Scavenger Samba Member
Posted: Sat May 17, 2014 8:02 pm Post subject: D.I.Y. tools |
I'm sure that at some point most of us here have made or modified a tool of some sort. I mostly just do it for the enjoyment and satisfaction of using something homemade or repurposed. Some may be from necessity or time restraints or for whatever reason. Thought I'd share a few of mine and hopefully others will do the same.
Rod bolt stretch gauge
Pushrod cutter
Flexplate hub for mockup
bugguy1967 Samba Member
Joined: January 16, 2008 Posts: 4341 Location: Los Angeles, CA 90016
Posted: Sat May 17, 2014 8:12 pm Post subject: |
This is going to be a good topic.
Clutch breakaway tool to see at what FT. LB. the clutch is slipping. I use it on a dial torque wrench.
esde Samba Member
Joined: October 20, 2007 Posts: 5966 Location: central rust belt
Posted: Sat May 17, 2014 8:23 pm Post subject: |
valve spring compressor
stretch gauge, didn't work as well as I had hoped
adapter to use a torque tool with a 1.5" gland nut
In the end I found that using a main bearing pin to space the end of the rod bolt out of the cap let me get a better measurement.
I love making stuff myself |
AlteWagen Troll
Glenn Mr. 010
Joined: December 25, 2001 Posts: 76902 Location: Sneaking up behind you
raul arrese Samba Member
Joined: July 23, 2006 Posts: 1329 Location: miami florida
Posted: Sun May 18, 2014 11:29 am Post subject: |
Hinge tool |
andy198712 Samba Member
Joined: December 05, 2010 Posts: 1209 Location: Cornwall - UK
Posted: Sun May 18, 2014 12:17 pm Post subject: |
Glenn wrote: |
Torque multiplier
Where did you get the spline bit from? Nice ! _________________
Alstrup wrote: |
I like 5,5inchers in the rear at least. |
grey60 Samba Member
Posted: Sun May 18, 2014 12:32 pm Post subject: |
bugguy1967 wrote: |
This is going to be a good topic. |
Which is what I thought when I bookmarked it over in the Bay forum:
http://www.thesamba.com/vw/forum/viewtopic.php?t=531899
Now will someone please put aside your 'Trade Secret' ideas and post dimensional drawings of the tool you use to separate kingpins on spindles that are already flipped? _________________ 1960 grey panel |
wompninja Samba Member
Joined: July 06, 2008 Posts: 2147 Location: Salt Lake City
Posted: Sun May 18, 2014 6:11 pm Post subject: |
esde wrote: |
Don't give up on this one. You have a nice rigid frame there. Just need to do a little fine tuning. There is a small dimple on each end of the bolt that you need to seat into for it to work correctly. You might be getting some flex on the adjustable end. If not, check the tip on that side. It needs to fit and seat into the dimple. BTW I use mine with the dial end at the head of the bolt.
Hope this helps. |
Posted: Sun May 18, 2014 6:24 pm Post subject: |
raul arrese wrote: |
Hinge tool |
If you have never tried to remove an old hinge pin then you can't really understand just how truly awesome this tool is. Well done! |
Posted: Sun May 18, 2014 6:28 pm Post subject: |
Flywheel puller
clonebug Samba Member
Joined: January 29, 2005 Posts: 4027 Location: NW Washington
Posted: Sun May 18, 2014 8:41 pm Post subject: |
My home made tubing notcher.
the fish eye cut it made...
Fits nice without any grinding....
I've made three intakes with it so far and it does the job. _________________
vwracerdave wrote: |
Take a good long look in the mirror and report back on what you see. |
Paul.H wrote: |
That one line on that chart is probably better info than you can get from this place in a month |
Water/Alcohol Injection
Audi TT intercooler
Upgraded to MS3Pro-Evo
EcuMaster PMU16
ECUMaster ADU5 Digital Dash
http://www.shoptalkforums.com/viewtopic.php?f=3&t=127936 |
stealth67vw Samba Member
Joined: January 22, 2004 Posts: 1852 Location: Grass Pants, Orygun
Posted: Sun May 18, 2014 8:43 pm Post subject: |
My favorite site for homebrewed tools.
http://www.homemadetools.net/ _________________ John Bates
JB Machining Services
1967 street Bug 2276 w/ 48 IDAs, 2020lbs with driver
7.76 @ 89.55mph 1/8 mile
12.34 and 108.10 mph 1/4 mile |
earthquake Samba Member
Joined: January 10, 2008 Posts: 3984 Location: SANDY VALLEY, NEVADA
Posted: Sun May 18, 2014 10:59 pm Post subject: |
I built my own engine stand...
Adapter to mount VW engine on std stand...
English wheel...
modified HF bead roller...
quick release steering wheel adapter [somebody borrowed my idea and is selling them now]...
I have a test stand I have been working for awhile...
I have some more but no pictures of them. I made most of them while I was working for a metal shop running a water jet machine but they closed the doors and I am disabled now and I can barely get out of bed in the morning.
Casey _________________ 74 CLASS 11 LOOK-A-LIKE
69 DUNE BUGGY
79 INTERNATIONAL SCOUT II
05 SCION XB SERIES RELEASE 2[#437]
95 Chevy C3500 dually
98 Ford E150
Link to Kelly J. Nolte 3/20/53 - 11/6/08
https://time-zonelabs.blogspot.com/p/about-kelly.html
DEATH TO CHINGERS!
[From a military recruitment poster in the novel "The Stainless Steel Rat" By Harry Harrison] |
Mick Mick-n-chips
Joined: April 12, 2003 Posts: 415 Location: RADelaide
Posted: Mon May 19, 2014 4:30 am Post subject: |
Great thread, a topic close to my heart.
I'm always building tools to do different jobs. For me this is half of the fun of restoration and the thing I get the biggest kick out of. Recently I've been getting into panel work, here's a few things I've made up in the past month or so.
Simple but necessary - spot weld drills made from normal twist drills - saves a fortune
A panel chisel for cutting and separating panels after drilling out the welds - just a heat treated bit of flat bar - heaps better then a big clumsy cold chisel.
Heat it up cherry
Quench it in oil (yeah I know - it should be clean oil but who wants to waste good oil on stuff like this)
Don't forget to hone the edge!
Tucking forks for shrinking metal.
Flange bending tool - an absolute necessity. I used to use an adjustable wrench but this is heaps better
(you also use it with a hammer to make a nice sharp edge)
Old hubs and wheels make a great tinmans stake stand - much better than mounting the stakes in a bench holder or in your vice as you can work at a nice comfortable height and easily move the panel around it.
it also makes a great stand for my bead roller - I cut the bottom off of an old stake I had spare. At some point I will also get around to making up some similar stands for my sand bags.
And now with an added hammer holder
There's heaps of other stuff that I don't have good photos for - slapping files, anvil stands, a jacking beam setup in my pit, a 3d printer. Will post some up if I can dig them out.
By far my favourite DIY tool is my CNC plasma cutter - designed and built by me mostly from scrap I had laying about the workshop.
The great thing about this is that it is now even easier to make other tools up. _________________ https://joeblow.me
Joe Blow Superchargers |
mark tucker Samba Member
Posted: Mon May 19, 2014 9:02 am Post subject: |
earthquake wrote: |
English wheel...
Casey |
I worked in a small prototype shop for a shortwhile learning to program&run cnc mills&other stuff.did mostly aerosapce&detroit car stuff,and some off the wall stuff along with tool&die.I wish I still had all that equip at my fingers.you can make just about any thing.the 3D programing was sweet.I miss realy using my brains for stuff like that.I never did get my own cnc machine hear at home like I had planed.that was the whole reason I went to work there for little over a year. shit happens.as does life....and now??? these darn lawn mowder powered cars in my way. |
esde Samba Member
Posted: Mon May 19, 2014 10:10 am Post subject: |
Mick wrote: |
you win
Posted: Tue May 20, 2014 4:20 am Post subject: |
esde wrote: |
Mick wrote: |
By far my favourite DIY tool is my CNC plasma cutter - designed and built by me mostly from scrap I had laying about the workshop. |
you win
Darnit, asked the Wife and was told that I couldn't have one. [hands in pockets, kicks rock]
Very cool! |
Posted: Tue May 20, 2014 4:39 am Post subject: |
andy198712 wrote: |
Glenn wrote: |
Torque multiplier |
Where did you get the spline bit from? Nice ! |
Starter gear? |
