Aaron Samba Luddite
Posted: Thu Feb 14, 2013 11:19 pm Post subject: |
I just bought the kit from Wagenswest, going to be installing it in my BD when I swap out the trans. I'll update with report on how the install goes and how it compares to the current one-off center mount I was running.
BTW. The new kits come with button head allen bolts for additional clearance. _________________ ____________________
low54 Samba Member
Joined: March 19, 2004 Posts: 424 Location: cotswolds-england
Posted: Fri Feb 15, 2013 1:12 am Post subject: |
Aaron wrote: |
BTW. The new kits come with button head allen bolts for additional clearance. |
Yes please I'm about to order one for my 54 as I have the csp solid mount in my Kombi and it is loud.
Cheers ben |
cdennisg Samba Member
Joined: November 02, 2004 Posts: 20278 Location: Sandpoint, ID
Posted: Sat Feb 16, 2013 10:40 am Post subject: |
Aaron wrote: |
I really liked your home built mount, Aaron. _________________ nothing |
Aaron Samba Luddite
Posted: Sat Feb 16, 2013 11:01 am Post subject: |
[quote="cdennisg"]
Aaron wrote: |
I really liked your home built mount, Aaron. |
It is a cool idea and sure seems solid. Problem is the shifting has been crap since that work was done. I've played with it a couple of times and can't get it sorted, I'm basically going to start from scratch. There are just too many factors right now: hockey stick, shift linkage, mount, ect.
You coming over to the West side in March for the camp-out. _________________ ____________________
Posted: Sat Feb 16, 2013 11:11 am Post subject: |
Planning to be there. I have a present for you, too. _________________ nothing |
KombiMadness Samba Member
Joined: December 09, 2011 Posts: 388 Location: Sunshine Coast, Australia
Posted: Wed Jun 25, 2014 9:08 pm Post subject: |
cdennisg wrote: |
thom wrote: |
Does the tab from the lower mount go into the urethane piece?
I'm not clear on the function of the 'hoop' that goes over the top; is it basically a big washer for the urethane bushing?
That lower tab that mounts to the nosecone is only half of a piece that is bent 90 degrees. the other half is cast into the urethane. The loop on top holds the urethane into the mount and hoops over the top of the shift rod part of the nosecone, just like an original setup. |
I just want to confirm something from people who have used Nate's Lollipop adapter - does the above Lollipop kit from Nate totally replace the ususal front tranny mount? I don't want to seem thick but I don't quite get it....
Does it replace this http://www.wolfsburgwest.com/cart/DetailsList.cfm?ID=211301265A _________________ My brother & I on the roof of Dad's Splitty circa 1967 - I'm the half pint with the skinny legs! |
swivel'n Samba Member
Joined: February 04, 2005 Posts: 275 Location: Tracy, Ca
Posted: Wed Jun 25, 2014 9:24 pm Post subject: |
Ya. It replaces it _________________ 1969 og paint Squareback
1968 automatic sunroof notchback
1959 Swivel seat kombi |
easy e Samba Member
Joined: May 28, 2008 Posts: 3931 Location: 1 hr north of Santa Barbara
oldvolkz Samba Member
Joined: September 28, 2005 Posts: 321 Location: Hollister, Califaztlan
Posted: Wed Jun 25, 2014 11:37 pm Post subject: |
KombiMadness wrote: |
cdennisg wrote: |
thom wrote: |
Does it replace this http://www.wolfsburgwest.com/cart/DetailsList.cfm?ID=211301265A |
can you use this on a bug?
Can you only use this lolipop mount or do you need to use a bus nose cone too.
thanks _________________ "if you want peace, you must work for justice"
Posted: Thu Jun 26, 2014 12:02 am Post subject: |
Thanks swivel'n and easy e
Concept1 Samba Member
Joined: September 07, 2004 Posts: 334 Location: Calgary, Canada
Posted: Mon Aug 25, 2014 3:47 pm Post subject: |
I know I'm the "competition"in the case, but...
Does the Wagens west adapter not just force the top of the nose come into the top of the original loop on the bus, making it metal on metal again?
The only polyurethane is on the bottom of the nosecone.
_________________ C-1 |
mightymouse Samba Member
Posted: Tue Aug 26, 2014 7:39 am Post subject: |
Ken that was my exact question. But i also then realized that the nosecone on reduction setup is always pushing DOWN, and the weight of the trans is likely to cause it to sag over time. So i figured it wouldnt make much noise while driving in my bus.
Now a straight axle setup... id think the nosecone would come up and go metal to metal causing some interesting vibes to be transmitted.
I have this mount and am gonna give it a try soon. Ill report when i do. If i dislike it im gonna put my OG trans back and a 36r. Just about completely vintage in my head now...lol. _________________ Nothing can stop the man with the right mental attitude from achieving his goal; nothing on earth can help the man with the wrong mental attitude.
Thomas Jefferson
Note to EVERYONE.
Know your ZDDP levels or you WILL lose a cam and lifters. |
sled Samba Member
Posted: Tue Aug 26, 2014 7:51 am Post subject: |
remember the nose cone itself is bolted to the flange that is molded into the "lollipop" and due to the semi-circular shape of the lollipop it can not move up or down or left or right within the original hole. Clearance the nose cone enough and it should not hit the original metal. I have used this mount and it worked flawlessly. I do wish the urethane was a bit softer, but what can ya do? _________________ drive your split. |
Posted: Tue Aug 26, 2014 8:55 am Post subject: |
sled wrote: |
remember the nose cone itself is bolted to the flange that is molded into the "lollipop" and due to the semi-circular shape of the lollipop it can not move up or down or left or right within the original hole. Clearance the nose cone enough and it should not hit the original metal. I have used this mount and it worked flawlessly. I do wish the urethane was a bit softer, but what can ya do? |
This is what I was thinking. The urethane/mount flange supports the nosecone, and it should be clearanced so that nothing makes metal-to-metal contact. _________________ nothing |
chrisflstf Samba Member
Joined: February 10, 2004 Posts: 3446 Location: San Diego
Posted: Tue Aug 26, 2014 9:11 am Post subject: |
Just use a good mid-mount, like a Berg to stop nose cone movement. The nose cone by itself isnt enough to offset the cantilever effects of the motor hanging off the trans |
Posted: Tue Aug 26, 2014 4:15 pm Post subject: |
Mine is now mounted with the Rancho tranny I bought (came with nosecone) and big nut axles/brakes. I have driven it about 300 miles in all conditions & speeds, bumpy roads and freeway driving at 65 mph......
I don't hear any excessive noise coming from the mount at all. Some people mentioned that a hard urethane mount on metal would be noisy. So far, this is not the case.
When I have more miles with this setup, I'll report back. _________________ My brother & I on the roof of Dad's Splitty circa 1967 - I'm the half pint with the skinny legs! |
jason Samba Member
Posted: Wed Aug 27, 2014 1:53 pm Post subject: |
Make your own, costs a few dollars. Make it like the ones used in a split beetle. I made mine and it uses a stock rubber mount which can be switched without removing trans. |
mr. warehouse Samba Member
Joined: February 27, 2001 Posts: 5001 Location: Nor Cal 707
Posted: Wed Aug 27, 2014 1:56 pm Post subject: |
jason wrote: |
Pictures / details? |
jason Samba Member
Posted: Wed Aug 27, 2014 4:47 pm Post subject: |
jason that mount is epic. You should make and sell those. Or sell cardboard templates of the pieces. Its very simple. I love it just want to see how far it hangs down in person.
Man thats cool.
Like a mount on stilts. The stanchion mount.
Thomas Jefferson
Note to EVERYONE.
