128vw Samba Member
Joined: April 05, 2006 Posts: 222 Location: Western Massachusetts
Posted: Sun May 25, 2014 7:15 am Post subject: rod small end oil hole |
I just got my rods back from the machine shop. They replaced the small
end bushings reamed the big end and straightened them. The question is they drilled 2 of the oil holes in the small end and not the 3rd. They
did not drill the holes that would be facing up in the engine. Is this
correct? This is a 1600 single port with Scat 69mm
counter weight crank and 88 pistons,W100 cam and mild home porting. _________________ 56 Jungle green restored w/orig interior
65 Ruby red w/ 1600 single port
building 66vert on 69pan w/ 2332 |
Lo Cash John Samba Member
Joined: February 06, 2004 Posts: 2246 Location: Jacksonville, FL
Posted: Sun May 25, 2014 8:08 am Post subject: |
Take 'me back and ask them to please drill the holes and ream to size again. _________________ www.LoCashRacing.org
More brains than bucks...Believe it or not!!
If you actually drive your VW, you need www.AirMapp.com
My boss told me I need to work on my mutli-tasking. So now when I use the bathroom at work I surf The Samba on my iPhone. |
modok Samba Member
Joined: October 30, 2009 Posts: 26741 Location: Colorado Springs
Posted: Sun May 25, 2014 12:11 pm Post subject: |
Two oil holes is just fine. They probably think that is a better idea and I don't know, but I'm pretty sure it doesn't matter enough to worry about.
By "up" I think you mean "out".
There aren't any reamers involved |
128vw Samba Member
Posted: Mon May 26, 2014 6:31 am Post subject: |
By up I mean that when the rods are installed on the crank, the holes that face up are not drilled. _________________ 56 Jungle green restored w/orig interior
modok Samba Member
Posted: Mon May 26, 2014 10:49 pm Post subject: |
that's weird
What direction did they put the seam of the bushings? |
