goopher Samba Member
Posted: Sat Oct 25, 2014 10:44 pm Post subject: 1963 convertible window scrapers - assembly order? |
Hi all,
As the restoration of my 1963 vert is just about ready for door/window assembly I have a question:
Can I mount the scraper rubbers and related chrome trim LAST, i.e. when I am done with everything else in the door/window department, or do the scrapers have to be mounted earlier in the process? If so - when in that process? Thanks for you help! Sincerely / Jonas _________________ Falun, Sweden, Europe. |
grandpa pete Samba Member
Posted: Sun Oct 26, 2014 10:07 am Post subject: |
As have I. I am aware of the concept of searching But despite this I can't find an educated answer on when in the assembly process I should - or could - mount the scrapers on a 58-64 vert. Hence my post. "Window scrapers assembly" as a search is too wide, BTW. window scrapers assembly differs from different VW cars and also between years. But I'm sure you already knew that. Still, if you have found the answer to my question in your search - please share _________________ Falun, Sweden, Europe. |
payin_vw Samba Member
Joined: November 27, 2012 Posts: 117 Location: Colorado USA
Posted: Sun Oct 26, 2014 12:35 pm Post subject: |
goopher wrote: |
As have I. I am aware of the concept of searching But despite this I can't find an educated answer on when in the assembly process I should - or could - mount the scrapers on a 58-64 vert. Hence my post. "Window scrapers assembly" as a search is too wide, BTW. window scrapers assembly differs from different VW cars and also between years. But I'm sure you already knew that. Still, if you have found the answer to my question in your search - please share |
Here's the order when I did replaced all the rubber on my 61 doors, its a NON Convertible, again its not a convertible.
1-Vent Wing seals
2-Felt guide (clips on top and bolts on bottom of the door)
3-Outside scrapper
4-Inside scrapper
5-Divider post with wing rubber installed
6-Lastly felts
hope it helps. _________________ 61 work in progress restoration, more work than progress actually. |
Posted: Sun Oct 26, 2014 12:43 pm Post subject: |
Thanks payin_vw, much appreciated!
Yeah, I think that's about the order I did it on my ragtop too. I have a feeling it's different on the vert though, since the scrapers and the trim that holds them down are mounted on top of the door... The scrapers for front and quarter windows sit with over 100 small clips, so I want to get the order right before assembly, so I'm not risking pulling it all out again. Thanks very much for your answer! _________________ Falun, Sweden, Europe. |
