raygreenwood Samba Member
Joined: November 24, 2008 Posts: 21519 Location: Oklahoma City
Posted: Thu Nov 06, 2014 4:22 pm Post subject: |
jfats808 wrote: |
Ray,
I want a couple of those pig dollies. |
While reading this thread an looking for an image to respond to bluebus86 with.....I simply google "god of engineering" and looked under google images and found that half a page down. I thought it was hilarious looking!
I have no idea what that page related to.....im afraid to look!
Ray |
raul arrese Samba Member
Joined: July 23, 2006 Posts: 1330 Location: miami florida
Posted: Thu Nov 06, 2014 6:26 pm Post subject: |
Ace wrote: |
Dale M. wrote: |
raul arrese wrote: |
So if im a lazy ass and I want to torque my axle nut without working up a sweat can I use a 50 ft bar and just lay my 5 lb Chihuahua on it ? |
YEP... 250ft-lbs torque applies at fastener...
Dale |
Not an accurate way to do it. That bar has weight. You would need an engineer to figure out the formula for the weight of the bar and then get the required weight chihuahua to stand at the proper distance on the bar.
I will counter balance the bar so its at zero ... and please have faith in my chihuahua _________________ " Hot vw feature , may 2014 issue "
" 2013 Bug Jam class winner "
" Bug Jam best motor and best paint "
" 2013 Lakeland Classic Best of Show "
" 2014 Show and Shine , First in class "
Like my facebook https://www.facebook.com/pages/Raul-Arrese-custom-fabrication-and-performance/1832968110262608 |
esde Samba Member
Joined: October 20, 2007 Posts: 5969 Location: central rust belt
Posted: Thu Nov 06, 2014 7:10 pm Post subject: |
Ace wrote: |
Dale M. wrote: |
Dale |
I will counter balance the bar so its at zero ... and please have faith in my chihuahua |
exactly, a 100 ft bar, with the socket centered, and your chihuahua on one end. |
chrisflstf Samba Member
Joined: February 10, 2004 Posts: 3444 Location: San Diego
Posted: Thu Nov 06, 2014 8:01 pm Post subject: |
with a 100 ft bar, it would flex so much, you would run out of rotating room |
57BLITZ Samba Member
Joined: June 12, 2012 Posts: 2385 Location: DEEK - U.S.A.
Posted: Thu Nov 06, 2014 8:36 pm Post subject: |
Raul, use a fifty foot long bar, socket exactly in the middle, use your chihuahua and borrow a second five-pound chihuahua from a neighbor! Just make sure that the second chihuahua weighs exactly five pounds!
If the borrowed dog is of a different weight, see if the neighbor that you borrowed the dog from can also lend you a slide-rule and a Ti-45 calculator so you can figure how much of a counter weight to put on the other end of the fifty-foot bar . . . you might need to borrow a parakeet or a gerbil to get the torque just right!
Keep at it . . . you might need to give it a few tries to get the process down, but I have seen what you are capable of . . . YOU CAN DO IT! _________________ Jesucristo es mi Señor y Salvador! |
Dale M. Samba Member
Joined: April 12, 2006 Posts: 20379 Location: Just a tiny bit west of Yosemite Valley
Posted: Thu Nov 06, 2014 8:49 pm Post subject: |
57BLITZ wrote: |
Keep at it . . . you might need to give it a few tries to get the process down, but I have seen what you are capable of . . . YOU CAN DO IT! |
At this point you have "0" (zero) foot pounds torque applied because chihuahua "B" would counter the weight of chihuahua "A" which is applied force... Effectively "B" neutralizes "A"...
You have just increased weight of bar by "BAR+(A+B)"
esde Samba Member
Posted: Thu Nov 06, 2014 9:40 pm Post subject: |
You'll get a more accurate torque using a schnauzer or shepherd puppy. |
Randall Samba Member
Joined: October 03, 2004 Posts: 1403 Location: Orange County, Alta California, El Norte
Posted: Thu Nov 06, 2014 11:24 pm Post subject: |
EverettB wrote: |
Adapted from an old post I made about engine gland nuts:
Quote: |
Here's what I do:
Get my breaker bar and big socket.
Let's say you need 250 ft. lbs. of force for the rear axle nut - that is 250 lbs. at 1 foot out from the socket.
1 foot = 12 inches.
Say you weigh 200.
So take 250/200 = 1.25
12 inches x 1.25 = 15 inches.
Mark a line on the bar at 15 inches.
When the bar stops moving downward from your weight, you just applied 250 lbs. |
That's the way the John Muir book said to do it. I also slipped a 'cheater pipe' over the breaker bar. I wrapped masking tape around the cheater pipe at the point where I needed to put my foot. In the 35 years since I first did it I have had to periodically move the tape closer to the pivot point. |
Posted: Thu Nov 06, 2014 11:34 pm Post subject: |
Dale M. wrote: |
Dale |
Dale, I meant that BOTH chihuahuas are to go on one side . . . the side that the parakeet or gerbil would need to be on depends on the actual weight of the loaner chihuahua . . .
For example . . .
Raul's chihuahua (5lbs) + loaner chihuahua (4.875lbs) = 9.875lbs . . . parakeet on same end of bar with BOTH dogs.
A different scenario . . .
Raul's chihuahua (5lbs) + loaner chihuahua (5.25lbs) = 10.25lbs . . .Both dogs on the same end of the bar and one gerbil on the other side of the bar.
As for it being any easier using a schnauzer or shepherd puppy, I wholeheartedly disagree! Mixing dog breeds will create other variables that will complicate the necessary calculations . . . you would need a pair of synchronized digital abacuses PLUS a slide-rule to figure that out! _________________ Jesucristo es mi Señor y Salvador! |
fastfil Samba Member
Joined: November 25, 2006 Posts: 356 Location: Sunshine Coast, AUS
Posted: Fri Nov 07, 2014 3:17 am Post subject: |
Look, you only need a 20ft bar weighing 25lbs and gravity will torque it to 250ft/lbs for you. Get the chihuaha to firmly push the brake pedal. _________________ "...swingaxle...transaxle...same diff." |
79SuperVert Samba Member
Joined: May 31, 2002 Posts: 9758 Location: Elizabeth, NJ & La Isla Del Encanto
Posted: Fri Nov 07, 2014 7:23 am Post subject: |
Time to update this classic drawing:
_________________ Central Jersey VW Society
Wanted: Art Collins VW (Savannah, Georgia) items - license plate surrounds and other items. Also ivory "AM", "FM" and "SW" buttons for a US Blaupunkt Frankfurt. |
Posted: Fri Nov 07, 2014 7:37 am Post subject: |
79SuperVert wrote: |
'Nother example of loosening axle nut.... So its non-relevant to initial subject...
scotth17 Samba Member
Joined: January 30, 2012 Posts: 335 Location: Bedford Texas
Posted: Fri Nov 07, 2014 1:31 pm Post subject: |
I used a honey badger so it would be real tight. |
subhuman Samba Member
Joined: January 22, 2008 Posts: 539 Location: north carolina
Posted: Fri Nov 07, 2014 1:38 pm Post subject: |
scotth17 wrote: |
dude, thats what i use also where do you get your badger calibrated? _________________ 63 restomod build
http://s431.photobucket.com/albums/qq37/johnnysubhuman/?albumview=slideshow
you can have everything you want, just don't want so much!
"the wrong way always seems the more reasonable."
george moore
1963 type1
2002 Subaru Wrx
never argue with an idiot, they will only drag you down to their level and beat you with experience!
Mark Twain |
Cusser Samba Member
Joined: October 02, 2006 Posts: 31379 Location: Hot Arizona
Posted: Fri Nov 07, 2014 1:56 pm Post subject: |
1. I couldn't read through all these, so my 2 cents is: an extension between the socket and the torque wrench, socket wrench, or breaker bar will have minimal effect, just need to keep all aligned. A length extension on the handle of the torque wrench, socket wrench, or breaker bar absolutely does matter, learn that Torque = Force x distance.
2. O'Reilly has free loaner 0-250 foot-pound torque wrench, so no excuses. _________________ 1970 VW (owned since 1972) and 1971 VW Convertible (owned since 1976), second owner of each. The '71 now has the 1835 engine, swapped from the '70. Second owner of each. 1988 Mazda B2200 truck, 1998 Frontier, 2014 Yukon, 2004 Frontier King Cab. All manual transmission except for the Yukon. http://www.thesamba.com/vw/forum/album_page.php?pic_id=335294 http://www.thesamba.com/vw/forum/album_page.php?pic_id=335297 |
Posted: Fri Nov 07, 2014 2:30 pm Post subject: |
Cusser wrote: |
2. O'Reilly has free loaner 0-250 foot-pound torque wrench, so no excuses. |
Wondered how long thread would go before somebody put in the SOCKET EXTENSION comment....
bluebus86 Banned
Posted: Fri Nov 07, 2014 8:22 pm Post subject: |
Splitdog wrote: |
bluebus86 wrote: |
of course my mentioning my profession is probably going to get me in hot water with some wacko's with religious slogans in their posts, |
That picture gives me great comfort. I can't lose with Him on my side.
THANKS!!!! _________________ Help Prevent VW Engine Fires, see this link.....Engine safety wire information
Splitdog Samba Split Personality
Joined: February 16, 2004 Posts: 4125 Location: Planet VW
Posted: Fri Nov 07, 2014 8:44 pm Post subject: |
_________________ CH³NO²
Z = z² + C
Der Blitzkrieg Kafers
#notacallooker |
