danfromsyr Samba Member
Posted: Fri Jun 13, 2014 5:50 am Post subject: |
my new hell is adjusting the shifter in my 1980
WTF does it have such bulky pinch clamp in a tight space when the adjustment from good to no good is less than 1/16" ALOT less.
Ohh and that's the same spot you adjust the length (in-out) as well. so as you futz with one adjustment you bugger the other
grrrrrrrrrrrrrrrr. _________________
Abscate wrote: |
DAIZEE Samba Member
Joined: January 26, 2010 Posts: 7552 Location: Greater Toronto Area Ontario West Side
Posted: Fri Jun 13, 2014 1:54 pm Post subject: |
oil change and complete check over in prep for an extended road trip. _________________ '09 2.5L Jetta 5 cylinder, 5 spd, super turbo, see thread in H2O Cooled Jetta, etc...
84 Vanagon GL Wolfsburg Westy WBX 4 speed (sold) |
nevadaesh Samba Member
Posted: Fri Jun 13, 2014 6:24 pm Post subject: |
Put on the bike rack for the first time and then the Trasharoo. Getting ready for a (hopefully) 3 month trip north into Canada, east to Calgary, back into the US, upper New York state and then on to the Maritime provinces - Nova Scotia, then home.
_________________ '85 Westy
'07 FJC
'02 Camry |
euro911 Samba Member
Joined: May 20, 2007 Posts: 162 Location: So. Cal, So. Bay
Posted: Fri Jun 13, 2014 7:29 pm Post subject: Re: Emblems |
euro911 wrote: |
ClarksuperVan wrote: |
euro911 wrote: |
Looks great. Did you spray the badges with silver paint? |
Thanks. First I cleaned them really well. Then sanded a bit to remove the old stuff. Then used a Krylon Silver Leafing pen to do all the letters. Finished them off with some rattle can sealant I had in the garage. They turned out pretty decent I think.
Jeremy |
Well, your post gave me some inspiration, so after dinner I scrubbed and masked-off one badge. It was a bit of work - tedious work for old eyes and hands I might add.
I'll spray it tomorrow with the metallic silver paint I used on my CLK wheels and see how it turns out. |
Didn't turn out as nice as yours Jeremy, but it is a big improvement
This was a 'spare' emblem, so maybe I try your method on the other emblems _________________ Mark S.,
So. Cal, So. Bay
'70 Karmann Ghia Coupe
'84 Vanagon Westfalia Camper ("Eileen") |
lemonspeed Samba Member
Posted: Sat Jun 14, 2014 8:38 am Post subject: |
I had these 8ply Beauties Installed : Love my Carat Alloys on the Van so staying 14" for now.....
_________________ Instagram : @overland_van
90 Vanagon Carat "domino"
81 Westfalia (sold) "clemintine"
73 Transporter (sold) "chloe"
80 Vanagon (sold) "brownie" |
Colorado Yeti Samba Member
Joined: August 25, 2013 Posts: 356 Location: Ft. Collins, Colorado
Posted: Sun Jun 15, 2014 7:51 pm Post subject: |
My wife took the kids down to Texas for the weekend to visit family. She said, "Why don't you have a nice relaxing weekend and catch up on some projects". (That is my of perfect idea of relaxing, as I do not sit still for long periods very well) Although I missed my family on Father's day, I took 3 full days and got Chewey ready for the roadtrip to the PNW this summer. Her's what I did:
- Completely rebuilt the front suspension (Wow, what a difference!)
- Painted everything on the front end with POR 15 and painted the wheelwells (not bad for Rustoleum rattle can)
- Replaced the fuel tank, filter, pump & hoses. Dropped the new gas tank on my face trying to install it resulting in a very nice laceration but managed to avoid the ER. Resealed the expansion tanks too. Holy crow, my engine was barely running because it had about 1" of crap in the sump of the gas tank. I can't believe how much better it runs. I think I gained 30 horsepower!
- Installed a new radiator. I wasn't sure I needed to do that one since it wasn't overheating, but Rocky Mountain Westy's recommended that I do it. Sure enough, they were right. It was leaking and weighed about 20 extra pounds due to all of the crud in it.
Now there's that pesky little throwout bearing that keeps making noise.......
AMT Samba Member
Posted: Sun Jun 15, 2014 9:10 pm Post subject: |
New-to-me-van kind of stuff:
Repaired the two windshield visor mounting brackets. They had been wrenched free over the years. Once of the brackets is totally cracked and will need to be replaced. Surprised to see the passenger visor mirror still lights up.
Installed the inner visor clip correctly. Looked like it came from the factory installed improperly, with the small pointed clip on the back torqued against the headliner instead of clipped into the shelf on the frame that is just forward of the mounting screw hole. A small hole needed to be cut in the headliner to mount it in the hole and sit flush.
Changed a headlight bulb. The passenger-side hi-beam glass housing is cracked and will need to be replaced. In removing the grill I was surprised at how flimsy the connecting pins are and how lightly the grill is held on. Is there an aftermarket solution for that?
Freed up a sticky automatic driver side mirror. The motor inside is doing its best, but it's on its last legs. Can I replace the motor or should I just replace the whole thing? Were they always just crap?
Discovered that front windshield spray pump is not working. Will troubleshoot tomorrow during daylight. Rear window pump operates normally. Loud as hell too.
Learned how to use the Bentley through completing the above tasks. _________________ 89 Syncro GL 2.1L WBX
Instagram |
a2d2 Samba Member
Joined: March 28, 2013 Posts: 366 Location: EastVanagon, BC
Posted: Mon Jun 16, 2014 12:07 am Post subject: |
Colorado Yeti wrote: |
Nice work, so envious of this. My steering is super sloppy so I'm planning on at least the steering rack/tie rods but dreaming of tackling the whole thing just like that.
All I got done today was rear hatch stuff: Installed the snaps for the bug screen, bought a turnbuckle to hold it open, and installed an interior release/handle.
_________________ 1981 Vanagon, Aircooled 2.0 AFC
1978 Baywindow Bus (R.I.P.) |
oldhuldy67 Samba Member
Joined: November 25, 2008 Posts: 506 Location: somewhere with a southern exposure
Posted: Mon Jun 16, 2014 5:25 am Post subject: Interior release |
Please tell us more about the interior release ...pics?. I have always thought it was needed, for safety and convince to improve the function of the rear hatch. I'm sure to want to do this...thanks, John in GA
1980 Westy...aka "the 0'possum" |
Mountain1.8t Samba Member
Posted: Mon Jun 16, 2014 6:30 am Post subject: |
Installed new BRIGHT tail light bulbs from Tarry Kay. Huge improvement over stock. |
Steve M. Samba Member
Joined: July 30, 2013 Posts: 6832 Location: Fort Lauderdale, Fl.
Posted: Mon Jun 16, 2014 6:33 am Post subject: Re: Interior release |
oldhuldy67 wrote: |
I believe it is just a turnbuckle using an eyelet at the door end and a hook end on the body's locking pin.
You put the eyelet into the door latch and just push it in so the lock engages as it would when you close the door normally.
Then hook the body side into the locking pin.
Crawl inside and turn the turnbuckle to open/close the air vent size.
Sleep in peace!
Mind the raccoons! |
Posted: Mon Jun 16, 2014 7:09 am Post subject: |
Thanks...I was interested in installing a door latch for the hatch. Do I see a brown door latch in the corner of the door? Winston has a few pics but I can't get the gist of how it would all work. Guess I need to remove the cover and take a whack at it myself. That's how I usually figure things out. Any ideas will be gratefully received and much appreciated. John in GA |
dobryan Samba Member
Joined: March 24, 2006 Posts: 16503 Location: Brookeville, MD
a2d2 Samba Member
Posted: Tue Jun 17, 2014 12:45 am Post subject: Re: Interior release |
oldhuldy67 wrote: |
Please tell us more about the interior release ...pics? |
I forgot to take pictures of what I did inside before I put everything back together, If I get some time I will do it and add them to one of the existing threads.
I did use an extra door pull and basically came up with a simple variation inspired by the ones in a few threads I found, including the one dobryan posted.
That is some hard steel in there so be prepared. I wore out 3 expensive cobalt bits trying to drill the hole through the release lever before I gave up and found another way, hard to explain but when I get the pictures up it should make sense. _________________ 1981 Vanagon, Aircooled 2.0 AFC
wemfam Samba Member
Joined: July 15, 2012 Posts: 137 Location: Central Illinois
Posted: Tue Jun 17, 2014 2:41 pm Post subject: aux battery relay |
My auxiliary battery did not charge back up after our first camping trip with it...so I took the advice of friends and tossed a new relay in there without any troubleshooting.....we'll see how it does next time... |
HoustonPhotog Samba Member
Joined: February 20, 2013 Posts: 1514 Location: Houston, TX
Posted: Wed Jun 18, 2014 4:35 am Post subject: |
Looksgreat, I know the passenger brake light is visible, but ya got a third brake light mounted? |
joetiger Samba Member
Joined: January 27, 2005 Posts: 5078 Location: denver
Posted: Wed Jun 18, 2014 9:42 am Post subject: |
HoustonPhotog wrote: |
Yea I'm looking at various third brake lights. Trying to see what would work best and still look good. |
The GoWesty one works very well.
http://www.thesamba.com/vw/forum/viewtopic.php?t=535840&highlight=gowesty+brake+light _________________ Joe T.
'04 GTI 1.8T
'04 Golf R32
Available Now! Vanagon to Louisiana--A Two-Lane Reckoning Through Past and Present
www.josephtrussell.com |
Posted: Wed Jun 18, 2014 10:09 am Post subject: |
I bought a (pair) of these red COB led strip lights.
they are VERY red, very flush and shouldn't be hard to figure out how to mount them in the back,
you do have to wait a little, but shipping from China hasn't been bad with any of my purchases.
http://www.ebay.com/itm/400710155047
Abscate wrote: |
