zackcowie Samba Member
Joined: April 05, 2010 Posts: 49 Location: Palmdale, California
Posted: Fri May 02, 2014 4:36 pm Post subject: |
durfeec wrote: |
Understand there are 2 different size camper windows like that. The smaller ones for cut in panels, which I think you have, and a larger size that fits into a kombi window opening. Make sure you're getting the right ones. Cut panel campers are where it's at. I prefer it over a late westy. |
Thanks! I need the larger of the two right? with the more square frames?
I see that you have a 1960 panel/ camper. think you could post some pics to the gallery so I could check it out?! |
fluxcap Samba Member
Joined: February 07, 2006 Posts: 1969 Location: Newnan GA
Posted: Fri May 02, 2014 4:42 pm Post subject: |
zackcowie wrote: |
durfeec wrote: |
Yes, square corners! I think they are larger. I needed one when I got my bus (originally a panel), and a friend found a sweet deal on one at Bulli. But it turned out to be the type for a window bus, and it was too small to even make temporarily work.
What you want (notice the square top corners)
What you don't want (rounded top corners)
_________________ Eric - 1966 camper bus
"It's like, how much more black could this be, and the answer is none.......none more black." |
Posted: Fri May 02, 2014 4:48 pm Post subject: |
Also, there are different sizes of the panel versions, so make you get the right size. See the top pic above of the cargo doors and see how the windows go all the way to the belt line. Now see the pic below and see how the windows are shorter.
Posted: Fri May 02, 2014 5:38 pm Post subject: |
Wow all good info! So the one I need is very speciic. Square top corners that go all of the way to the belt line. The actual dimensions of the holes are I believe 14 x 18. Thanks for all this great info, it helps alot and is appriciated greatly! |
srfndoc Samba Member
Posted: Mon May 05, 2014 8:41 am Post subject: |
Here's another shot of the ones you need:
_________________ RPM=(MPH*336* (R&P*4th*1.26))/Tire Diameter in inches |
durfeec Samba Member
Posted: Mon May 05, 2014 5:33 pm Post subject: |
zackcowie wrote: |
durfeec wrote: |
I have the smaller version of the panel windows so it wouldn't be much help. It looks like everything got answered though. _________________ 1960 Bus Panel/Camper |
Posted: Mon May 05, 2014 7:04 pm Post subject: |
durfeec wrote: |
zackcowie wrote: |
durfeec wrote: |
I have the smaller version of the panel windows so it wouldn't be much help. It looks like everything got answered though. |
Would you be interested in selling them? Because If so, might be interested in them, and perhaps just weld the holes on my bus to be a little smaller. |
Posted: Mon May 05, 2014 8:46 pm Post subject: |
NOS 1950's ALERT! These NOS decals decals are going on the interior panels and possible on the exterior of my camper bus! My Grandfather was an ice cream man in the San Fernando valley, (California) from the 40's thru the 60's and he saved many of the decals. He was going to throw them away and my dad saved them from the trash back in the 90s. Now I'm going to use them on my bus and surprise my grandfather, who used to have a vw camper himself.
velvetgreen Samba Member
Posted: Tue May 06, 2014 7:01 pm Post subject: |
good save on those stickers they will be a great surprise |
Posted: Sun May 11, 2014 9:41 am Post subject: |
We'll the sanding party went well, big thanks to everyone who came over and was in the pictures and those who came after the camera was put away. I have some awesome friends. there's a lot left to sand but we did pretty well considering how much just plain hanging out we did, here Are some pictures from the day
Also big thanks to my good friend Scott! He gave me the front emblem for my bus! Awesome birthday present! |
Posted: Mon May 12, 2014 9:36 pm Post subject: |
Engines out! Ready for some maintenance! |
mandraks Samba Member
Joined: November 28, 2004 Posts: 7045 Location: Lawrenceville, Ga
Posted: Tue May 13, 2014 6:54 am Post subject: |
while the engine is out, check your clutch cable, install an alternator, and a bus muffler.
find out what kind of flywheel and starter you have, just in case you ever need to buy a replacement, never easier than now _________________ regards
Uli
Posted: Tue May 13, 2014 7:59 am Post subject: |
mandraks wrote: |
find out what kind of flywheel and starter you have, just in case you ever need to buy a replacement, never easier than now |
Definitely. Going to install new alt , starter, etc.
what exhaust do you recommend? I believe a single quiet pack exhaust will fit, right? |
NoBudgetVWGarage Samba Member
Joined: November 27, 2008 Posts: 755 Location: Quartz Hill,CA
Posted: Tue May 20, 2014 10:08 am Post subject: |
I know you got some windows.. lemme see!
and a BUMP just to keep your butt motivated _________________ 1969 Transporter
1968 Ghia
1959 Ghia Hot VW Drag Car |
Adam Samba Member
Joined: November 08, 2009 Posts: 624 Location: Petaluma, Ca
Posted: Wed May 21, 2014 11:53 am Post subject: |
zackcowie wrote: |
what exhaust do you recommend? |
Stock |
RPGreg2600 Samba Member
Joined: November 07, 2010 Posts: 1657 Location: Vallejo, CA
Posted: Wed May 21, 2014 12:10 pm Post subject: |
Muffler is easy enough to change with the engine installed. |
Posted: Thu May 22, 2014 10:54 am Post subject: |
I almost got those windows! A guy was 10 minutes ahead of me! All five windows working for 150. I can't believe I missed out on that, I was so frustrated. But I found an interior for 250! Pretty complete too. I have all the hardware and white trim. Here's some pics, I just kind threw it in. It's not fully assembled yet. Also, I picked up a kadron dual quiet pack to run on my bus for now.
Anyone know what this interior is out of? 64-67 westy? I have
I got the guy down to 250 for all of it. Also still waiting for the three Hehr windows I ordered |
Posted: Wed May 28, 2014 9:57 pm Post subject: |
Thanks to my buddy from work, I now have a
Pair if headlights that Were generously donated towards the cause
CaLiBus Samba Member
Posted: Thu May 29, 2014 8:16 am Post subject: |
Love how that Nose turned out! Good job! |
