Scorpwanna Samba Member
Posted: Thu Sep 25, 2014 9:22 pm Post subject: Tired of negative rear camber... |
Could bad spring plate bushings cause negative camber?
I've replaced the trailing arms, stub axles, bearings, drums and they still go / \ and I'm tired of it. :( _________________ 1971 Super Beetle Sedan Stock
Manufacture Date: December 12 1970
Left Factory on: December 17 1970 (Emden Germany)
Received: Washington, USA
Original Color: L 12 D Shantung Yellow
SOLEX 34-PICT 3 Carb
I've got a Bentley |
Brian Samba Moderator
Posted: Thu Sep 25, 2014 9:24 pm Post subject: |
Aren't there shims that negate that?
Or your trailing arms are bent _________________ Wash your hands
'69 Bug
'68 Baja Truck
'71 Bug
'68 Camper
Only losers litter |
Posted: Thu Sep 25, 2014 11:34 pm Post subject: |
Crap, I must of replaced my bent ones for some bent ones :(. That tells me that I'm pretty much always going to be stuck with them that way and tire wear will always be uneven. _________________ 1971 Super Beetle Sedan Stock
Anthonyisawsome Samba Member
Posted: Thu Sep 25, 2014 11:40 pm Post subject: |
Well how low are you in the rear? Even with irs once lowered to a certain point I think they all get camber?? _________________ I have learned so much, but yet I still don't know anything because knowing what you don't know is showing you how much you haven't learned.
1973 Subaru powered supabeetle
(o\ l /o) 1964 Baja bug roller |
Aussiebug Samba Member
Joined: June 03, 2002 Posts: 2162 Location: Adelaide Australia
Posted: Fri Sep 26, 2014 12:08 am Post subject: |
Both swing axle and IRS suspension bugs will suffer from negative camber if the rear torsion bars are "rotated" to lower the suspension - swing axle bugs much more than IRS, but it will happen for both suspension styles.
So - is the rear suspension on your 71 (IRS) bug lowered? _________________ Rob
Rob and Dave's aircooled VW pages
Repairs and maintenance for the home mechanic
http://www.vw-resource.com |
Posted: Fri Sep 26, 2014 12:11 am Post subject: |
shouldn't be by that much, mine is raised by 3" and there is no camber issues _________________ Wash your hands
'69 Bug
'68 Baja Truck
'71 Bug
'68 Camper
Posted: Fri Sep 26, 2014 7:59 am Post subject: |
The rear is not lowered. It sits about a normal height I think. Maybe a few inches low. I've been wanting to reindex it but am afraid of doing it wrong and hurting myself.
caffeinebean Samba Member
Joined: November 20, 2013 Posts: 234 Location: Menifee, CA (92584)
Posted: Fri Sep 26, 2014 9:22 am Post subject: |
Nice Bug! that's not that bad compared to some rear wheels I've seen. How bout you rotate tires more often? |
Multi69s Samba Member
Joined: January 24, 2006 Posts: 5364 Location: Lefty, CA
Q-Dog Samba Member
Joined: April 05, 2010 Posts: 8700 Location: Sunset, Louisiana
Posted: Fri Sep 26, 2014 11:46 am Post subject: Re: Tired of negative rear camber... |
Scorpwanna wrote: |
I've replaced the trailing arms, stub axles, bearings, drums and they still go / \ and I'm tired of it. |
Yes, absolutely.
Did you not replace the bushings when you replaced the trailing arms? _________________ Brian
'69 Dune Buggy
'69 Beetle Convertible
'70 Beetle |
Posted: Fri Sep 26, 2014 3:21 pm Post subject: |
I installed new trailing arm bushings when I replaced the trailing arms but I didn't take the spring plates off to re-index them and change their bushings. That I'm afraid is not one thing I'd be able to do, I'd need a professional. _________________ 1971 Super Beetle Sedan Stock
vamram Samba Member
Posted: Fri Sep 26, 2014 5:42 pm Post subject: |
Scorpwanna wrote: |
I installed new trailing arm bushings when I replaced the trailing arms but I didn't take the spring plates off to re-index them and change their bushings. That I'm afraid is not one thing I'd be able to do, I'd need a professional. |
I did mine this past summer but it was a motherf-r to do. You can see the build in the link in my signature. I would do it again after having learned and taken my lumps this time but....I know a shop that would have done it for $500...would've been worth every penny but I like pain & suffering!! that's why I drive a 42 y/o car!!! _________________ Eventually, "we are what we pretend to be.’”
Give peace a chance - Stop Russian-Soviet Aggression!!
'75 Super Le Grande...waiting it's turn in line behind '74.
Click to view image
Save the Supers!! |
Posted: Fri Sep 26, 2014 8:29 pm Post subject: |
500 DOLLARS.... *faints*... I'll never have time to figure out how to do it safely and actually have time to do it myself. _________________ 1971 Super Beetle Sedan Stock
Posted: Fri Sep 26, 2014 8:54 pm Post subject: |
Scorpwanna wrote: |
Scorpwanna, in the last pic (side on) above, it looks to me like your torsion bars have sagged some - the rear end is definitely lower than the front.
There is a procedure on my web site too, for resetting the suspension height. It's not particularly difficult but it will take you a few hours per side, the first time you do it. Get some new torsion bar bushes and replace them at the same time. And use real talcum powder to lubricate the torsion bar bushes - not the corn flour substitute they have in supermarkets these days - that stuff will absord water and get sticky. _________________ Rob
dirtkeeper Samba Member
Joined: February 19, 2008 Posts: 3200 Location: Left of everywhere
Posted: Fri Sep 26, 2014 8:57 pm Post subject: |
You need to reindex and replace the bushings will fix that . if you can replace the trailing arms you could probably do a reindex. |
vamram Samba Member
Posted: Sat Sep 27, 2014 6:49 am Post subject: |
Scorpwanna wrote: |
500 DOLLARS.... *faints*... I'll never have time to figure out how to do it safely and actually have time to do it myself. |
I think it was an "insider" price. His daughter has a '65 that he built and maintains for her. I should've taken him up on it but i've yet to graduate from the School of Hard Knocks. _________________ Eventually, "we are what we pretend to be.’”
Click to view image
Save the Supers!! |
vamram Samba Member
Posted: Sat Sep 27, 2014 7:02 am Post subject: |
It's a lot easier if you have the right tools. These 2 and my 2.5 ton floor jack were must-haves:
The angle finder was like $6 form HF. The one to raise the spring plate into positions was about $30.
http://www2.cip1.com/ProductDetails.asp?ProductCode=ACC-C10-7047 _________________ Eventually, "we are what we pretend to be.’”
Click to view image
Save the Supers!! |
Posted: Sat Sep 27, 2014 8:18 pm Post subject: |
Does that big tool work for double spring plates? _________________ 1971 Super Beetle Sedan Stock
wcfvw69 Samba Purist
Posted: Sat Sep 27, 2014 9:27 pm Post subject: |
Even when these cars were relatively new, they suffered negative camber on the rear wheels. I remember in the early 80's getting bugs in at the frame and alignment shop I worked at with inside tire wear like your photo shows. We'd check the toe in/toe out and in most cases that measurement was fine. We liked them set to 0 toe in or out on the back wheels.
So, what we'd do to adjust the camber was (hide your kids eyes) bend the trailing arm up slightly with a chain and porta-power. Basically, we'd loop a chain around the outside's of the trailing arm and push up with the porta-power in the middle of the trailing arm. We'd warn the owners that the trailing arm would look a bit bent afterwards but it would stop them from wearing out their tires. The owners didn't care what a part under their bug looked like. They simply wanted to stop buying tires so frequently.
So, our final alignment specs would be 1/8" to 1/4" negative on the camber and 0 for toe. This cured their tire wear problem. I can't ever recall even one come back for continued tire wear after we did this work. _________________ Contact me at [email protected]
The Samba member since 2004.
Posted: Sat Sep 27, 2014 9:30 pm Post subject: |
Scorpwanna wrote: |
Does that big tool work for double spring plates? |
Yes. It's really not that difficult to adjust the torsion bars. If you search the forums, you can find some step by step procedures of people who have done this. A Bentley manual is useful as well.
Your pictures do show some saggy torsion bars but as I mentioned, even when these bugs were new and the rear ends did not sag, they still had negative camber that caused tire wear. _________________ Contact me at [email protected]
