Location: Tsawwassen, BC
Posted: Wed Apr 23, 2014 2:03 pm Post subject: |
Yesterday afternoon I finally got around to installing my new Stan's Headers SubaruVanagon header. What an improvement over the POS Small Car junk... made in Washington and fit perfectly. Looks nice, too!
The header hangs down just about as far as the shortened oil pan - I don't foresee any problems with clearance.[/img] _________________ '84 Vanagon GL 1.9 WBX
@jakedevilliersmusic1
www.crescentbeachguitar.com
www.thebassspa.com |
djkeev Samba Moderator
Joined: September 30, 2007 Posts: 32584 Location: Reading Pennsylvania
16CVs Samba Member
Joined: February 22, 2004 Posts: 4024 Location: Redwood City, California
Posted: Wed Apr 23, 2014 7:48 pm Post subject: |
So Mr DjKeev
What type of glass are you buying ? I can only find FY or XY . If you are buying something else ,I'd like to know what the brand is.
More than that ,what is the DOT # ? I hear a lot of talk that this Chinese stuff does not fit. I have installed at least 30 Vanagon Windshields without incident. Maybe I am just that good that I can make anything work. A lot of what you think is domestic is still made in China.
I have seen some PGW glass (made in China) with a blue band , I have heard of some Pilkington(Mexico/Canadian) but none of my suppliers have them.
Stacy _________________ 1987 Syncro Westfalia Triple knob (bastard)
Samba member # 14980
Don't let your van end up in an "abortions" thread. |
oldhuldy67 Samba Member
Joined: November 25, 2008 Posts: 506 Location: somewhere with a southern exposure
Love My Westy Samba Member
Posted: Fri Apr 25, 2014 11:59 am Post subject: |
I just added a couple of spacers inside my front Koni shocks. What I am aiming for is to keep my 215 75 R 15 tires from hitting my fender flares at Syncro Solstice. I have Van Cafe springs I installed 2 years ago. I have an '86 2wd Wolfsburg Weekender camper. I hope it works, I would rather hit the jounce stops than my fender flares. |
mlbdriver Samba Member
Joined: October 16, 2013 Posts: 63 Location: Outer Banks
Posted: Fri Apr 25, 2014 2:18 pm Post subject: |
So I replaced my rotors, pads, and wheel bearings. The ride is so smooth now. Only thing I messed up was the speedo cable couldn't get it back through the dust cap. So needless to say my speedometer isn't working now. |
regis101 Samba Member
Joined: July 28, 2005 Posts: 2078 Location: Livermore, Ca
Posted: Sat Apr 26, 2014 6:24 pm Post subject: |
Transaxle fluid change. Read a van load of info on here.
Im sure its the OE trans with a bazillion miles on 'er.
So I opted to go factory(ish) and sourced some Sta-Lube 85w-90 GL/4.
Kinda glad I did this so I now know how much fluid is in there. I did have it serviced about two years ago. Today, a bit over 4 qts came out. eh
I opened the gallon jug of Stay Lube and marked the side at the fluid top. Then split this into four marks down the side of the jug to represent four qts. Split that last qt mark in half so I knew where 3.5 qts would be.
Then I trimmed the hose from the hand pump so it would equate the depth of 3.5 qts. This meant that about 3/4" of fluid will be left in the jug. I allowed for the fluid in the pump hose with a couple more squirts. I'm confident that there is no more than 3.75 qts in there. Did this on the ground on my slanted driveway.
But I see that I need new glasses. I mistakenly put the top plug in the lower drain hole. Out came the drain tub again and a quick change with the correct lower plug happened. Some fluid was lost But I pumped in about three squirts with the left over fresh 1/2 qt.
There was still some new stuff left and now all is really well. I wont give a mind to the fluid level being 1/2" or 9/16" below the hole until I get it on a level surface and after a few miles. Prolly wont even worry about it then. _________________ Peace, Regis |
imagesinthewind Samba Member
Posted: Sat Apr 26, 2014 6:50 pm Post subject: |
I did this...
This is me...
chojinchef Samba Member
Joined: February 17, 2011 Posts: 1539 Location: Central Massachusetts
Posted: Sat Apr 26, 2014 6:56 pm Post subject: |
Pulled out of the garage, played in the rain. Oil change, new plugs, rotate tires, fuel filter.
Took out the Christmas lights from each of the windows.
Attached the grille 'brow' I bought in Germany and that I had been questioning.
Raining out all day, or else I would have washed, compounded and waxed it. Next weekend I guess. Needs a good buff.
Started cleaning the inner surfaces. _________________ Its a mistress; an expensive, whiney, needy bitch of a mistress. She is a chunky, dirty girl with bad skin, little motivation and yet she always makes me smile. She sure has been around before shacking up with me. She has a direct line to my wallet, plays with my emotions, is consistantly jovial yet with a sarcastic and sardonic side, is consistant in her inconsistancy, and every once in a while gives me a great ride and a fantastic memory. |
Posted: Sat Apr 26, 2014 7:02 pm Post subject: |
imagesinthewind wrote: |
I did this...
[ Hello, world, here's the song that we're singin'
C'mon get happy ]
Sorry, had to say it. You're awesome _________________ Peace, Regis |
Posted: Sat Apr 26, 2014 7:06 pm Post subject: |
regis101 wrote: |
I did this...
C'mon get happy ]
Sorry, had to say it. You're awesome |
Was thinking the exact same thing.
Like the look btw.
LP _________________ Its a mistress; an expensive, whiney, needy bitch of a mistress. She is a chunky, dirty girl with bad skin, little motivation and yet she always makes me smile. She sure has been around before shacking up with me. She has a direct line to my wallet, plays with my emotions, is consistantly jovial yet with a sarcastic and sardonic side, is consistant in her inconsistancy, and every once in a while gives me a great ride and a fantastic memory. |
Posted: Sat Apr 26, 2014 7:09 pm Post subject: |
Two tone or three tone the pop top.
Cant envision what to do with the wheels. Nice rims. Silver maybe.
Cool. Cool. Cool. _________________ Peace, Regis |
luckystu Samba Member
Joined: September 20, 2011 Posts: 70 Location: Tasmania, Australia
Posted: Sat Apr 26, 2014 11:58 pm Post subject: |
Love that paint job 'imagesinthewind'. Bet that masking took some time!. I wasn't so creative today...more destructive ... and finished parting out my donor camper.
_________________ 1990 Syncro Camper : 2.1wbx : Rear Locker : Decoupler : Camperize pop top conversion ; 2" lift and 16" CLK rims (215/70r16} |
16CVs Samba Member
Posted: Sun Apr 27, 2014 1:25 am Post subject: |
I'm with Regis , I love the paint but the wheels need to go or at least paint em Silver .
