Revelen Samba Member
Joined: September 01, 2010 Posts: 233 Location: Augusta, Maine
Posted: Thu Aug 28, 2014 5:29 am Post subject: Canoes and Convertibles |
Alright, bit of an out there, impractical question, I know!
We've got a 1972 super 'vert, and we've got a 16" canoe. Transportation of said canoe is a bit tricky, using said car...
I'm considering welding some mounts to the support rails, and then building a removable cage/psuedo-roof rack of sorts, and tying down to that and the bumper mounts.
There's also the option of a trailer-hitch T-mount thingy and the front windshield, that I've seen on a few other makes of 'verts around the interwebs...
Any thoughts or suggestions?
(Also, yes, we've considered a small trailer, but we'd reaaaaally rather not!) _________________ I probably have no idea what I'm talking about. That's honesty, not shrouded modesty. No, really. |
60ragtop Bonneville Belt Bitch
Joined: March 13, 2006 Posts: 7800 Location: Big Wonderful WYO 82401
Posted: Thu Aug 28, 2014 5:39 am Post subject: |
if you look at the bumper mounts on my bug, you can see the mounts welded to the bracket to install removable a roof high rack made out of square tubing. There are also some on the front bumper. I can take pics of the rack later if you want. _________________ Rick
Certified Mechanic by the State of Michigan in 1977
ASA certified in 1987
Certified Hunter Wheel Alignment Master Technician 1986
tasb wrote: |
I've restored a large number too, but I don't toot my horn quite as loud.
sb001 wrote: |
maybe he just snapped cause his car sucked |
Posted: Thu Aug 28, 2014 5:57 am Post subject: |
That's pretty much exactly what I was hoping to do, a square-tubing rack. When we get home from this camping trip, I think the welder may just be coming out.... _________________ I probably have no idea what I'm talking about. That's honesty, not shrouded modesty. No, really. |
jhicken Samba Member
Joined: October 24, 2003 Posts: 9466 Location: Fallbrook, CA
Posted: Thu Aug 28, 2014 6:21 am Post subject: |
How about a few heavy blankets and a couple ratchet straps? Also run a lanyard tying down the fore and aft of the canoe.
-jeffrey _________________ Der Kleiner Kampfwagens |
gt1953 Samba Member
Posted: Thu Aug 28, 2014 6:58 am Post subject: |
Pull a light weight trailer. May be more practical. _________________ Volkswagen: We tune what we drive.
72 type 1
72 Squareback
Randy in Maine Samba Member
Posted: Thu Aug 28, 2014 8:55 am Post subject: |
I do not have the front rack but you get the idea and you don't have to tow a trailer
This bug was owned by an oilfield engineer and he hauled equipment with it
so I guess this set up would work for a canoe _________________ Rick
tasb wrote: |
sb001 wrote: |
DWP Samba Member
Posted: Thu Aug 28, 2014 1:48 pm Post subject: |
What about a bracket that mounts just to the front and rear bumpers?
Bolt it on when you need. This way you would still have use of the
convertible top.
DWP |
hitest Samba Member
Joined: September 30, 2008 Posts: 10296 Location: Prime Meridian, ID
Posted: Thu Aug 28, 2014 5:49 pm Post subject: |
Hey 60ragtop- I don't think he wants to buy a hardtop just for the canoe...
Second vote for the canoe trailer. There are a ton on the net- and your local CL should produce a single axle utility; MC or PWC trailer you could alter easily for the job. _________________
EverettB wrote: |
FU#5 |
Posted: Thu Aug 28, 2014 6:16 pm Post subject: |
Yep, doesn't need a buy hardtop for the bumper mounted racks which will work on a vert also. At least I understand what he is asking about as he'd prefer not to tow a trailer
I didn't see a poll to vote
tasb wrote: |
sb001 wrote: |
Posted: Sat Aug 30, 2014 7:57 am Post subject: |
Thanks for all the responses, guys!
We COULD do a trailer, but we'd definitely like the compact-ness of going without...
Right now, the bumper mounts are looking like the way to go! _________________ I probably have no idea what I'm talking about. That's honesty, not shrouded modesty. No, really. |
hitest Samba Member
Posted: Sat Aug 30, 2014 11:57 am Post subject: |
It definitely helps to see this thing with a useful picture. Even better if you had one on the front. I'd probably go this route too- but my canoe is 17 feet long- and should not be supported so close to its ends. The gunwale load spread is only 5 feet. Hope it works out. _________________
EverettB wrote: |
FU#5 |
mikeonthebike Samba Member
Joined: December 08, 2012 Posts: 953 Location: Sacramento, CA
Posted: Sat Aug 30, 2014 12:01 pm Post subject: |
you can always throw a support under the canoe like a 2X6 or a 4X4. |
