largest tire size for stock 85 westfalia
dillon schuh
dillon schuh is offline
PostPosted: Fri Apr 25, 2014 7:32 am    Post subject: largest tire size for stock 85 westfalia Reply with quote
I picked up some 15" mercedes wheels and would like to put the biggest tire on. Would a 235/75 fit? Is there any way to lift a 85? I heard that stock 85's are the highest and the 2" lift from gowesty wont do anything. Any help would be great.
AKWesty
AKWesty is offline
PostPosted: Fri Apr 25, 2014 7:52 am    Post subject: Reply with quote
Measure your center of hub to your fender lip on all four corners. I have the 2wd GW all terrain package with the 1.5" springs and it will give you a lift of 18" from wheel center to fender lip. I have an 84'.
If you are close to this and someone else can tell you the tire size, you also have the option of adding 1/2" spacers to your current springs to give you what you need or want. 18" of lift seems to be the agreed max you can lift a 2wd. Syncros seem to run around 20-21" at the same measure points.
dillon schuh
PostPosted: Fri Apr 25, 2014 8:07 am    Post subject: Reply with quote
What would I have to do to make 235/75 fit my 85. Where do I buy lift spacers? I will measure my wheel hub to fender height.
danfromsyr
danfromsyr is offline
PostPosted: Fri Apr 25, 2014 8:12 am    Post subject: Reply with quote
maybe a good place to ask is in the WHAT TIRES FIT THREAD?
http://www.thesamba.com/vw/forum/viewtopic.php?t=584507
Abscate wrote:
AKWesty
AKWesty is offline
PostPosted: Fri Apr 25, 2014 8:14 am    Post subject: Reply with quote
You can buy them from GW but they are like $20 a piece. I have read where some will make them from a cutting board or other hard plastic resource.
Here is a tire size chart that is very useful
http://tire-size-conversion.com/tire-size-chart/
With my 18" center to fender I can accommodate 215/70-16's. Tire chart puts those tires at 28"x8.5 outside diameter. GW considers this combination to be the maximum for a Westy. For the lighter tin top 2wds they don't recommend their springs as they ar to much. Disclaimer on their website.
idahoskier
idahoskier is offline
PostPosted: Fri Apr 25, 2014 8:57 am    Post subject: Reply with quote
235/75 will not fit. To make them fit you would need to do serious mods to the suspension (think Burley control arms front and rear) as well as cut fenders in the front possibly. You would need a different axle/CV set up in rear to handle the increased angle. I have stock 85 front springs with coil over load assist shocks and syncro springs in the rear and ride about as high I think you can go without serious mods (18.5"). I have 16" BFGs (215/70) and rub the front fender under full compression in a turn. A 235/75-15 BFG is 717 revs/mile. Mine are 743 revs/mile and I would certainly not want to go that big even with a Subaru engine. What power plant do you have?
85 Westy w/ 2.2L Subaru
91 Westy w/ 2.5L Subaru - sold
j_dirge
j_dirge is offline
PostPosted: Fri Apr 25, 2014 9:11 am    Post subject: Reply with quote
This^^^
Except that I run 29.5 tires and have been (with a 2.1 WBXer) for several years. Its a different type of driving and one you have to come to grips with.
Trade-offs, no doubt.
I am in the minority, here.. and that said, I would not recommend that size to anyone unless they want to, and enjoy, modifying stuff and spending a good deal of coin to do so.
I would recommend no bigger than 215 wide and 28.5 inches tall...
LOTS has been written on what tires work.. and that thread listed above is a good place to start.
After that.. do a search on "pre-runner vans" and THAT thread discusses suspension mods in good detail...
Here:
http://www.thesamba.com/vw/forum/viewtopic.php?t=389820&highlight=prerunner+van
ALL your answers are already type out here on this forum.
Have a look thru the FAQs.. which our moderator Kamz has put a great deal of work into.
-89 GL Westy, SVX.. finally.
-57 pan f/g buggy with a 67 pancake Type 3 "S"
"Jimi Hendrix owned one. Richard Nixon did not"
-Grand Tour, Season 1, episodes 4 and 5
danfromsyr wrote:
those are straight line runs with light weight race cars for only 1/4mile at a time..
not pushing a loaded brick up a mountain pass with a family of 4+ inside expecting to have an event free vacation..
Wildthings
Wildthings is offline
PostPosted: Fri Apr 25, 2014 9:40 am    Post subject: Reply with quote
Running 27x8.5r14's I notice a significant loss of tractive effort at higher elevations, so unless you are adding a lot of extra HP or are willing to downshift more often then go with something smaller.
davevickery
davevickery is offline
PostPosted: Fri Apr 25, 2014 11:55 am    Post subject: Reply with quote
Yep, you ask a specific question and get a totally different answer. But you may be asking the wrong question, which is what is the biggest tire I would want to put on an 85. Since you didn't mention an engine conversion you probably have an 80hp stock engine and stock gearing. That combo isn't capable of running that tire. 215/75-15 is also way pushing it, but it would fit and look nice.
Searching "prerunner" or "lifting 2wd" should answer your question in detail.
Hammy1
Hammy1 is offline
PostPosted: Fri Apr 25, 2014 4:30 pm    Post subject: Reply with quote
Here's my 85' with 215/75 15". I added 1" of lift in the rear using the cutting board lift. Kept the stock engine, didn't really notice much of a loss power. I am doing a suby swap because the engine is tired, but if i didn't need to replace the motor i wouldn't. I think the distance from the fender to the centreline is around 19".
ThankYouJerry
ThankYouJerry is offline
PostPosted: Fri Apr 25, 2014 10:11 pm    Post subject: Reply with quote
Why do people so often assume that "bigger must be better"? Maybe it's just the American way Rolling Eyes . It's more than likely a compensation for something else that's lacking Wink... In the case of Westy tires, what is the problem and what is the ideal outcome? Swaying in the wind? Autocross times not competitive against the Miatas? Nurburgring times not low enough? What about the current condition of sway bars, bushings, ball joints, wheel bearings, etc, etc, etc?
I get wanting to upgrade to 15" wheels. I'd go 215/65/15 or 215/75/15 max. 205s probably just as good if not better. Again, what engine do you have powering your van? That's a very valid consideration when considering upsizing wheels/tires.
Check the "What tires fit" sticky for other options. Or, I see you are in Sacramento.... Go talk to Stephan at Stephan's Auto Haus.
1990 Multivan - "Ohana"
1.8T, Auto w/3.27 R&P + Peloquin TBD
Jon_slider
Jon_slider is offline
PostPosted: Sat Apr 26, 2014 9:16 am    Post subject: Reply with quote
contact Christopher Schimke for info on proper hardware and spacers. Depends on the wheel specs. He knows how to make things fit. Be ready to add lift, possible fender mods and trailing arm mods, and a motor swap.
Big tires rob the van of power.
Hammy1 wrote:
215/75 15"... I added 1" of lift ... I am doing a suby swap because the engine is tired
nice pic Smile
instead of a motor swap, try 205x65x15 tires to put some pep back into your van's gearing
My Soapboxes: Inflation; Handling; Gearing; Decoupling; Swepco
uncommonvw
uncommonvw is offline
PostPosted: Sat Apr 26, 2014 10:05 am    Post subject: Reply with quote
nice pic Smile
I can attest to what Jon_Slider says about the bigger tires.
I have 215/75/15 on my 85 Westy, automatic with a 92 Jetta 1.8L engine. It really bogs down going up hills. I have a set of 205/70/15 I'm going to try to see if it gives better drivability. I can't imagine what 235s would be like.
Hammy1
Hammy1 is offline
PostPosted: Sat Apr 26, 2014 4:52 pm    Post subject: Reply with quote
I hear ya on the gearing. Once I get the swap done and flush out the bugs I'll sort out the gears. One thing that I can say about the van is, it was gutless before the bigger tires and gutless after the bigger tires. Either way people are are gonna be pissed off at you on the long hills stock wheels or not. Laughing
Regards'
Jon
morymob
morymob is offline
PostPosted: Sun Apr 27, 2014 8:52 am    Post subject: Reply with quote
U could do as i did on rear window=PASS NOW AVOID THE RUSH
Steve M.
Steve M. is offline
PostPosted: Sun Apr 27, 2014 9:29 am    Post subject: Reply with quote
LoL and so true!
j_dirge
j_dirge is offline
PostPosted: Sun Apr 27, 2014 9:52 am    Post subject: Reply with quote
Yep..
And downshifting is just a fact of life with a WBXer...
I just don't see all the hullah baloo over having to downshift on a hill... I've always had to do it.. 25" tires or 29" tires.. I just have to downshift earlier with my 29s.
When I see my rpms dropping below 3k, and I see I have more hill left to go? downshift..
And this is true all the way down to 1st gear.
The trade off, is a I can accelerate to HWY speeds in 3rd gear (manual).. and settle into 4th once speed is attained..
The main drawback, for me, is that I run out of gearing in 1st.. and I wish I had a granny.. particularly off road and at higher altitudes.
This was true with my tall 14" tires, it is even more pronounced with my much taller 16" tires..
There I also the problem of the big gearing gap between 2nd and 3rd in the manual.. where dropping to 2nd on a HWY grade limits your speed as you wind out to 5k.. but shift to 3rd and it lugs.. Not good, but rare circumstance.
This may not be an issue with the auto, however.
I find there are grades, offroad and at altitudes of 6000'+, 1st gear territory,.. where the smaller 14" tires made it up OK, but I had to SERIOUSLY slip the clutch to get the van up with the much bigger 29.5s.
I know of one road in particular where the van could not do it with the big tires where I had gone before with smaller ones.. but that could have due in part to a big camping load, as well.
The 25" tire and the gearing that VW chose was done, in part, to optimize the van for 55mph HWY speeds...
My personal opinion that a lower cruising rpm with 27-28s is a good tradeoff. But mostly just for reducing engine noise levels.
MPGs suffers slightly due to more windeage as tires get bigger.. AND due to ease of traveling at higher speeds. I.E. Cruising at 70 in a van 1" taller is going to consume noticeably more gas than cruising at 60 and is 1" lower.
I have lost about 10% fuel economy with a 3" over stock ride height and the 29s make for 2" of that. That is not a trade off too many people would take..
And in my opinion it is this fuel economy issue that would be the biggest compromise.. not the perceived loss of power.
My next set of tires will likely be 28-28.5s.. regardless whether I change powerplants. The choice to limit to 28.5 has mostly to do with re-gaining full suspension arcticulation in the front wheel well...
Jon_slider
PostPosted: Sun Apr 27, 2014 12:50 pm    Post subject: Reply with quote
This is an important factor. Are you warning the OP that if he goes to 235's his tire will rub the front wheel arch?
Does that mean he would need to modify his fender, or use higher lift?
How much lift do you have, and how much more would be needed to solve the problem?
j_dirge
j_dirge is offline
PostPosted: Sun Apr 27, 2014 2:01 pm    Post subject: Reply with quote
Yes.
This contact occurs when the wheel is turned outward and compression is moderate to extreme.
235s are almost sure to hit the top of the fender lip, It is not just "rubbing" The contact results in "fender bang" and cut up tires.
Before you even get that far:
The 235 will require effective ET of ~25 to even fit without the tire hitting the upright inside.. and that pushes out the outer edge of tire even beyond where mine (a 225) is located
No amount of lift will fix that, as the suspension will compress regardless what height spring you put in.
The ONLY way to stop it is to modify the fender lip (push out and reshape) and/or introduce added bump-stop to slow/stop the upward travel of the wheel. Adding bump-stops reduces overall suspension travel.. and that begins the law of diminishing returns. You'd be limiting upward travel to about 2-3" depending on spring used.
I believe there is potential in lifting the van (2WD) by lowering entire front suspension.. not just a spring lift.. but that would require cutting and welding of the lower control arm mounting points, relocating steering rack, etc. RCA bulkhead..
I was jawing with Burley about this once.. building new longer LCAs that pivot from further inboard.. lengthening RCAs.. building a "long travel" 2WD.. prerunner style..
Sadly, my pocket book can not support that idea coming to fruition...
Very Happy
Killcullen
Killcullen is offline
PostPosted: Sun Apr 27, 2014 2:34 pm    Post subject: Reply with quote
By design I have never seen any reason to put larger tires on my '85. The ground clearance is already very significant and with skill you can drive over some pretty ugly terrain if want to. A little wider would not be an issue but taller seems like a waste of time. I have 205/65/15's , but may go to a 215/75/15 to be able to get into an AT tire.
