Opossum Samba Member
Joined: February 26, 2005 Posts: 735 Location: Islets of Langerhans
Posted: Tue Feb 14, 2012 4:42 pm Post subject: |
jtauxe wrote: |
Desertbusman wrote: |
How can I convert a PDF to JPG to use one of my picture editors? I need to make a low light out of it, change the colors and do some other mods. |
bignick wrote: |
go to the link, click on Fahrzeuge and then go to PKW in the sub category. It will show you the thumbnails, which you click on and they pop up. When they pop up, there is a PDF image in the bottom left corner. Click it and its the full sized piece |
Then, since it is in PDF format, the only way to make it a raster image like jpg is to show the PDF image on your screen as large as possible, and make a screen capture.
Well, there is another way: Print the PDF, and scan the print. that will actually be higher res, I guess. |
Or open it in Adobe Acrobat or Photoshop and do a "save as" and change the file type to a .jpg (under "format" for Photoshop or "save as type" for Acrobat). _________________ "You can lead an aircooled to water, but you can't make it drink"
"Live and learn or crash and burn"
"It's only Cool, If it's Air-Cooled"
Virginia Whiteface (Opossum) the first VW
Camper Special Club Member
1973 Orange Westfalia Hard top, Original owner |
Sssingo Samba Member
notchboy Samba Member
Joined: April 27, 2002 Posts: 22463 Location: Escondido CA
jtauxe Samba Member
Joined: September 30, 2004 Posts: 5780 Location: Los Alamos, New Mexico
Posted: Tue Mar 04, 2014 12:37 pm Post subject: |
notchboy wrote: |
Im still working on getting my recent find remade so I can sleep easy knowing I didnt use the last one. |
Don't you ever build that original! That must be kept for posterity.
But please do scan it in as high resolution as you can. _________________ John
http://vw.tauxe.net
1979 Champagne Sunroof, 1974 Westfalia Automatic, 1979 Transporter, 1972 Sportsmobile, 1973 Transporter Wild Westerner, 1974 Westfalia parts bus, 1975 Mexican single cab *FOR SALE*, 1978 Irish 4-door double cab RHD
Posted: Tue Mar 04, 2014 4:35 pm Post subject: |
Im never going to build it. If it needs to be sacrificed by popping it open to make more then maybe. Other than that it will get put in a frame and hung
Scanning has proved more difficult. I have the largest flat bed scanner (mainstream office shit) at work that others in the area have. Most large stuff gets run through a roller type scanner that Im unsure if I should put this trough without messing it up. So unless someone has an idea on where I can use a large - 11.5x23 flat bed scanner minimum. - Im still looking. _________________
t3kg wrote: |
Jason "notchboy" Weigel
1964 1500 S
1964 T34 S Convertible
Desertbusman Samba Member
Posted: Tue Mar 04, 2014 4:44 pm Post subject: |
Is there a local Kinkos? And no major problem by scanning it in two halves. The file pics can be joined/spliced. Or at least a good quality hi res. scan for each component of it. That's no concern since the parts will get cut out anyway. _________________ 71 Superbug
71 Westy |
Posted: Tue Mar 04, 2014 8:11 pm Post subject: |
Is there a local Kinkos? And no major problem by scanning it in two halves. The file pics can be joined/spliced. Or at least a good quality hi res. scan for each component of it. That's no concern since the parts will get cut out anyway. |
This is most likley what Ill do. I ran a quick scan like this at work (same size scanner that they have) but it was a pdf I forgot to change it to a tif or jpg. So once I do that Ill have it.
Then well see who I share it with........................... _________________
t3kg wrote: |
1964 1500 S
Jim Bear Samba Member
Joined: March 25, 2006 Posts: 670 Location: Watkinsville, GA
Posted: Wed Mar 05, 2014 12:13 pm Post subject: Geeks... |
GEEKS!!!!!! _________________ "You're either on the bus, or you're off the bus." ~kk
'85 Vanagon Westy - George In the Stable 2020-?/'74 Weekender - Ophelia In the Stable 2007- ?/'69 Beetle Convertible - SOLD 2017-2020/'67 Beetle - September SOLD 2013-2016 /'67 SO42 Westy - Sage SOLD 1996-2001 /'69 Transporter - Baby Blue SOLD 1995-1995/'72 Westy - Nelly - SOLD 1990-1995--STOP FRACKING |
brandt Samba Member
Posted: Tue May 13, 2014 9:07 pm Post subject: |
A few of these images recently appeared in another thread. Seemed like they could go here, too.
From Notchboy's 6000 photos.
Neat dealer cardboard cutouts!
Rubber Duck Samba Member
Joined: January 18, 2006 Posts: 806 Location: Pitt Meadows BC
Posted: Wed May 14, 2014 2:26 pm Post subject: |
These are neat! Its a pity the pdf isn't vector. I work in a large format tradeshow display company, I could print these on pretty good sized paper, card...whatever. Would be cool!
Plus...it would be easier to change the colour to orange _________________ ---------
Rubber Duck
1974 Westfalia |
Posted: Mon Dec 29, 2014 11:19 am Post subject: Paper cars |
You guys still messing around with trying to print or download?
Should of gone to www.cutout-n-keep.com |
