Yondermtn Samba Member
Joined: November 21, 2007 Posts: 609 Location: Illinois
Posted: Sat Jul 31, 2010 7:37 am Post subject: Installing new SVDA distributor questions?? |
I'm installing a new aftermarket SVDA distributor w/pertronix on my 1977 bus. Stock 2.0L
1. What is the distributor tang? The instructions say to line the tang up with the shaft.
2. The notch mark for cyl. #1 on the new distributor seems to be on the opposite of the distributor as the same notch on the old distributor. Should I position the distributor so that this notch is in the same place as the former distributor? (in relation to engine case) |
TomWesty Samba Member
Joined: November 23, 2007 Posts: 3482 Location: Wyoming,USA
clearsurf2001 Samba Vaccinator
Joined: February 26, 2004 Posts: 1671 Location: Dave-AKA-fortyeye-Oceanside, Ca
Posted: Sat Jul 31, 2010 8:27 am Post subject: |
Ok. TomWesty's link seems to be what is happening with my distributor. It seems as though it is 180 degrees different from the original.
It looks like I should install it with the same orientation as my stock dist., but I'll have to switch the plug wires on the cap. Correct?
Here is my old distributor with my thumb showing the #1 tdc mark.
My new dist. with index finger pointing to #1 tdc mark.
Here is a pic of my dist. orientation before I pulled the old one.
Mal evolent Samba Member
Joined: March 31, 2009 Posts: 2912 Location: San Antonio, Nuevo Mexico
Posted: Sat Jul 31, 2010 8:33 am Post subject: |
the tang is the offset flat bar that lines up with the slot that drives the rotor shaft.
an SVDA mounts 90 degrees from where an 009 mounts, because the vacuum advance cam would hit the case if they lined up the same _________________ 73 Beetle Baja, Ghia front brakes, Type 3 rear brakes, 2220 ( 94 X 80 ), Weber Progressive, Bosch SVDA, '97 Mustang seats
Baja Bugs for Volkswagen Virgins: Index |
busdaddy Samba Member
Joined: February 12, 2004 Posts: 51124 Location: Surrey B.C. Canada, but thinking of Ukraine
Posted: Sat Jul 31, 2010 8:35 am Post subject: |
Well the bottom line is getting it in a position where the vacuum can has some room to move for adjustment, if your drive isn't in the right place don't worry. Set the engine to #1 with your old distributor then install the new one and put your own mark on with a sharpie where the rotor ends up, arrange the wires to suit. _________________ Rust NEVER sleeps and stock never goes out of style.
Слава Україні! |
Posted: Sat Jul 31, 2010 8:41 am Post subject: |
Okay, thanks. Sounds like I'm on the right track.
Now my problem is that I can't get the distributor to seat all the way. I think it's because of the newer rubber seal on the shaft. I had a hard time getting the bracket over this seal too.
Any tricks to this? I don't want to force it too much, but I just can't seem to get it all the way seated. |
Posted: Sat Jul 31, 2010 8:56 am Post subject: |
The seal should have an almost flat profile, if you just can't get it in recycle your old one until you can find the correct one. IIRC Karl said they were available from Mercedes but try Germansupply first.
Just to make sure install the distributor with the seal removed and confirm the rotor position when it's fully seated so you know you've got it right once you battle with the seal. _________________ Rust NEVER sleeps and stock never goes out of style.
Слава Україні! |
Posted: Sat Jul 31, 2010 10:52 am Post subject: |
Got the distributor in there and cranked the engine and it won't start. I'm pretty confused at this point. |
Amskeptic Samba Member
Joined: October 18, 2002 Posts: 8568 Location: All Across The Country
Posted: Sat Jul 31, 2010 11:02 am Post subject: |
Yondermtn wrote: |
Check wires to coil. All correct?
Put engine at TDC #1. Solid lifters? Confirm by checking that both #1 rocker arms have a little click of clearance. If they are both tight, rotate engine 360* and check again.
Look at the rotor under the distributor cap. Is it "locked into place" as in Successfully Engaged With The Distributor Drive Gear?
Wherever that rotor is pointing (ignore little notches on the distributor body), the wire in the cap just above it HAS to be #1 now. Install other wires 4-3-2-.
Try it now.
Colin _________________ www.itinerant-air-cooled.com |
Posted: Sat Jul 31, 2010 11:13 am Post subject: |
how much won't it seat?
the height of the tang ( there's a hint there ), a quarter inch, ? _________________ 73 Beetle Baja, Ghia front brakes, Type 3 rear brakes, 2220 ( 94 X 80 ), Weber Progressive, Bosch SVDA, '97 Mustang seats
Posted: Sat Jul 31, 2010 12:12 pm Post subject: |
How did you connect the wires from the new distributor? _________________ Rust NEVER sleeps and stock never goes out of style.
Слава Україні! |
Nica Samba Member
Joined: November 11, 2005 Posts: 618 Location: Bogotá, Colombia
Posted: Sat Jul 31, 2010 12:18 pm Post subject: |
It probably didnt engage. That can be a PITA Make sure the shaft is engaged, try to move it, if you can move it more that a couple mm it didnt completely engage. |
Posted: Sat Jul 31, 2010 12:29 pm Post subject: |
Thanks again for the replies.
I threw the old dizzy back in and got it running and started the entire procedure over from square one.
The new dist. slid in much easier with a warm engine. BUT, I'm having the same issue. Won't start.
The pertronix has a red and a black wire. I have my red to positive side of coil and black to negative side of coil.
I've tried all possible firing orders.
I found that after cranking the engine, if I set the crank at TDC the rotor is in a different place each time. Also, I can move the rotor around by hand. Is this what Nica is talking about? My shaft not engaging?
It looks like it's seated pretty well as is.
Thoughts? |
Posted: Sat Jul 31, 2010 1:48 pm Post subject: |
Not seated well enough, turn the rotor as you drop in the distributor until you feel the drive engage the slot, then give it a good twist both ways to confirm it's engaged. You may have bent the clamp by now and it may be holding the distributor up away from the case, there should be no gap between the distributor, clamp and case. _________________ Rust NEVER sleeps and stock never goes out of style.
Слава Україні! |
Posted: Sat Jul 31, 2010 1:56 pm Post subject: |
Okay. I got it seated correctly now. I could feel it drop in and now the rotor only turns a little bit with some springy resistance.
Still will not start. The rotor points 180 degrees(pointing towards #3 cylinder) from the original distributor. I have placed #1 wire where the rotor is pointing and then 4-3-2.
Now I'm perusing the Pertronix trouble shooting pages. |
Posted: Sat Jul 31, 2010 2:07 pm Post subject: |
I have had 2 pertronix. they lasted about 10 seconds each, connected correctly to a 3 ohm coil. _________________ 73 Beetle Baja, Ghia front brakes, Type 3 rear brakes, 2220 ( 94 X 80 ), Weber Progressive, Bosch SVDA, '97 Mustang seats
Posted: Sat Jul 31, 2010 3:10 pm Post subject: |
Still no start. It has backfired a couple times while cranking, if that means anything.
I'm now thinking about pulling the pertronix out of the new distributor and putting some points in.
The reason I'm changing distributors is because I suspect my old one to be sticking. I can't get it to stay timed right and the idle will not return to normal all the time. |
crDaniel Samba Member
Joined: September 13, 2010 Posts: 43 Location: Portland, OR
Posted: Tue Oct 21, 2014 2:44 pm Post subject: Im having the same issue! |
This thread was describing my same problem exactly -- and then it ended! What was the solution...? And more importantly, how do I get my new Pertronix SVDA to work? |
Randy in Maine Samba Member
Posted: Tue Oct 21, 2014 3:12 pm Post subject: |
From Speedy Jim and modified by Amskeptic |
