Connecting Stereo to the AUX battery....help!
Vespagetti
Vespagetti is offline
PostPosted: Wed Mar 16, 2005 10:46 pm    Post subject: Connecting Stereo to the AUX battery....help! Reply with quote
OK, so the auxiliary battery installation went smoothly. Deep cycle gel Optima is under my seat and connected to the 400W inverter and charging via Hella relay switch, yey! Anyway, $200 bucks later, I'm still not able to listen to my stereo when the engine is off.
Any suggestions/tips of how to route/wire the stereo to the auxiliary battery? Thanks guys....
ChesterKV
ChesterKV is offline
PostPosted: Wed Mar 16, 2005 11:25 pm    Post subject: Reply with quote
Dude,
I have my aftermarket radio directly wired to the main battery positive terminal. I installed a second rear window defrost switch in the blank space on the lower right corner of the instrument panel. I turn the radio on and off via that switch. It took me about 10 dead batteries Rolling Eyes before it became a habit. The Vanagons didn't come with an ACCESSORY wire for having things turn off when the engine is turned off if my memory serves me correctly. Oh, well....
Hey.....how long did it take you to wire up the secondary battery. I got a crazy quote from my local shop for $ 550.00 to add a second battery including two outlets (I guess that includes an inverter). The Hella kit is meant for Vanagons that had no previous wiring for a secondary battery, right ?
Dude.....
mightyart
mightyart is offline
PostPosted: Thu Mar 17, 2005 5:05 am    Post subject: Reply with quote
The red wire and sometimes new radios with memory and clocks have a yellow wire. hook both of them up to the + on the aux battery, then the black wire of the radio hook to the van body (ground) and that's it.
all you need is an extra battery, the relay kit and a few hours to hook up an aux battery, the hella kit is fine.
$550.00 is highway robbery, hooking up an aux battery is easy, justs takes a little time.
My Art:
http://www.instagram.com/flynn8552/
DanJReed
DanJReed is offline
PostPosted: Thu Mar 17, 2005 6:33 am    Post subject: Reply with quote
Here some links that may help..
http://www.bentleypublishers.com/images//tech/vw/vw.wiring.diagram.pdf
http://www.carstereo.com/help/radio_wires.cfm
-Dan
(87 Westy Vanagon, 98 Jetta GLS 2.0, 95 Golf Sport) VW Logo
ChesterKV
PostPosted: Thu Mar 17, 2005 10:10 am    Post subject: Reply with quote
I'm ordering the Hella kit in about five minutes before I go to work. I figure it'll cost me about $ 175 total including the Optima battery. Anybody have a favorite Optima model ?
Vespagetti
PostPosted: Thu Mar 17, 2005 10:20 am    Post subject: Reply with quote
Sounds good, I guess I just need to figure out how to route the wire. Any idea to what gauge wire to use? I was surprised to see all the thin wires supplied with Hella kit but who am I to argue... Smile
ChesterKV
PostPosted: Thu Mar 17, 2005 10:24 am    Post subject: Reply with quote
House wiring that I often work with is 12 or 14 guage and is maybe 30 percent thicker but carries 110 volts ! ! ! You'll be fine with 16 or 18 guage. The smaller 18 will be easier to conceal under your carpets.
I can't wait for my Hella kit. By the way, where did you get your Optima battery from?
mightyart
PostPosted: Thu Mar 17, 2005 10:26 am    Post subject: Reply with quote
Get the Optima that is rated at the same cranking amps as the battery that is suposed to go in your Vanagon. That way you can start the van with the optima in an emergency. If you're not really worried about this then just get the one you like. Sears is a good place to get Optima batteries.
My Art:
Vespagetti
PostPosted: Thu Mar 17, 2005 10:28 am    Post subject: Reply with quote
Installing the battery is easy, I've been quoted $300 from a pro but $550! Holy crap. I routed the wires under the carpet edge, no drilling required, apart from one hole for earth connection. The instructions that come with Hella kit are simple and quite sufficient.
I bought a yellow top Optima (the red ones are not Deep Cycle). There is only one model that fits, don't remember the model number now, but I think it will be obvious when you see it. You'll have to mount it on it's side though, with side terminals facing up. I bought mine at Pep Boys - $160.
Vespagetti
PostPosted: Thu Mar 17, 2005 11:37 am    Post subject: Reply with quote
That's some good stuff, thanks Dan.
