upper cyl cooling tin
darg
darg is offline
PostPosted: Tue Jul 15, 2014 1:53 pm    Post subject: upper cyl cooling tin Reply with quote
I have two small pieces of tin about 2X3 with a notch ( slit) on both tabs. They were left off by the previous owner. Can someone tell me where they might go. and how to get them in place with removing any engine parts. I understand it goes above the push rod tubes. I thank you for needed help
Rolling Eyes
Mr.Duncan
Mr.Duncan is offline
PostPosted: Tue Jul 15, 2014 2:09 pm    Post subject: Reply with quote
left off? thats bad.
You have to install them (they snap to the cylinder studs) when the heads are off and the pushrods/tubes are out. (while the motor is out)
See the black square on each side of the engine above the pushrod tubes in on the cylinder fins. my photo below-
(Owner) www.vintagecarleds.com
Red 1971 Squareback Thread
Red 1966 Beetle Thread
1971 Green Super Beetle (sold)
1966 Ghia (sold)
1971 Blue Super Beetle (sold)
1966 Java Green Std Beetle (sold)
1971 Red Squareback (sold)
1966 Red Beetle
TheAmazingDave
TheAmazingDave is offline
PostPosted: Tue Jul 15, 2014 2:13 pm    Post subject: Reply with quote
If you have time and patience, you may be able to finagle them in place with the engine assembled.
Try not to run the engine without them, you'll end up toasting your cylinders.
Cusser
Cusser is offline
PostPosted: Tue Jul 15, 2014 2:35 pm    Post subject: Re: upper cyl cooling tin Reply with quote
I can't believe someone left those off.
Yes, I can believe it. Don't run the engine without those !!!! Or you won't have much engine left !!!!
darg
darg is offline
PostPosted: Tue Jul 15, 2014 3:08 pm    Post subject: cyl tin Reply with quote
The blk pieces are they next to the block?
How is the best way to install them without taking the head off? The body of the bug is off the pan,
thanks
talljordan
talljordan is offline
PostPosted: Tue Jul 15, 2014 3:30 pm    Post subject: Re: upper cyl cooling tin Reply with quote
If you have a hard time believing that wait till you hear this. After rebuilt my motor I had my VW mechanic do the timing and carb and install all at once (I was on a time crunch, give me a break Razz). He said he was impressed I didn't screw it up, when I asked what he meant he relayed some home rebuild horror stories. The best by far was a guy who put the tins on the bottom of the tins like he should but also added an extra set on the TOP! He was very confused as to why his engine was toast apparently...
1972 Super Beetle, Parked until adequate restoration funding is acquired in restoration!
Wanted: Male computer diagnostic plug end
darg
darg is offline
PostPosted: Tue Jul 15, 2014 4:01 pm    Post subject: cyl tin Reply with quote
I guess some people just forget to install them or to lazy.
Mr Duncan. Can you please tell me exactly where the tin goes. I can,t quite figure the picture out.
XBIG DX 408X. Can you please tell me what I have to do to install the tin without removing the head and pushrod tubes?
More idea would be helpful from the members
Idea
TheAmazingDave
PostPosted: Tue Jul 15, 2014 4:22 pm    Post subject: Re: cyl tin Reply with quote
Idea
Just call me Big D. Cool
I'm reminded of the time the starter packed its bags on my Toyota MR2. The BGB (Toyota equivalent of the Bentley manual) stated that complete removal of the exhaust system, manifold and all, was necessary to replace it. Time and patience proved otherwise.
The tabs on those little plates aren't so long IIRC. I think you'd be able to get them in by removing the sled tins to give you some room, and then slipping them in place between the tubes and jugs, and snapping them in over the head studs. I haven't had to test this theory, but it's worth a shot.
darg
darg is offline
PostPosted: Tue Jul 15, 2014 4:39 pm    Post subject: cyl tin Reply with quote
OK BIG D, thanks
Do you know exactly where they go? Question
talljordan
PostPosted: Tue Jul 15, 2014 4:39 pm    Post subject: Re: cyl tin Reply with quote
Idea
You literally just push them between the cylinders, on the bottom side, the tabs click onto the head bolts. The tabs are asymmetrical so there is a correct orientation but it is pretty easy to figure out which way is right by looking at it.
TheAmazingDave
PostPosted: Tue Jul 15, 2014 4:42 pm    Post subject: Re: cyl tin Reply with quote
darg wrote:
OK BIG D, thanks
Directly between, and up against, the bottoms of the cylinders.
sb001
sb001 is offline
PostPosted: Tue Jul 15, 2014 4:49 pm    Post subject: Re: cyl tin Reply with quote
darg wrote:
OK BIG D, thanks
Circled from Mr. Duncan's photo above (behind the pushrod tubes):
I'm the humblest guy on this board.
1600 SP engine
Solex 30 PICT 3 carburetor
Bosch 113905205AE autostick distributor
Joel
Joel is offline
PostPosted: Tue Jul 15, 2014 5:39 pm    Post subject: Re: upper cyl cooling tin Reply with quote
Spend long enough working at a VW garage and it almost becomes surprising when you see an engine that still has them.
Engines worked on by non VW mechanics they often get the heads and pushrods on then realise shit I forgot those, meh to much work to fit customer wont notice Rolling Eyes
Quick little bug, you got a Porsche motor in that?
1974 Germanlook 1303 2.5 Suba-Beetle
darg
darg is offline
PostPosted: Wed Jul 16, 2014 2:47 am    Post subject: cyl tin Reply with quote
Thanks for all of the help.
I see the one now that are circled .
I hope the tabs go in without bending them to slide in.
You are right about people leaving things off that they forgot, hoping the customer would not catch it.
Laughing
Mr.Duncan
PostPosted: Wed Jul 16, 2014 2:14 pm    Post subject: Reply with quote
another photo
1966 Ghia (sold)
1966 Red Beetle
ach60 Premium Member
ach60 is offline
PostPosted: Wed Jul 16, 2014 3:36 pm    Post subject: Reply with quote
Mr.Duncan wrote:
another photo
A long time ago in a galaxy far away I had a buddy I was helping with the same problem.
I cut the verticle parts off that "Clip" to the cylinder studs, and safey wired
the defectors in place.
It was a fresh rebuild of unkown value, but my friend wanted it "fixed" quickly without pulling the motor, or pulling the heads.
Good Luck
Al
View user's profile Send private message Yahoo Messenger MSN Messenger Gallery Classifieds Feedback
VWCOOL
VWCOOL is offline
PostPosted: Wed Jul 16, 2014 3:42 pm    Post subject: Reply with quote
Yes I too have seen the tins "abbreviated" and wired into place
Brian
Brian is offline
PostPosted: Wed Jul 16, 2014 11:52 pm    Post subject: Reply with quote
My thought on head tins:
"Without them, your engine will explode and you will die"
its not true, but helps me remember. They are important, every piece of tin is important expect the pulley cover.
Wash your hands
'69 Bug
'68 Baja Truck
'71 Bug
'68 Camper
Only losers litter
