vintagemotion Samba Member
Joined: December 13, 2009 Posts: 73 Location: Kleve Germany; Atlanta Georgia
Posted: Mon Jul 12, 2010 11:15 am Post subject: Alternative starter for diesel Vanagon |
Slowly my 82 Vanagon starter is going out. I’m using the bulky 1.6 Diesel starter and it turns my AHU TDI motor well. The problem is the solenoid or one-way clutch (starter spins but intermittently without turning motor)
Now I’m looking for an alternative inexpensive starter that fits without modification. Would a starter from a gasoline Audi motor fit? How about Bosch BMW starter? I looked at a Mercedes 6 Cylinder Bosch starter, it would have the power and even the drive gear is the same. Unfortunately the mounting depth is off.
Any suggestions? _________________ 82 orange Diesel Westy
AHU conversion (mechanical with stock JX pump)
5 Speed ASS
CLK Wheels 215/70/16 |
MarkWard Samba Member
Joined: February 09, 2005 Posts: 17119 Location: Retired South Florida
Posted: Mon Jul 12, 2010 1:36 pm Post subject: |
The bosch replacement starter I got for my diesel was a torque reduction starter. It was half the size as the original and so far works great even with the larger 1.9 diesel. I believe the bosch reman number is SR 28 X. _________________ ☮️ |
crazyvwvanman Samba Member
Joined: January 28, 2008 Posts: 9923 Location: Orbiting San Diego
Posted: Mon Jul 12, 2010 1:49 pm Post subject: |
The Bosch SR28X number applies to both the old large diameter starter and the smaller later one that most people get when they order that part. It is just a application number, for replacement purposes, and either starter fits the application. Maybe all the big ones are gone from the Bosch rebuilt channels but I doubt it since big ones still get turned in as cores.
Mark
rsxsr wrote: |
The bosch replacement starter I got for my diesel was a torque reduction starter. It was half the size as the original and so far works great even with the larger 1.9 diesel. I believe the bosch reman number is SR 28 X. |
Posted: Mon Jul 12, 2010 2:24 pm Post subject: |
Yes, I realize it is the same number, but wanted to let the poster know there was good chance if he went with another Bosch Vanagon diesel reman, it would be of the more modern compact designs. Are they better? I can't say. They are easier to lift into place. World Pac shows the photo of the later design and their pictures are usually accurate. _________________ ☮️ |
Posted: Mon Jul 12, 2010 2:49 pm Post subject: |
I don't know if either is really better either. I just don't want someone to think that because a starter offered to them is a Bosch with a SR28X sticker that it will for sure be the smaller newer one. I have both types here with that sticker. Both came from WorldPac but not that recently.
mark
rsxsr wrote: |
Yes, I realize it is the same number, but wanted to let the poster know there was good chance if he went with another Bosch Vanagon diesel reman, it would be of the more modern compact designs. Are they better? I can't say. They are easier to lift into place. World Pac shows the photo of the later design and their pictures are usually accurate. |
DAIZEE Samba Member
Joined: January 26, 2010 Posts: 7552 Location: Greater Toronto Area Ontario West Side
Posted: Tue Jul 13, 2010 2:26 pm Post subject: |
ok I'm not sure I understand. I was a gas now I am an AZZ 1.9L TD. Should I change starters, or is that something that was probably done during the conversion? I don't know everything but am keen to learn. I'm getting better with the glow lites . _________________ '09 2.5L Jetta 5 cylinder, 5 spd, super turbo, see thread in H2O Cooled Jetta, etc...
84 Vanagon GL Wolfsburg Westy WBX 4 speed (sold) |
Posted: Wed Jul 14, 2010 6:40 am Post subject: |
Daizee, we have not seen pictures of your install, but if a diesel bellhousing was utilized for a 50 degree install, then I am pretty sure the installer would have had to upgrade the starter at the same time. I don't believe the gasser starter even fits the diesel bellhousing. The diesel engine compression is at least twice that of a gas engine. While a gas starter might turn the engine over, I doubt it would last for long. Someone here, was making an adapter for adding a high torque starter to the gasser bellhousing. I don't recall who it was. _________________ ☮️ |
BlackDogVan Samba Member
Joined: December 21, 2007 Posts: 855 Location: Vancouver Island
Posted: Wed Jul 14, 2010 9:02 am Post subject: |
Westyventures makes the adapter for the Tdi Bosch starter on tue wbx bellhousing. By far the best way to go if you don't have the diesel bellhousing. Nothing wrong with the stock diesel starter that I know about, stay away from the her reduction starters that were popular with early diesel swaps... Junk! _________________ Gone but not forgotten - 1991 Carat - AAZ transmogriffied to mTDi.
Still addicted, looking for Doka... |
DerPänzer Samba Member
Posted: Thu Sep 18, 2014 2:59 am Post subject: Starters? |
Hi, Im not sure how old is that post but its interesting for me, Im doing an engine swap on my vanagon, Its a aba (gas) engine but im using a diesel bellhousing. Can I use the 2.1 oem starter or not??? Does the 2.1 starter fit directly to the diesel bell housing????? (Excuse my english ) |
danfromsyr Samba Member
Posted: Thu Sep 18, 2014 6:05 am Post subject: Re: Starters? |
Welcome and your english is good.
to answer, NO you can't use the 2.1 oem starter on your Diesel bellhousing.
you need to use a Bosch SR28X from the 1982-1983 US market or 1981-1991 European market vanagon diesel. any of the regular vanagon or import shops should be able to get it for you.
wolfburg wrote: |
Abscate wrote: |
Posted: Thu Sep 18, 2014 3:55 pm Post subject: and,,, |
If I use the diesel starter, and the mk3 aba engine, wich flywheel can I use? the mk3 or the vanagon 2.1? here were I live its very dificult to find a diesel one.... |
?Waldo? Samba Member
Posted: Thu Sep 18, 2014 5:11 pm Post subject: |
2.1 vanagon flywheel will not work. It has 5 crank bolts and the inline-4s have 6. I'm somewhat ignorant about the VW gas engine components but I thought that the MK3 ABA had the pressure plate bolted to the crank and the flywheel bolted to the pressure plate. No way for that to work in a vanagon. No FedEx in Puerto Rico? |
vanagonjr Samba Member
Joined: October 07, 2010 Posts: 3431 Location: Dartmouth, Mass.
Posted: Thu Sep 18, 2014 5:19 pm Post subject: |
Andrew A. Libby wrote: |
I'm somewhat ignorant about the VW gas engine components but I thought that the MK3 ABA had the pressure plate bolted to the crank and the flywheel bolted to the pressure plate. No way for that to work in a vanagon. |
That is correct.
Certainly through me for a loop when I removed it -I was like > _________________ John - 86 Wolfsburg Westfalia "Weekender"
FAQ thread: http://www.thesamba.com/vw/forum/viewtopic.php?t=525798 |
Posted: Thu Sep 18, 2014 5:34 pm Post subject: ... |
yep. we have fed ex, but heavy weight ítem cost too much. |
Posted: Fri Sep 19, 2014 4:43 am Post subject: Re: ... |
wolfburg wrote: |
If it fits in a large flat rate box it will be very reasonable.
Med box inside-13-5/8" x 11-7/8" x 3-3/8" - $12.65
Large size is also reasonable. _________________ John - 86 Wolfsburg Westfalia "Weekender"
