Capulina Samba Member
Joined: June 14, 2013 Posts: 28 Location: Fairfax, CA
Posted: Sat Sep 27, 2014 11:53 pm Post subject: Electrical Questions for Heater Fan Motor & Resistor |
Hello,
My dad and I removed the dashboard and dismantled the heater box today (1984 Westy). We are replacing the heater core, and the heater fan/motor and the 3-speed resistor. The fan/motor and resistor were both purchased separately from a reputable VW parts dealer. When we went to wire up the fan motor and resistor, we scratched our heads. See diagram below, with original config and new schematic config.
The ground wire that came with the fan/motor was loose in the packaging(neither end connected) and there appears not to be an obvious attachment for a ground on the fan/motor. The fan/motor has a short brown (ground?) wire that obviously is supposed to attach via connector to a white lead from the resistor.
The yellow wires seem to match up, except the yellow wire on the new config has an open ended spade splice and we're not sure what it should connect to. It seems logical that the black/yellow lead should connect to the #3 high speed connection on the dashboard fan switch. We're unsure what connects from the fan/motor and/or resistor to the low (#1) and middle (#2) connector on the switch.
No electrical genius here, (obviously) so I feel bit of an idiot for posting this. The solution is probably obvious to some of you experts. Any help you can offer would be great. The parts house office/phone is closed this weekend, and we were hoping to figure it out and get the van back together again this weekend. Thanks!
westyventures Samba Member
Joined: December 29, 2004 Posts: 2306 Location: Oregon Outback
Posted: Sun Sep 28, 2014 12:46 am Post subject: Re: Electrical Questions for Heater Fan Motor & Resistor |
Capulina wrote: |
Hello,
Just like before except the yellow middle connector now goes to the switch. So: brown is ground. Almost always. Yellow is the + side of the motor and receives full power via switch terminal 2, or low / medium via terminal 1 or 3 through the resistor. Connect everything just like the first photo except the original two yellows are now connected outside the motor instead of inside as in the original. |
dhaavers Samba Member
Joined: March 19, 2010 Posts: 7757 Location: NE MN (tinyurl.com/dhaaverslocation)
Posted: Sun Sep 28, 2014 9:49 am Post subject: |
Forget your "new" schematic - it's severely muddled. Wire it like the original.
It's possible your replacement parts connectors don't exactly match the originals in the Vanagon.
Remove any that don't allow for the connections needed, and use a good quality crimper and
connectors where necessary...
Like Karl says, but step-by-step:
- Brown from motor connects to ground.
- Yellow from motor connects to yellow from resistor; but ALSO:
- add a wire to switch terminal "2" and crimp the loose end together WITH the two yellows.
- Black/yellow from resistor connects to switch terminal "3".
- White from resistor connects to switch terminal "1"
If I were you, I'd wire this together and test it before you put the entire heater box & dash
back in...you wanna be sure it's working right before then! _________________ 86 White Wolfsburg Westy Weekender
"The WonderVan"
Posted: Sun Sep 28, 2014 11:02 am Post subject: Assistance was successful |
Hey, it worked great. Thanks for the advice. We wired it up and tested the fan in the garage and all 3 speeds work correctly with the switch using the new fan and the new resistor. Now we can start putting everything back together! Woot! Thanks again! |
