outwesty Samba Member
Joined: June 06, 2006 Posts: 1074 Location: Tahoe City
Posted: Sat Aug 02, 2014 12:47 pm Post subject: locker stuck on |
I've been chasing down an oil leak on my syncro trans. It turns out someone had put two aluminum crush washers on the switch for the dash light. The locker on this van has always worked perfectly. When I installed the switch with one washer I noticed the locker pin did not move nearly as easily. Anyone every encounter this ? I tried pulling vacuum on the actuator with a mighty vac and that is still not enough. (drove it 100 yds or so swerving) Actuator is brand new and works but can't pull the pin out with the switch installed. Any ideas ?
Thanks |
gears Samba Member
Joined: October 28, 2002 Posts: 4391 Location: Tamarack, Bend, Kailua
Posted: Sat Aug 02, 2014 12:49 pm Post subject: |
Reinstall switch with two crush washers ? _________________ aka Pablo, Geary
'90 Syncro Westy SVX
'87 Syncro GL 2.5
https://guardtransaxle.com |
goffoz Samba Member
Posted: Sat Aug 02, 2014 1:22 pm Post subject: Re: locker stuck on |
outwesty wrote: |
Thanks |
If I don't drive my syncro weekly the locker and decoupler will often get sticky...they will engage or dis-engage when they feel inclined after I prompt them by pulling or pushing a knob
After everythings warmed up they become quite perky
I've had both apart to try and see a way to improve the performance,
..your double crush washer has given me a new thought |
Posted: Sat Aug 02, 2014 1:34 pm Post subject: |
gears wrote: |
Reinstall switch with two crush washers ? |
It leaks badly with two crush washers. I get about 5mm of movement on the locker pin with the switch out. does that sound about right. hole for actuator pin at about the 2:00 position. Everything is as clean as can be. Thanks Paul
Edit - I get about 3/4" of travel on the pin after rotating the prop shaft a few degrees. Going to put it back together right now. Will report back. |
Posted: Sat Aug 02, 2014 2:31 pm Post subject: |
figured it out. I didn't realize the aluminum sleeve the pin rides in has a certain orientation it needs to be in. I rotated it until I could feel the spot where the light switch needs to be. wont do that again. Thanks |
gears Samba Member
Posted: Sat Aug 02, 2014 6:00 pm Post subject: |
Ah .. the pin rubbing on the aluminum sleeve. BTW, a leak from an area so far from oil splash sometimes signals that the vent is getting plugged. _________________ aka Pablo, Geary
'87 Syncro GL 2.5
morymob Samba Member
Posted: Sun Aug 03, 2014 4:15 am Post subject: |
What location on trans is the vent, looking at my sync installed trans maybe its not visible, are u. able to stick something into hole or is a loose cap there?? Looking at a spare trans I still dont find a vent. |
gears Samba Member
