Blinking coolant light at start up, but not with low coolant
devesvws
devesvws is offline
PostPosted: Tue Aug 12, 2014 1:43 pm    Post subject: Blinking coolant light at start up, but not with low coolant Reply with quote
its a 1991... I had a hose come loose up front last week and thought the light should have come on but the reservoir was still full so I didn't think anything of it until I went to add the lost coolant and checked the level... its not working?? is there a relay that controls the light? location? relay number? I checked the wire and plug and the sensor is only a few yrs old so it must be a relay??
THE FEW THE PROUD THE ORIGINAL VW WATERBOXER -> looking for a original 91 vanagon owners manual with 1991 on the cover http://www.youtube.com/watch?v=pmuiG2tUsP4&feature=share https://picasaweb.google.com/101290228103300323836/BostonBobFlywheelVideo#5543000332201103922
insyncro
Banned
insyncro is offline
PostPosted: Tue Aug 12, 2014 1:53 pm    Post subject: Reply with quote
If there truly isn't air in the system, the dash pod foil can create issues that are shown as non responsive sensors.
Farf
Farf is offline
PostPosted: Tue Aug 12, 2014 1:56 pm    Post subject: Reply with quote
I think the light blinks when you turn the ignition on as a test. There is a coolant low level relay located in position 3 on the fuse/relay box. Refer to Bentley Manual page 97.201...
I had the same issue and found that there wasn't a relay installed. It should be a #43 relay.
devesvws
devesvws is offline
PostPosted: Tue Aug 12, 2014 2:09 pm    Post subject: Reply with quote
I just replaced the relay with a used one from my other vanagon and sill no light..i will dig up another and replace that..wtf its one thing after another lately Rolling Eyes
DLJ
DLJ is offline
PostPosted: Tue Aug 12, 2014 2:16 pm    Post subject: red light Reply with quote
There is also a small printed circuit on the inside of the guage. Changed mine and now it work properly.
devesvws
devesvws is offline
PostPosted: Tue Aug 12, 2014 2:21 pm    Post subject: Reply with quote
I'm just going to swap out the cluster in the morning and see it that's it...gota get to work now thanks everyone
atomatom
atomatom is offline
PostPosted: Tue Aug 12, 2014 3:02 pm    Post subject: Reply with quote
before you go nuts and destroy your dash, check the wire to the coolant level sensor. very easy for that to become loose. if not connected, it will blink forever.
on starting, if you get a test blink for a few seconds, then it turns off, that is working perfectly. i was not clear on what is actually going on for you.
84 Vanagon Westy, 1.9L, California raised but defected to Canada.
morymob
morymob is offline
PostPosted: Wed Aug 13, 2014 6:03 am    Post subject: Reply with quote
Try a jumper in plug from top of tank, see if it works norm if not look at wiring cont.
devesvws
devesvws is offline
PostPosted: Wed Aug 13, 2014 10:55 am    Post subject: Reply with quote
light blinks when I turn the key to on and stops blinking after about 7 blinks..wires and plug at the level sensor is good but it will not blink with low coolant after I start it (it should start blinking right away)... I did jump the plug with a jumper wire and still no light, and changed the relay under the dash but still no low coolant blink.... Shocked my god how long has it been this way??
Ahwahnee
Ahwahnee is offline
PostPosted: Wed Aug 13, 2014 10:58 am    Post subject: Reply with quote
devesvws wrote:
...I did jump the plug with a jumper wire and still no light,..
I believe 'no light' when the plug is jumped is correct.
What happens when the plug is removed but not jumped? That should cause the light to blink.
PDXWesty
PDXWesty is offline
PostPosted: Wed Aug 13, 2014 10:59 am    Post subject: Reply with quote
Blinking on starting for 7 times then stopping is normal.
While the van is running, if you unplug the sensor wires, the light should start blinking. Jumping the wires would make it stop.
I'm pretty sure that's how it's supposed to work.
89 Westy 2.1 Auto
devesvws
devesvws is offline
PostPosted: Wed Aug 13, 2014 11:09 am    Post subject: Reply with quote
well it not blinking at all when running..
well I'm going to swap the cluster for now and see...
PDXWesty
PDXWesty is offline
PostPosted: Wed Aug 13, 2014 11:26 am    Post subject: Reply with quote
I'm confused...If it blinks on start up, then stops, everything is working properly. I don't see what you mean by saying it doesn't blink when the van is running. It's not supposed too.
If the sensor or wiring or dash cluster were bad, none of that would be happening.
The start up test indicates nothing wrong with the light or sensor.
Does it blink when you unplug the sensor? If not, there may be a short in the wiring. Connection all the time between the contacts would make it act like you describe. Use your multi meter to measure continuity between contacts when you pull the plug.
89 Westy 2.1 Auto
devesvws
devesvws is offline
PostPosted: Wed Aug 13, 2014 11:31 am    Post subject: Reply with quote
the coolant tank is empty right now, so it should be blinking until I fill it back up...yes???
devesvws
devesvws is offline
PDXWesty
PDXWesty is offline
PostPosted: Wed Aug 13, 2014 11:36 am    Post subject: Reply with quote
Yes, it should blink.
There are two small probes on the end of the sensor. When coolant hits them, it closes a circuit and the light stops blinking. If it never blinks, the circuit is closed somewhere. You need to find where that is by process of elimination.
Have you tried unplugging the sensor leads yet? What happens?
89 Westy 2.1 Auto
devesvws
devesvws is offline
PostPosted: Wed Aug 13, 2014 12:01 pm    Post subject: Reply with quote
swapping out the cluster did not work so it must be a broken wire...
MarkWard
MarkWard is offline
PostPosted: Wed Aug 13, 2014 1:11 pm    Post subject: Reply with quote
On the 90 I have, I noticed that the key needed to by cycled to shutoff the flashing light after jumping the connector. Seems that once it started flashing it wanted to keep flashing until the key was cycled.
So, say you had a flashing light, and wanted to add coolant while the engine was still running the coolant light would continue to flash even after filling.
I am basing this only on the one Vanagon overflow tank warning I did work with. After all these years and owners it could just be unique to this one too.
I'd be more concerned about the gauge accuracy vs the coolant level. My 82 does not have a coolant level warning. But does have the LED to get your attention if it starts to overheat.
PDXWesty
PDXWesty is offline
PostPosted: Wed Aug 13, 2014 1:27 pm    Post subject: Reply with quote
No - A broken wire would cause it to always flash. A shorted connection would cause it to never flash, like you describe.
Again - have you pulled the connector while the van is running and did it start to flash?
That will tell you if the short is in the sensor or in the wiring.
89 Westy 2.1 Auto
devesvws
devesvws is offline
PostPosted: Wed Aug 13, 2014 2:39 pm    Post subject: Reply with quote
PDXWesty wrote:
yes I have pulled it and it did not flash, so it must be in the wire right? when I probe the end of the plug I get a ground on one side but not the other, if it was shorted or fused together, would I not get the same on the other end??
