68-73 Sliding Door+Directions+Operating+Operation+Using
Tcash
Tcash is offline
PostPosted: Mon Jun 02, 2014 1:05 pm    Post subject: 68-73 Sliding Door+Directions+Operating+Operation+Using Reply with quote
To link to this thread
Code:
[url=http://www.thesamba.com/vw/forum/viewtopic.php?t=596631&start=0&postdays=0&postorder=asc&highlight=]68-73 Sliding Door+Directions+Operating+Operation+Using[/url]
The Early Sliding Door
To open the door from the outside.
Push the outer handle downward. Slide the door rearward until it catches. When fully open it is held in position by a hook.
To close the door from the outside.
Push the outer handle downward (which releases the hook) and slide the door forward until it latches.
Then pull the handle up firmly, until the sliding door is flush with the rear panel.
Make sure that the sliding door is fully closed while the vehicle is moving.
To open the door from the inside.
Push inner handle forward (–A-). Slide the door rearward until it catches. When fully open it is held in position by a hook.
To close the door from the inside.
Push inner handle forward (–A-) (which releases the hook) and slide the door forward until it latches.
Then pull inner handle backward (–B-) until the door is fully latched.
Unlocking and Locking the door from the outside.
The door can be unlocked and locked with the key.
To unlock insert the key and turn to the left (counter clockwise) 180 degrees, half a turn.
To lock insert the key and turn to the right (clockwise) 180 degrees, half a turn.
(Note) the locks will only operate with the key installed in one of the two possible positions. ( if the key will not turn take it out and turn it 180 degrees, half a turn and reinsert it)
Locking and Unlocking door from the inside.
To lock push the small lever to the position (-C-)(note: door will not lock from the inside until you, pull inner handle backward (–B-) until the door is fully latched).
To unlock push the small lever to the opposite position of (-C-).
VDubTech
VDubTech is offline
PostPosted: Mon Jun 02, 2014 2:23 pm    Post subject: Reply with quote
A how to on how to open and close doors? Is this what it's come to?
First Trip in the RustyBus:
http://www.thesamba.com/vw/forum/viewtopic.php?t=279077&highlight=
borninabus wrote:
a measurement of your rod would be extremely useful.
notchboy wrote:
my dad wasnt a belittling cock when he tought me how to wrench on cars.
One photo = good for reference.
10 photos = douchebaggery
pickledBus
pickledBus is offline
PostPosted: Mon Jun 02, 2014 2:36 pm    Post subject: Reply with quote
deleted
vwwestyman
vwwestyman is offline
PostPosted: Mon Jun 02, 2014 9:43 pm    Post subject: Reply with quote
To be fair, I just bought a '73, and I knew the door handle was a little different than my '78. The bus is still in Seattle (I live in Kansas) but the seller mailed me the owner's manual along with other info on the bus.
The whole setup is rather counter intuitive (IE, essentially pull the handle back to latch it forwards), and I've determined that once I finally get the bus, I'm going to have to take some time to teach my kids how to properly work the thing!
Dave Cook
1973 Wild Westerner
My Thing
airschooled
Air-Schooled
airschooled is offline
PostPosted: Mon Jun 02, 2014 10:17 pm    Post subject: Reply with quote
It seems like there's at least one post a weeks about some early bay owner learning about fully closing the slider on the bus they've had for 20 years.
Learn how your vintage VW works. And why it doesn't!
www.airschooled.com
Desertbusman
Desertbusman is offline
PostPosted: Mon Jun 02, 2014 11:01 pm    Post subject: Reply with quote
Thanks Tcash for starting this thread. Driving the bus for 17 years and never closed the slider the way you mentioned. Embarassed Embarassed It's not my fault the owners manual didn't make sence. Laughing Laughing
I roll the door all the way forward and then a gentle push inward at the rear with my hands palm closes and latches it. So if I ever paint it then evidently there is a way to avoid finger prints on the door.
So why is there a big long depression in the door above the latch and just a little one below? I tried once to move the handle upward CW and it didn't move. So swinging the handle down CCW is the only way it ever gets done.
And the handle on the inside works backwards from the way it would be the most handy and usable.
71 Superbug
71 Westy
karlonwheels
karlonwheels is offline
PostPosted: Tue Jun 03, 2014 7:41 am    Post subject: Reply with quote
I was glad to see this: never would have known. So I guess that owner's manual is for reading, huh? Might take a look, next week.
TomWesty
TomWesty is offline
PostPosted: Tue Jun 03, 2014 8:08 am    Post subject: Reply with quote
Imagine this scenario. Someone in the back of the bus (a child perhaps) grabs the inner door handle just as you accelerate. The force of your acceleration causes them to pull the door handle and open it. The door is now open while you are moving. The sticker on your steering system tells you in Deutsch not to drive with the sliding door open. Trust the German engineers DB...... Very Happy Wink
Greg in GA
Greg in GA is offline
PostPosted: Tue Jun 03, 2014 11:44 am    Post subject: Reply with quote
I wonder if they changed the design on the later bays? Mine opens when the inside handle is pulled back (CCW) and can be locked when the handle is pushed forward (CW)
1969 Beetle
1974 Westy 1800cc FI conversion, L62H
Need a really good mechanic for your VW bus? Consider making an appointment with Colin (Amskeptic) next time he passes thru your area.
busdaddy
busdaddy is offline
PostPosted: Tue Jun 03, 2014 12:40 pm    Post subject: Reply with quote
Yes, 74+ opens like you would expect a door on an American van to open, I guess they were going after a wider customer base who couldn't figure it out.
Слава Україні!
aeromech
aeromech is offline
PostPosted: Tue Jun 03, 2014 2:14 pm    Post subject: Reply with quote
You must have missed the thread from the other day where this topic began. Hence, the instructive TCash thread.
Airbus A319,320,321
DC9/MD80
BAe146
Fokker F28/F100
VW type 1 1962,63,65,69,72
VW Jetta
VW Passat
VDubTech
VDubTech is offline
PostPosted: Tue Jun 03, 2014 7:13 pm    Post subject: Reply with quote
No I saw it, I just didn't realize we had some many people here that didn't know how to properly operate an Early Bay Slider.
Tom Powell
Tom Powell is offline
PostPosted: Tue Jun 03, 2014 8:10 pm    Post subject: Reply with quote
Caveat
sliding door assist strap
Rear hinge release
Aloha
tp
Desertbusman
PostPosted: Tue Jun 03, 2014 8:20 pm    Post subject: Reply with quote
Not everyone has the simple design and different proceedure like you do.
1. Remove padlock from gate latch.
2. Swing door open on it hinges.
3. On a windy day secure it open with a bungee so it won't slam shut.
You must have a different hiding place other than the Samba gallery for your pictures. But we know you replaced the slider with a swinger Laughing
71 Superbug
71 Westy
chabanais
chabanais is offline
PostPosted: Tue Jun 03, 2014 8:49 pm    Post subject: Reply with quote
Clearly there are a lot of morons out there.
"I spud therefore I yam."
aeromech
aeromech is offline
PostPosted: Wed Jun 04, 2014 6:15 am    Post subject: Reply with quote
I've instructed several new bus owner on how it works. Can't think of any other van type vehicle that operates the same way and like has been said it's not very intuitive.
Airbus A319,320,321
DC9/MD80
BAe146
Fokker F28/F100
VW Jetta
VW Passat
karlonwheels
PostPosted: Wed Jun 04, 2014 1:17 pm    Post subject: Reply with quote
I have an ex girlfriend or two who would back you up on that 100%.
chabanais
PostPosted: Wed Jun 04, 2014 4:48 pm    Post subject: Reply with quote
Hmmm.
But, in case of what I wrote, it was in reference to myself.
busdaddy
busdaddy is offline
PostPosted: Wed Jun 04, 2014 6:33 pm    Post subject: Reply with quote
The door on my 1984 F'nDodge van works exactly the same and for the first 10 years we had it we were pushing in on the back if it didn't fully latch too Surprised , the only difference is the internal handle is mounted facing up and further back from the end of the door so it's natural for most passengers to pull it back to open it. None of that helps at all in the F'nDodge or the bus with most modern teenaged kids, they are completely perplexed by a door you have to turn something on to open or latch thanks to the self opening/closing power sliders in modern minivans.
Both the bus and the F'nDodge door will close fully with no handle twisting if a window is down and you give it a good slam, windows all up means you'll be twisting the handle up.
Слава Україні!
skills@eurocarsplus
Samba Peckerhead
PostPosted: Wed Jun 04, 2014 8:11 pm    Post subject: Reply with quote
busdaddy wrote:
the F'nDodge....
i would have never guess you a dodge guy. i have to admit, a little piece of me died inside due to this admission Crying or Very sad
gprudenciop wrote:
[email protected] wrote:
Jake Raby wrote:
Brian wrote:
