Critter1 Samba Member
Joined: August 04, 2004 Posts: 1575 Location: Sacramento
Posted: Thu Aug 02, 2007 8:07 am Post subject: Warning lights |
I had my gauges redone a while back by John Troia. I've installed them and my red light comes on with my high beams, and the blue light comes on with low oil pressure. They worked fine before.
My conclusion is that maybe when he reassembled the gauge, he switched the colored windows around.
Right now the colored windows are, from left to right: unk color/red/blue/green. What is the proper order of the colored windows? _________________ Justin |
COFBack Samba Member
Joined: July 05, 2005 Posts: 2148 Location: Colorado Springs
Posted: Thu Aug 02, 2007 9:23 am Post subject: |
Sure you don't have the wires on backards? _________________
iowegian wrote: |
Henceforth he shall be known as "Trameltoe".
Chickengeorge's wife wrote: |
bing chow ching fong fang T.J. fang ching dow fong |
KTPhil Samba Member
Joined: April 06, 2006 Posts: 33875 Location: Conejo Valley, CA
Posted: Thu Aug 02, 2007 9:29 am Post subject: |
Green parking lamps, blue high beams, red gen, red oil
The earlies do not have the symbols, but I think the order and colors are the same.
Posted: Thu Aug 02, 2007 9:31 am Post subject: |
COFBack wrote: |
Sure you don't have the wires on backards? |
I never took the bulbs out of the back part of the gauge. That part stayed in the car while the gauges were being redone. before I try to switch the bulbs, I want to know that the colored windows on the front of the gauge are in the right sequence.
I would also like to know what the fourth one is for. I know red=oil, blue=high beam, grn=generator (i think). Whats the other one for? _________________ Justin |
Posted: Thu Aug 02, 2007 9:36 am Post subject: |
KTPhil wrote: |
The earlies do not have the symbols, but I think the order and colres are the same. |
Yea, mine doesn't have the symbols (67). If the high beam is second from the left, then the red and blue windows must have been switched around when he reassembled the gauge. _________________ Justin |
KTPhil Samba Member
Posted: Thu Aug 02, 2007 9:40 am Post subject: |
"the red and blue windows must have been switched around when he reassembled the gauge."
Might send him a pic, along with this one, and ask if he might have made a mistake. |
Posted: Thu Aug 02, 2007 9:44 am Post subject: |
KTPhil wrote: |
Good idea, but his website is gone and presumably so is he... Its been two years since they were redone. I should have inspected them closer when he returned them.
You dont happen to have a close up pic of an early gauge do ya _________________ Justin |
Posted: Thu Aug 02, 2007 9:49 am Post subject: |
Here is a pic of the gauges. They were finished in February 2005.
You tell me if the warning lights look right
Mike Fisher Samba Member
Joined: January 30, 2006 Posts: 17962 Location: Eugene, OR
Posted: Thu Aug 02, 2007 9:53 am Post subject: |
Very nice! The silver or white background does make for cool gauges! |
KTPhil Samba Member
Posted: Thu Aug 02, 2007 9:57 am Post subject: |
Can't really tell from this pic (too dark in the light pieces). |
KTPhil Samba Member
Posted: Thu Aug 02, 2007 9:59 am Post subject: |
Pac51 Samba Member
Joined: February 28, 2007 Posts: 91 Location: Oregon City, OR.
Posted: Thu Aug 02, 2007 4:39 pm Post subject: |
Here's a pic of a '68 guage.
On the left is parking which is actually light green. Next is high beam, Blue. Generator is Red, and Oil is dark green.
Fuel sending unit is currently detached, hence guage level.
Nice job on those guages by the way.. |
Russ Wolfe Samba Member
Joined: October 08, 2004 Posts: 25187 Location: Central Iowa
Posted: Thu Aug 02, 2007 4:48 pm Post subject: |
This is a NOS gauge. 12V system.
_________________ Society is like stew. If you don't keep it stirred up, you end up with a lot of scum on the top!--Edward Abbey
Gary: OK. Ima poop. |
Posted: Fri Aug 03, 2007 7:59 am Post subject: |
Pac51 wrote: |
That's a good pic. I made sure all of my wires were ran correctly, which they were. The high beam and generator windows were switched. I took the gauge apart and fixed the issue.
BTW, You would think the oil light should shine "RED" since that's the most critical. The engine will be fine without generator power, but no oil pressure is a killer... Just a thought. Thanks for the help! _________________ Justin |
beetlepowerpt Samba Member
Joined: August 28, 2008 Posts: 27 Location: Lisbon- PORTUGAL
Posted: Wed Jul 02, 2014 7:09 am Post subject: |
Hi there,
I'm restoring a 65 Notch and it never worked or was powered on since on my hand.
So have a few questions.
Can someone tell me if the turn signals warning lights on the gauge light up independent of each other?
Shall it be left or right depending on the lever and direction you're turning?
It has also regular horn and another air horn.
Is this correct or was it a mod introduced by previous owner?
Thanks a lot. |
Donnie strickland Samba Member
Joined: December 21, 2009 Posts: 2403 Location: Moody, AL
Posted: Wed Jul 02, 2014 8:06 am Post subject: |
beetlepowerpt wrote: |
Hi there,
Thanks a lot. |
Both turn signal warning lamps flash at the same time, regardless of the lever direction.
No air horn on a stock Type 3. _________________ 71 Elm Green FI A/T Squareback |
