imikeh Samba Member
Joined: June 21, 2013 Posts: 56 Location: Midwestern USA
Posted: Mon Sep 08, 2014 6:24 pm Post subject: How to remove broken coolant sensor thread from tank |
Got a new coolant tank from GW old one was leaking. Put old coolant level sensor in. light torque with socket. Test drove around block and boom. Coolant level sensor shot out like cork. part is still screwed in tank like a black ring. any ideas on how to remove?
Oh yea 91 auto westy multi
imikeh Samba Member
Posted: Tue Sep 09, 2014 6:19 am Post subject: How to remove broken coolant sensor thread from tank |
Hoping I don't have to buy new tank.
JudoJeff Samba Member
Joined: May 24, 2013 Posts: 1179 Location: Near Springfield, MA
Posted: Tue Sep 09, 2014 6:56 am Post subject: |
Can you push it into tank? Or thread it all the way into the tank? Photo isn't clear, so I'm just putting out thoughts. If what's stuck is plastic, try heating up a screwdriver and inserting it, then unthread it. Good luck. _________________ ________________________________________
1989 Vanagon GL Westfalia Camper, Burned up on 7/31/16.
1987 Vanagon GL Westfalia Camper, Bostig & Rebuilt, sold
1986 Vanagon GL Westfalia Camper, Bostig Sold May 10, 2021
1999 Ford GTRV Westfalia camper (30% bigger Westy layout) |
blackglasspirate Samba Member
Posted: Tue Sep 09, 2014 7:12 am Post subject: |
I had that happen once on a trip and used a potato (cut to size) to screw into the hole and bump the threads to loosen them up. I also used it to plug the hole till I got home. Then again, that was an emergency road trip fix, so your options are more varied than mine.
You could also use some epoxy or something to glue something of a similar diameter to the top lip of those stuck threads so you can get a grip on it. Maybe some PVC that's about the same size that's long enough to stick out of the top of the tank so you can turn it. _________________ '87 Vanagon GL Westfalia
IG: @holidayatsee
FB: https://www.facebook.com/holidayatsee |
hdenter Samba Member
Joined: October 14, 2008 Posts: 2754 Location: San Luis Obispo, CA
Posted: Tue Sep 09, 2014 8:39 am Post subject: |
Go to a hardware store and get a tool for removing broken plumbing nipples. I thing they are called EZ Outs. They come in different sizes and I think a larger one will work. I would not use the hot tool method for fear of accidently melting something adjacent and then ruining the tank.
Good Luck!
Hans _________________ '79 triple white convertible bug
'84 sunroof vanagon
'85 weekender |
atomatom Samba Member
Joined: May 15, 2012 Posts: 1867 Location: in an 84 Westy or Bowen Island, BC
Posted: Tue Sep 09, 2014 9:03 am Post subject: |
before you extract it, make sure that is not actually the threads the sensor screws into!
i had this happen too. if there was anything left, it moved pretty easily with my thumb. it is a good thing those sensors are cheap, readily available and blow up easily. saves having to find a replacement for an obscure NLA hose. _________________ 84 Vanagon Westy, 1.9L, California raised but defected to Canada. |
vanis13 Samba Member
Joined: August 15, 2010 Posts: 3100 Location: ABQ NM USA.... Except when not
Posted: Tue Sep 09, 2014 9:12 am Post subject: |
hdenter wrote: |
I thing they are called EZ Outs. |
Lots of time those are for smaller diameter applications. The logic is the same though, get something in there to dig into the part needing to be moved to create the friction.
A sprinkler head remover tends to be a bigger dia but not sure if this big.
What comes to mind for me is a tapered putty knife. push it in until the edges cut into the edges and twist. _________________ 83.5 Westy with Subaru 2.5, 4 spd manual, center seat, COLD A/C on 134a!, Winter camp heated with an Espar B4 gasoline furnace
www.SuperVanagon.com - some stuff I make |
Terry Kay Banned
Posted: Tue Sep 09, 2014 11:44 am Post subject: |
Dental pick will grab it and back it out. _________________ T.K. |
imikeh Samba Member
Posted: Tue Sep 09, 2014 3:54 pm Post subject: |
Thanks all!
Ez out was 12.00 bucks.
Dental pick I had and will try. I just bit the bullet and threw another part at it.Waiting for a new GW tank and sensor to show. |
vanagonjr Samba Member
Joined: October 07, 2010 Posts: 3431 Location: Dartmouth, Mass.
Posted: Tue Sep 09, 2014 5:38 pm Post subject: |
imikeh wrote: |
Thanks all!
That's fine. I'd work on the old one and keep it in the van as a spare, along with a new coolant level sensor. Both these items are less than optimal build quality. My $0.02
PS - if you drop the glovebox, they will fit behind it, along with a fuel filter. _________________ John - 86 Wolfsburg Westfalia "Weekender"
FAQ thread: http://www.thesamba.com/vw/forum/viewtopic.php?t=525798 |
