Alpine gears
crowlejo
crowlejo is offline
PostPosted: Fri May 16, 2014 1:40 pm    Post subject: Alpine gears Reply with quote
Does anyone know where to find alpine gears? I've been searching classifieds for a long time and cannot find them anywhere. I recently posted an ad, and nothing...Is there somebody out there that reproduces them?
Lionhart94010
Lionhart94010 is offline
PostPosted: Fri May 16, 2014 2:24 pm    Post subject: Reply with quote
If you want to find something that rare; IMO you would have to look in places they were sold more often, I have seen T2 mountain tranys in Split and Bays on e-bay Europe, but most often they were still in the bus ;0)
www.ebay.ch (eBay Switzerland)
www.ebay.de (eBay Germany)
FYI I have bought some rare items directly from eBay, Germany, England, Greece etc… biggest problem is sending money if they do not take PayPal and the shipping cost…
Current VWs 71 T2 Westy SO-72/6(Miami), 71 Crew Cab, 2015 GSW TDI
Other owned VW’s 59, 68 1500s, 69 & 71 Bug’s; 72 & 73 S-Bug’s; 67 Westy, 67 Deluxe, Other 71 DC, 72 KG GT that now lives in Australia, 12 JSW TDI, 2015 GSW TDI, 2023 Tiguan
VW technical information sights
thesamba - www.ratwell.com - www.shoptalkforums.com/ - www.vw-resource.com - http://www.type2.com/
http://bobhooversblog.blogspot.com/ - www.aircooled.net/gnrlsite/resource/articles.htm
Stocknazi
Stocknazi is offline
PostPosted: Fri May 16, 2014 6:36 pm    Post subject: Reply with quote
Why are you wanting mountain gears in FL?
Not trying to be a smartass, just curious.
WANTED:
"Resistance to tyrants is obedience to God."
Thomas Jefferson
busdaddy
busdaddy is offline
PostPosted: Fri May 16, 2014 8:16 pm    Post subject: Reply with quote
X2, most for some reason want to go the other way Confused
Слава Україні!
crowlejo
crowlejo is offline
PostPosted: Fri May 16, 2014 9:23 pm    Post subject: Reply with quote
I have a place in West Arkansas that I have one of my busses at. It gets really crappy driving around in the mountains. I had alpine gears in a previous bus that could handle the terrain a lot better. I didn't realize what I was giving up when I sold it.
mandraks
mandraks is offline
PostPosted: Sat May 17, 2014 11:08 am    Post subject: Reply with quote
search for schweizer armee bus, berg getriebe, there were a ton of those, and everybody who bought one, installed a regular tranny and RGBs for use on the autobahn. there has to be a ton of those
regards
Uli
Eric&Barb
Eric&Barb is offline
PostPosted: Sat May 17, 2014 12:17 pm    Post subject: Reply with quote
Have you tried directly contacting transaxle rebuild shops???
In Stereo, Where Available!
Lionhart94010
PostPosted: Sat May 17, 2014 3:40 pm    Post subject: Reply with quote
If ground clearance is not an issue; perhaps you could find the shortest sidewall for a 14” rim, most tier specs have their circumference… and get some gearing reduction that way… probably not too hard to calculated the max possible reduction using tiers and compare to Alpine Trany…
55samba
55samba is offline
PostPosted: Sat May 17, 2014 4:30 pm    Post subject: Reply with quote
Another thought is a 4.86 or 5.14 ring and pinion. But as someone above said, I would call Rancho and some other trans builders to see if they have any core mountain ratio reduction boxes. Most people wont want them so you might get lucky.
crowlejo
crowlejo is offline
PostPosted: Sat May 17, 2014 9:08 pm    Post subject: Reply with quote
Yeah I already talked to Rancho. This post was kind of a last ditch effort. I don't know much about transmissions. I've rebuilt reduction boxes though and I figured that this would be the easiest way. I'll just keep searching I guess. Thanks!
