Yondermtn Samba Member
Joined: November 21, 2007 Posts: 609 Location: Illinois
Posted: Sun Oct 26, 2014 12:16 pm Post subject: |
I didn't read this entire thread, but as far as a sink, wouldn't a used Westy sink work?
http://www.thesamba.com/vw/classifieds/detail.php?id=1668636
We rarely use the sink in our '77 but I do miss the drawers for utensils and small odds and ends when we use the '90 MV. _________________ 1977 Westfalia 2.0FI 4spd
1990 Multivan 2.1 Auto |
ZsZ Samba Member
Joined: December 11, 2010 Posts: 1642 Location: Budapest Hungary, Europe
Posted: Sun Oct 26, 2014 12:38 pm Post subject: |
To Djkeev:
We usually cook on the fold up table, but the top of the fridge is often used also
_________________ Zoltan
1.9 MTdi 2wd Multivan (ex Caravelle)
Van since 2006, engine since 2008 |
crazyvwvanman Samba Member
Joined: January 28, 2008 Posts: 9895 Location: Orbiting San Diego
Posted: Mon Feb 16, 2015 2:51 pm Post subject: |
I just finished my version of the holy grail. A compact self contained and fully removable kitchen unit. Does not block aisle to front seats, no holes cut in the floor or to the outside
Propane stove, sink, electric fridge, water tank, drawer, cutting board. Remove 3 bolts and 4 wires and it is out if needed.
Has aux battery voltmeter, aux 12v cig socket, 5 gal fresh water tank.
Mark |
wildenbeast Samba Member
Posted: Mon Feb 16, 2015 8:27 pm Post subject: |
I really like this self contained version of the weekender kitchen. Where did you get the cabinet? Could you reverse the location of the fridge so that you wouldn't need to climb into the van when sitting by a campfire?
Bill _________________ - Bill, '93 Eurovan Syncro Weekender (2.5 manual ACU) |
dhaavers Samba Member
Joined: March 19, 2010 Posts: 7733 Location: NE MN (tinyurl.com/dhaaverslocation)
Posted: Mon Feb 16, 2015 9:27 pm Post subject: |
Pretty sweet, Mark...ready to start taking orders...??? _________________ 86 White Wolfsburg Westy Weekender
"The WonderVan"
WestyBob Samba Member
Joined: June 11, 2004 Posts: 2346 Location: Portland, Oregon
Posted: Mon Feb 16, 2015 10:05 pm Post subject: |
Very nicely done, Mark.
What's powering the fridge ?
And yes ... time for a production run. |
newfisher Samba Member
Joined: January 05, 2012 Posts: 1764 Location: The wet spot--Oregon
Posted: Mon Feb 16, 2015 10:20 pm Post subject: |
Crazyvwvanman--- nice work! Best yet. |
Steelhead Samba Member
Joined: February 25, 2007 Posts: 1791 Location: Kentfield, CA
Posted: Tue Feb 17, 2015 1:33 am Post subject: |
Way to go Mark _________________ '77 Bay Window / '89 Caratsburg (aka. the Stormtrooper) |
Vanagon Nut Samba Member
Joined: February 08, 2008 Posts: 10347 Location: Sunshine Coast B.C.
Posted: Tue Feb 17, 2015 1:46 am Post subject: |
Way cool Mark.
Is the sink bowl removeable?
Is the nook shown in lower LH of image for fire extinguisher?
Nicely done man!
Neil.
crazyvwvanman wrote: |
Mark |
_________________ 1981 Westy DIY 15º ABA
1988 West DIY 50º ABA
VE7TBN |
djkeev Samba Moderator
Joined: September 30, 2007 Posts: 32432 Location: Reading Pennsylvania
greggearhead Samba Member
Joined: June 20, 2004 Posts: 563 Location: Colorado Springs, CO
Posted: Tue Feb 17, 2015 6:07 am Post subject: |
The cabinet is built from scratch. The main objective was to build it so it was as small as possible and intruded as little as possible into the main living space. Originally I was going to put the water tank flat under the unit but just a few inches more height made it less practical to use the kitchen while seated at the jump seat, at least for a shorter person lke my wife.
I bought a sheet of grey laminate to use but decided this wasn't the project to learn that skill on.
The van is an 87 Westy Wolfy so it came with a factory aux battery setup that is being used to power the kitchen unit. A second Group 41 battery is under the driver seat for this.
The stainless sink/stove top is from a Westy kitchen. It has been trimmed to the smallest practical size on all 4 sides, including removing the other burner. During the mockup phase I bought some aftermarket sinks and stoves to use but didn't get as compact a result as I desired.
That is a fire extinguisher spot doing double duty as a bracket to keep the water tank in position. I removed the extinguisher and the velcro straps for it to take the photos.
The sink drains into a 1 gal jug that fits behind the front passenger seat. The stove uses a green 1 lb can that straps to a holder behind the front seat. Here is a photo of that.
The step in the cabinet top is needed because the front seat leans back and the seat/headrest would otherwise interfere with the stove/sink.
Mark |
Posted: Tue Feb 17, 2015 8:05 am Post subject: |
Mark ... since the fridge is powered off a group 41 when in camp do you consider this operation to be an overnighter only (as in moving daily from camp to camp to recharge) ?
I was also wondering about adding propane as well although then perhaps not as easy to remove the unit when desired.
Overall looks simpler than I expected which is good .... I like a clean, simple set-up without hundreds of wires and multiple hook-ups |
Posted: Tue Feb 17, 2015 8:35 am Post subject: |
The Group 41 is good for an occasional 2 night stay. More battery is needed really but I am starting with what the factory provided and we will see how it goes. That is why the voltmeter on the cabinet where I can keep an eye on the battery condition. I don't want to drift this thread into all the usual electrical discussions.
With just a single burner stove the 1 lb cans should be fine. I have plenty of permanent mount propane tanks on hand for under a van but I am trying to do without that in this van. We are going to try to live simply.
Mark
WestyBob wrote: |
Last edited by crazyvwvanman on Tue Feb 17, 2015 8:57 am; edited 1 time in total |
Posted: Tue Feb 17, 2015 8:48 am Post subject: |
I don't want to drift this thread into all the usual electrical discussions ..... We are shipping this one to Europe for extended travels .... |
Well then .... I guess you wouldn't want this thread to drift toward knowing more about your extended Euro travel plans either ? |
dobryan Samba Member
Joined: March 24, 2006 Posts: 16473 Location: Brookeville, MD
shadetreetim Samba Member
Joined: January 10, 2011 Posts: 1994 Location: Riverside, California
Posted: Mon Apr 06, 2015 5:30 pm Post subject: |
I keep trying to come up with the perfect cabinet for our Bluestar, built for the particular usage Lady Shadetree and I prefer, which means all cooking and washing outside. To that end, a year and a half ago I built this cabinet to hold our plethora of kitchen utensils and the abundance of food we like to travel with.
It was pretty satisfactory, with the exception that it replaced the jumpseat and took up a lot of space while camped. Not to mention it oriented all those cool utensils inside and the cookstove outside at a table. Not to mention I hated placing the stove in a trashbag and storing it on the bed cushion while traveling.
Fast forward to 2015 and we now have a CHC top, which changes the options available in my feeble little mind. At Buses By The Bridge I tried a crate outside with my limited dishes (I was camping alone), and my food in another crate in the pop top. Camping with the jump seat instead of the cabinet made the interior seem extravagantly spacious. But Lady Shadetree wants her dishes, and I want her happy. Besides, I have long admired the chuck boxes others have posted, so I decided to try my hand at building one.
Here you can see the overall size of the cabinet
Almost done, still need to varnish it.
And here is the finished product, closed up and ready to travel.
The legs each have about 2" of vertical adjustability to account for rough terrain. Currently the cabinet is loaded and ready to try it out camping this weekend. _________________ Tim Potts
Doing my best every time I drive it to dispel the myth these Vanagons have to be slow!
'89 Vanagon Bluestar/Country Homes 1.8T & .77 4th
'74 Jeep CJ5 |
adv rider Samba Member
Joined: September 09, 2012 Posts: 288 Location: Everett,wa
Posted: Sun Sep 20, 2015 1:41 pm Post subject: |
[quote="crazyvwvanman"]I just finished my version of the holy grail. A compact self contained and fully removable kitchen unit. Does not block aisle to front seats, no holes cut in the floor or to the outside
That's a nice set-up! I just might have to copy it. _________________ 86' Wolfsburg weekender 2.1, 4spd, , merian brown |
