physast Samba Member
Posted: Tue Oct 07, 2014 3:13 pm Post subject: gates barricade 5/16" fuel hose clamp |
I really did search for this...
What size hose clamps do you use on the gates barricade 5/16 ID fuel hose?
I have some from van-cafe, but would like to use the ear style clamp on most connections.
Thanks for the help. _________________ 1967 L633 VW beetle (currently being restored...slowly)
1991 Orly Blue Vanaru 2.5L |
vanagonjon Samba Member
Posted: Tue Oct 07, 2014 3:25 pm Post subject: |
You need to size the clamp to the OD, go online and look up Oetiker, the German company that makes the ear type clamps. They come in number sizes based on hose OD range. you will need something around a size 17 to 20 I guess based upon my clamps I just looked at.
John |
Posted: Tue Oct 07, 2014 3:34 pm Post subject: |
| vanagonjon wrote: |
John |
That's my problem I don't know the OD of the gates hose. It's gates 27348 FI hose. I saw one mention of the OD as being 13mm, but I can't find it again. I didn't find anything on the gates website.
I will keep looking. _________________ 1967 L633 VW beetle (currently being restored...slowly)
kalispell365 Samba Member
Posted: Tue Oct 07, 2014 5:11 pm Post subject: |
If you are doing a Subaru conversion anyway, the factory stainless Subaru fuel clamps are the nicest Ive ever come across, and they are on your donor(or any 1990 and newer Subaru at the junkyard).I use them on all fuel lines on the Vanagons. _________________ 1983 Diesel Vanagon Westfalia chassis with Subaru 2.2l |
Phishman068 Samba Member
Joined: February 19, 2007 Posts: 2024 Location: Pittsburgh PA (ish)
Posted: Tue Oct 07, 2014 5:50 pm Post subject: |
The clamps I used are:
Oetiker 16700013 Stainless Steel Hose Clamp, One Ear, 7 mm Band Width, 9/16" Hose ID, 12 mm - 14.5 mm Hose OD Range (Pack of 100).
They're available on amazon for $27, so $0.27 a piece.
They do seem quite tight though, and I may be moving up to the next size up for some applications. I have used them on most of the engine and fuel connections with no problem though, they tighten down really nicely.
I am using Goodyear Hose, so i'm not sure if the OD is any different but it should be pretty much the same. _________________ http://www.thesamba.com/vw/forum/viewtopic.php?t=559766&highlight=winter+rust
http://www.thesamba.com/vw/forum/viewtopic.php?t=482402&highlight=sunroof+syncro
http://www.thesamba.com/vw/forum/viewtopic.php?t=569774
http://www.thesamba.com/vw/forum/viewtopic.php?p=6864936#6864936
"Along with the ability to go fast, one looses the desire to hurry." |
rubbachicken Samba Member
Posted: Tue Oct 07, 2014 7:08 pm Post subject: |
these are what i've been using for the last couple of years, i've gone through 300 or so, all the vans i've put fuel lines have had these fuel line clips these are reuseable unlike the oetiker clamps, and a good bit cheaper.
i had them on lucy for over a year before i put them on other peoples vans, no leaks on any of them.
if you pop the hood on a modern VW you will find these all over the place, and they are LOT more expensive if you buy them from VW  _________________ lucy our westy
lucy's BIG adventure
meet 'burni' |
Posted: Tue Oct 07, 2014 7:15 pm Post subject: |
| rubbachicken wrote: |
if you pop the hood on a modern VW you will find these all over the place, and they are LOT more expensive if you buy them from VW  |
Do you know if this fits the gates 27348 hose? I might give these a try. _________________ 1967 L633 VW beetle (currently being restored...slowly)
Posted: Tue Oct 07, 2014 8:29 pm Post subject: |
sorry i have no idea, i don't have any gates fuel line, what's the OD of the gates fuel line, i can go and measure what i have, if that would help.
| physast wrote: |
Do you know if this fits the gates 27348 hose? I might give these a try. |
meet 'burni' |
djkeev Samba Moderator
Joined: September 30, 2007 Posts: 32988 Location: Reading Pennsylvania
nmerrill Samba Member
Joined: January 07, 2014 Posts: 388 Location: Vermont
Posted: Wed Oct 08, 2014 6:13 am Post subject: |
Hopefully not a significant drift...
Is there a specific tool out there for this type of spring clamps? I always use pliers of one sort or another...
Yes, they are all over my GTI.
Oddly, the emissions pipes also have Oetiker style clamps on them. |
Posted: Wed Oct 08, 2014 7:38 am Post subject: |
| Come to think of it, I think these are only used on the GTI for cooling system hoses. |
Posted: Wed Oct 08, 2014 7:54 am Post subject: |
I think I might stick with the ABA ones from vancafe for now. I have not heard of them failing yet.
Since I am using the 5/16 gas line I just want to make sure they get snug and stay put. _________________ 1967 L633 VW beetle (currently being restored...slowly)
borninabus Samba R&D Dept.
Joined: May 18, 2006 Posts: 4779 Location: Arizona Highways
Posted: Wed Oct 08, 2014 8:08 am Post subject: |
ABA 21013 Stainless 13mm bolt style clamps are what you want. _________________ 88 Van WBX, A/T - 93 Multivan 5cyl 5M/T - 13 JSW TDI 6M/T - 2012 Touareg TDI Sport |
Posted: Wed Oct 08, 2014 8:26 am Post subject: |
| borninabus wrote: |
| ABA 21013 Stainless 13mm bolt style clamps are what you want. |
Like this?
http://www.amazon.com/AAS-Fuel-Injection-Clamps-FI...K4VRGQWJ5A
I read somewhere that these are good for low pressure hose. But these say FI in the description. _________________ 1967 L633 VW beetle (currently being restored...slowly)
Posted: Wed Oct 08, 2014 9:47 am Post subject: |
go look under the hood on a new VW, these are all over the fuel lines, if you have the right size for the hose, they clamp very well, remember over tightening damages fuel line anyway, like i posted i put them on my van first, before using them on anyone elses, they are fine.
| Phishman068 wrote: |
Are those rated for fuel injection pressures?
I can't see how they possibly can be and certainly won't be using them on my bus anytime soon. They just seem so weak.
Heck, I put a new carb on our Dodge truck recently and It used these, and I wasn't overly confident with their tension to hold on a fuel line that operated at a few PSI, let alone the high pressures of the vanagon system.
To each their own I guess. |
meet 'burni' |
kamzcab86 Samba Moderator
Posted: Wed Oct 08, 2014 1:19 pm Post subject: |
yep
no special tools required _________________ 88 Van WBX, A/T - 93 Multivan 5cyl 5M/T - 13 JSW TDI 6M/T - 2012 Touareg TDI Sport |
Posted: Wed Oct 08, 2014 1:20 pm Post subject: |
those pliers are WAY to big for fuel line clips though.
i use just a regular pair of pliers, for the fuel line clips, those are for coolant hose clips _________________ lucy our westy
meet 'burni' |
1vw4x4 Banned
Posted: Fri Oct 10, 2014 10:44 am Post subject: |
You people really know how to spend money. Pinch clamps are available
in any size you want. That's the key. Beverage companies seem to need
a lot of these. They are typically stainless steel and are about .03 to .05 each. YES that is five cent.
Bars and restaurants use these all the time. I have about 4000 of these in maybe 6 different sizes.
THey work great, look great, and are cheap. |
