Henrik_K Samba Member
Joined: November 17, 2013 Posts: 181 Location: Denmark
Posted: Sun Sep 28, 2014 10:57 am Post subject: What to do - Type 4 - engine tin missing |
Just bought a type 4 1800 - engine. With bad or missing engine tins.
It seems a little hard to locate some tins in good shape. I reade about the upright conversion - and thought that could some of my challenges.
Would you recommned that I stay on the original tins or?
Any good pics outthere that shows the complete engine tins?
Rgds, Henrik |
Wasted youth Samba Member
Joined: July 06, 2012 Posts: 5134 Location: California's Hot and Smoggy Central Valley
Posted: Sun Sep 28, 2014 11:37 am Post subject: |
Henrik,
I like the Type 4, so my opinion is slightly biased. You can find several pictures of the tins you are missing using the Photo Gallery and also the Classifieds, but getting the actual name or correct part number for each piece can be confusing.
It has been my experience that the two most difficult pieces to locate for the Type 4 are the bottom two that go below the pushrod tubes, but not impossible to find. Regardless, both the Type 1 upright and the Type 4 pancake need all their tin, so converting to the Type 1 might not solve all of your problems anyway.
There is literally a bus full of tin at the VW junkyard where I go.
Also try these vendors of used parts:
Busted Bus: http://bustedbus.com/
Interstate VW: http://interstateusedparts.com/ |
Posted: Sun Sep 28, 2014 11:52 am Post subject: |
If you go with an upright cooling system you will become dependent on a heavily loaded fan belt. One of the things I like about the T4 is that the fan is going to keep turning so long as the crank does. Yes there is still a belt to drive the alternator, but it is very lightly loaded and will last for a couple hundred thousand miles with very infrequent adjustments, and when and if it does fail you can still drive a hundred or more miles without the alternator until you can get a new belt. |
SGKent Samba Member
Posted: Sun Sep 28, 2014 12:23 pm Post subject: |
Humbly said - if that is as used engine you may have a lot more going on in that engine than just missing tins. Borrow a bore scope and look inside the cylinders to see what they look like. Check the valves with the rockers off to be sure they are even. Drain the oil and check for bits of metal. Do not tighten the oil strainer bolt more than 9 ft lbs or it will break.
If it is a new engine who is the engine builder?
Tins can be bought easily out of classifieds. For every engine that becomes scrap there is a tin set left over. You should be able to buy a whole set cheaper than piece by piece. _________________ “Most people don’t know what they’re doing, and a lot of them are really good at it.” - George Carlin |
Tcash Samba Member
Posted: Sun Sep 28, 2014 5:52 pm Post subject: |
Thanks to jersylooker
Engine |
sonofamitch Samba Member
Joined: May 27, 2012 Posts: 325 Location: Evergreen, CO
Posted: Mon Jan 05, 2015 5:19 am Post subject: |
Hi Tcash - I can't seem to find the correspondin item number list to the picture from Jerseylooker. Can you help?
Rgds, Henrik |
aerosurfer Samba Member
Joined: March 25, 2012 Posts: 1602 Location: Indianapolis, IN
Posted: Mon Jan 05, 2015 6:53 am Post subject: |
First off what is your current or planned exhaust setup?
The picture above is tin specific to the stock 75-78 exhaust system.
If you are going with the 72-74 style heater boxes and trapezoid shaped exhaust flanges part numbers 9, 20, 21, 27, 32, and 01 will be different.
Also not pictured will be the heat riser tubes from the forward side of the heater boxes, and the riser from the engine bay to the right side heater box. those parts are specific to the exhaust style.
This is a better thread describing the differences... http://www.thesamba.com/vw/forum/viewtopic.php?t=292923
Once you know what exhaust, then you can proceed to figure out which pieces you need _________________ Rebuild your own FI Harness..My Harness
77 Westy 2.0L Rockin and Rolling Resto!
72 Sportsmobile (sold)
79 Tran$porter... Parts car money machine (gone) |
SGKent Samba Member
Posted: Mon Jan 05, 2015 8:11 am Post subject: |
the parts won't be listed in classifieds under VW part numbers. I have never seen a NOS set come up. Most pieces are bent a little, dirty, and have cracks in them.
My suggestion is make a decision what year engine you are going to run and then continue this thread trying to find each piece or a set. Also if you change carbs or FI that may change what you need/can use too. _________________ “Most people don’t know what they’re doing, and a lot of them are really good at it.” - George Carlin |
Tcash Samba Member
Posted: Mon Jan 05, 2015 9:32 am Post subject: |
Henrik_K wrote: |
Rgds, Henrik |
I matched the numbers to the numbers on the parts diagram, to reference the parts description name.
As suggested post the exhaust used and the year of your engine and someone can help you acquire the correct tin.
http://www.jerseylooker.com/FicheDump/EarlyBaywindow/EarlyBay-1.html
Good Luck
Tcash |
Posted: Mon Jan 12, 2015 5:44 am Post subject: |
Finally managed to take some pics of my engine tin.
There's also a pic of the heater boxes I plan to use...
Reg. Carbs - I plan to run two 32-34 carbs.
These I'm not really where belong to...
williamM Samba Member
Joined: August 07, 2008 Posts: 4333 Location: southwest Arizona
Posted: Mon Jan 12, 2015 7:28 am Post subject: |
looks like 73. Do you have the big fan casting?
almost easier to identify what you have vers what you need.
Looks like you have front tin w- warm air hole for preheat, but no tube for that. see an oil cooler piece there, bottom tins, under cylinder tins- top cylinder tins-
your off to a good start.
I will try and get some pics of your missing parts. but off to work now. _________________ some days I get up and just sit and think. Some days I just sit.
opinion untempered by fact is ignorance.
Don't step in any!
Posted: Mon Jan 12, 2015 7:37 am Post subject: |
Yes I have the fanhousing without any cracks...
I've got hold of two 32-34 carbs with linkage... |
vwpilotbob Samba Member
Joined: June 22, 2014 Posts: 28 Location: Tucson, AZ.
Posted: Wed Jul 21, 2021 9:24 pm Post subject: Re: What to do - Type 4 - engine tin missing |
Well, if you post in an old dead thread, some people complain. If you post a new thread, people say "why don't you do a search, dummy"?
So, here goes:
Yeah, building my first Type 4 for a dune buggy. (I'vd built many Type 1's.) I've got the long block built, but have no cooling tin. Does anyone have a pic of what tin I need to search for please? Just what I need for a dune buggy installation, not all the extras for a van or other install.
Add: I have the large aluminum fan shroud and fan, just need to know what tin to look for to wrap it up.
Thanks!! |
busdaddy Samba Member
Joined: February 12, 2004 Posts: 51144 Location: Surrey B.C. Canada, but thinking of Ukraine
Posted: Thu Jul 22, 2021 8:06 am Post subject: Re: What to do - Type 4 - engine tin missing |
Well done!
You'll need the 2 large top pieces (you can trim off the outer flanges that meet up with the sides of the engine compartment for buggy use) (1&3 on fiche).
The 2 under the cylinders (10 fiche) as well as the rear deflectors (27 & 36) shown below, you likely don't need the flat rectangles (20 & 21) since you probably don't run heat exchangers:
And you'll need the deflectors at the front as well (32 & 33):
_________________ Rust NEVER sleeps and stock never goes out of style.
Слава Україні! |
Posted: Thu Jul 22, 2021 12:24 pm Post subject: Re: What to do - Type 4 - engine tin missing |
Wow!! Excellent information, and precisely what I needed! Thanks!!
Yeah, on Type 1 VW's that aren't running a skid plate, I do use the tin under the cylinders to protect the pushrod tubes. But on this Type 4, my exhaust header runs down out of there. Fabbing a skid plate to protect that area is going to be interesting...
Now to find the tin. Any ideas there?
Sometimes I really wonder whatever possessed me to go with a Type 4 this time....
Thanks again,
Vwpilotbob |
Posted: Thu Jul 22, 2021 12:33 pm Post subject: Re: What to do - Type 4 - engine tin missing |
In your first pic, what is the piece with the large round hole in the foreground??
And, while I've got you, will a Melling type long gear oil pump fit behind the fan shround on a Type 4??
Thanks!
Vwpilotbob |
Posted: Thu Jul 22, 2021 12:55 pm Post subject: Re: What to do - Type 4 - engine tin missing |
I've never heard of anyone having shroud clearance issues, but many complain of the way it fits loose in the case.
The mystery part in the top pic goes between the alternator and it's pulley, but it's not needed if there's no engine compartment.
Plenty O tin here: https://www.thesamba.com/vw/classifieds/search.php...ton=Search _________________ Rust NEVER sleeps and stock never goes out of style.
Слава Україні! |
vwdoctor53 Samba Member
Posted: Wed May 11, 2022 10:25 am Post subject: Re: What to do - Type 4 - engine tin missing |
Hi I'm looking for part Number 20 & 21 in the tin diagram... Anyone have those pieces for sale ??
021119356c
021119355b |
Posted: Wed May 11, 2022 12:14 pm Post subject: Re: What to do - Type 4 - engine tin missing |
Welcome!
That search link I posted just above your post still works, I see a few in there. _________________ Rust NEVER sleeps and stock never goes out of style.
Слава Україні! |
