Little Hobbit Bastard Samba Member
Posted: Fri Aug 08, 2014 9:03 am Post subject: |
Thanks Christopher! Sorry I moved my post from the Ultimate Wheel part 2 thread because I thought it was more suited the original... I was in the wrong thread initially.
My Vanagon is sitting 70mm AVO's so if the fronts are going to be sticking out that far there will probably too much rubbing on the outer wheel arch lip so probably not a good idea then? My 17's sit just inside the lip so it might be better just to stick with 17's.
Thanks for your help! _________________ - 1989 Vanagon GL
- 1985 Vanagon GL (R.I.P.) |
1971BugGuy Samba Member
Joined: October 16, 2004 Posts: 426 Location: Ontario, CANADA
Posted: Tue Aug 12, 2014 8:57 pm Post subject: Mercedes E320 |
I bought these wheels and was told they were from a Mercedes CLK but after probing a little deeper it seems that they are from a 2002 Mercedes E320. Anyhow, with a little help and hardware from Christopher Schimke they fit nicely with 215-65-16 tires wrapped around them. No wheel spacers necessary.
[/img] _________________ Only a fool or a child would judge a project before it reaches its completion.
1971 Super Beetle
1986 Vanagon Westfalia Weekender |
dutchcamper73 Samba Member
Joined: July 30, 2014 Posts: 8 Location: redwood city
Posted: Fri Aug 22, 2014 8:17 am Post subject: |
hi all, a little overwhelmed with all the info on this subject and not sure what i need but came across this and was hoping it would be a straight fit on my 86 Weekendder:
Selling the rims from my 2007 rabbit
These will fit VW Rabbit, Golf, Jetta 2005 and newer
And VW Passat and Audi 2001 and newer.
Size: 16" X 6.5"
Bolt Pattern: 5 X 112mm
Offset: 50mm
Thanks for any and all feedback! |
Posted: Tue Aug 26, 2014 8:10 am Post subject: |
dutchcamper73 wrote: |
Size: 16" X 6.5"
Offset: 50mm
Sorry for the delay here! You can certainly use those wheels, but you would need to have the centerbores machined out to 66.56mm and you would need spacers front and rear, new front lug bolts, new rear wheel studs and new rear lug nuts.
One other issue that may arise is that you may have difficulty mounting the center caps due to interference with the front grease caps. You would just have to try it and see. _________________ "Sometimes you have to build a box to think outside of." - Bruce (not Springsteen)
Posted: Tue Aug 26, 2014 10:58 am Post subject: |
Thanks for your response!
So, what i am gathering is that this wheel set is probably not the best way to go? Seems lots of things needs to happen to ensure a good fit?
Wait and keep looking? |
lemm0 Samba Member
Joined: June 17, 2014 Posts: 5 Location: Nordic Sweden
Posted: Fri Aug 29, 2014 7:40 am Post subject: |
I bought some wheels today that said they were: 5x112, 7x16 ET31 bore:6,65, but when I got them home it said ET37..
Will they fit 2WD and or 4WD?
Thanks. |
Posted: Fri Aug 29, 2014 4:22 pm Post subject: |
lemm0 wrote: |
Thanks. |
We will need the part number, or at least a photo of the wheels to be able to help. Those specs sound like OE Mercedes wheels, but could be something else too.
Simply judging by the 16x7 ET37 specs, you could use them on either a 2wd or a Syncro, but depending on which wheels they are, you may need longer studs (rear on a 2wd, front and rear on a Syncro) and you will most likely need new front lug bolts (2wd only), you may need spacers (more likely on a 2wd than a Syncro), etc.
If you can post the part number or photo of the wheel, I can be more specific and I can probably tell you if you will have any center cap clearance issues or not. _________________ "Sometimes you have to build a box to think outside of." - Bruce (not Springsteen)
lemm0 Samba Member
Posted: Tue Sep 02, 2014 12:12 pm Post subject: |
Christopher Schimke wrote: |
lemm0 wrote: |
Thanks. |
If you can post the part number or photo of the wheel, I can be more specific and I can probably tell you if you will have any center cap clearance issues or not. |
Thank you Christopher for your help, I decided to send them back and now they're hopefully sending Mercedes wheels that should be ET33. |
brettsvw Samba Member
Joined: November 22, 2007 Posts: 2145 Location: Florida
HoustonPhotog Samba Member
Joined: February 20, 2013 Posts: 1514 Location: Houston, TX
raoul mitgong Samba Member
Joined: July 05, 2009 Posts: 1338 Location: Denver, CO
Posted: Tue Sep 30, 2014 2:03 pm Post subject: |
Can anyone tell me if the stock steel wheels on a Syncro (86 if that matters) are the same ET as the stock steel wheels on a 2wd (84 westy wolfsburg if that matters)?
Just wondering if I was going to run into any troubles moving my 14" BFGs around from van to van if I wanted to in the future. I no longer have the stock steelies from the 2wd to compare.
Thanks,
-d _________________ 84 Westy with a 2.1 (Groover)
86 Tintop Syncro (Crow)
86 Tintop Syncro to Westy project (Tom Servo)
91 Westy (Only the top 12 inches of this van (a burn victim)) |
Farfrumwork Samba Member
Joined: October 10, 2008 Posts: 692 Location: Mile High
Posted: Tue Sep 30, 2014 3:45 pm Post subject: |
So, I've got a line on a set of these passat wheels.
Making sure they will drop onto my syncro? Will I need to bore them to clear the front hub, or is that just a 2wd thing(?) <- I suspect it is (just for 2wd that is)
fuzzymath wrote: |
12mm spacers and 39mm bolts up front, stock studs and nuts in back. Fronts bored for grease caps.
_________________ sold -> '85 Wolfsburg Syncro / 'Built' DOHC EJ25 (a great machine!)
'07 Legacy spec.B, road tuned stgII
'17 4x4 Sprinter, stone grey, SMB pop-top, on 33"s
"Blood stains, speed kills - Fast cars, cheap thrills - Rich girls, fine wine - I've lost my sense, I've lost control, I've lost my mind" |
Posted: Tue Sep 30, 2014 4:03 pm Post subject: |
raoul mitgong wrote: |
Thanks,
-d |
brettsvw wrote: |
I owed both a syncro westy and a two wheel drive westy and the 14in steel wheels were the same. |
Yep, brettsvw is correct, the wheels are the same. Just make sure that you use the correct lug nuts to match the wheels. Vanagon alloy wheels require conical seat lugs and the Vanagon steel wheels require large ball seat lugs. _________________ "Sometimes you have to build a box to think outside of." - Bruce (not Springsteen)
Posted: Tue Sep 30, 2014 4:08 pm Post subject: |
Farfrumwork wrote: |
fuzzymath wrote: |
Those wheels in the photo above are 15x7 ET37. In order to bolt them onto a Syncro, you will need a set of small ball seat lug nuts and you will need to either open up the centerbores of the wheels or you can grind down the lip on the front hub until the wheel fits. Another alternative is to run a set of thin spacers, but then you would need to install longer wheel studs.
The front grease caps will fit, but the rears will not...at least not without installing spacers. _________________ "Sometimes you have to build a box to think outside of." - Bruce (not Springsteen)
uberaudi Samba Member
Joined: June 24, 2013 Posts: 503 Location: Hi-top Country
Posted: Thu Oct 02, 2014 9:52 pm Post subject: |
15x7, et45 Audi Fuchs. Forged, strong and light. I bored out the center to fit T3's hubcentric spacers and left about .050" of the original bore for the center caps to latch on to. I also shortened the grease caps about .200". 18mm spacers on the front along with conversion studs and 22mm spacers on the rear with longer studs as well; small ball seat lugnuts all around. I had some 205/70-R15 Yokohama Geolander AT/S' mounted up and the difference between this setup and stock is remarkable! It handles so much better, is much more stable and quieter too! Thanks again Chris!
Before:
After:
babywindow Samba Member
Posted: Thu Oct 02, 2014 10:03 pm Post subject: |
Holy Fuch |
OhBetty Samba Member
Joined: August 23, 2014 Posts: 80 Location: Salt Lake City
Posted: Mon Oct 06, 2014 3:58 pm Post subject: |
mrshrimp wrote: |
Is there a big break kit that fit 15" Rhein south african rims?
-Keith |
Keith - I'm looking into this too. I have heard that the GoWesty kit does not fit the Rhein-15s. But the small car and Audi kits do.
Would love to hear from anyone else that has some perspective on this issue though. |
almo Samba Member
Joined: January 27, 2011 Posts: 174 Location: In the back sleepin
Posted: Mon Oct 06, 2014 9:39 pm Post subject: Bronze |
VC Carrot 15" rims powder coated bronze, 215/17/15 BFG's
I was nervous as hell about getting the brand new rims powder coated!!
I am very happy with how it turned out against the wolf-man grey. The camera doesn't do them justice!
All inspiration came from members on here cheers.
I know they will prob get scraped up, off roading etc....., but I will always know she was pretty once
_________________ San Francisco/Mayo Ireland
1986 2.1L Westy 2wd 4-spd Sold!!!!
1987 2.1L Westy syncro
2005 Subaru legacy 2.5Gt Wagon 5sp MT |
pizzavandriver Samba Member
Posted: Mon Oct 13, 2014 11:49 am Post subject: |
16" audi wheels and hardware from T3technique. centercap solution coming soon.
_________________ Pete
85 Vanagon |
