Brake Booster Issue
Page: 1, 2, 3  Next
19BUG70
19BUG70 is offline
PostPosted: Mon Nov 17, 2014 9:42 am    Post subject: Brake Booster Issue Reply with quote
I worked on my brakes this weekend replacing the rear cylinders and brake shoes. I noticed when I was done that there was a leak near the brake booster (see pic) - there is no brake fluid in the reservoir right now so I am assuming after reading some threads on here it is backing up through the master cylinder. Does that sound right? Any advice on my next step?
1970 Bug (sold 12/2014)
1972 Riviera Camper
1961 Bug (sold)
1966 Fastback TL
merlinj79
merlinj79 is offline
PostPosted: Mon Nov 17, 2014 9:59 am    Post subject: Reply with quote
It looks like the MC is probably leaking past it's internal seals, which will flood the brake booster and destroy it's internal diaphragm.
But there's also some kind of fluid leak in the upper left of the picture, on the torsion housing tube. That is probably a leak from the reservoir, the tube from the reservoir to the MC, or both.
You'll need a new or rebuilt MC, a new or rebuilt booster, and probably the supply tube to the MC.
If it hasn't been soaking for long, it's remotely possible that you could flush out the booster to remove the brake fluid and see if it still works. But odds are good the diaphragm is toast, or will be soon.
Rick
"Pumpkin II"
Stock 2L FI '77 Westy
CA Smog Stuff
kreemoweet
kreemoweet is offline
PostPosted: Mon Nov 17, 2014 10:01 am    Post subject: Reply with quote
Which reservoir is empty? The upper one or the one on the M/C? If that's actually brake fluid on your booster,
you have a massive leak from the front seals on your M/C. The booster would have to be at least 1/2 full of
fluid (or have a holed main diaphragm) for brake fluid to be coming out the front like that. Bad News! You probably
need a new M/C and will have to remove and clean out and test the booster.
'67 bug: seized by the authorities
19BUG70
19BUG70 is offline
PostPosted: Mon Nov 17, 2014 10:21 am    Post subject: Reply with quote
The reservoir behind the drivers seat.
FYI - When I replaced the rear cylinder (passenger side) that had a pretty good leak. Also, none of this is surprising as the bus sat for almost 20 years.
1972 Riviera Camper
1961 Bug (sold)
1966 Fastback TL
Tcash
Tcash is offline
PostPosted: Mon Nov 17, 2014 10:50 am    Post subject: Reply with quote
http://www.karpspowerbrake.com/
http://www.busdepot.com/j18100
merlinj79
PostPosted: Mon Nov 17, 2014 11:05 am    Post subject: Reply with quote
In that case you might want to replace all of the brake lines as well...the steel ones might be rusted from the inside from moisture buildup due to not being flushed with fresh fluid. May depend on where it was stored.
At the very least, do an impromptu hydrostatic test...have a big strong guy press and hold the brake pedal as hard as he can to see if anything ruptures or balloons.
Obviously the rubber brake hoses are probably overdue as well.
Rick
"Pumpkin II"
CA Smog Stuff
19BUG70
19BUG70 is offline
PostPosted: Mon Nov 17, 2014 11:47 am    Post subject: Reply with quote
Thank you - in reading other threads it looks like a rebuilt one is approx. $180 vs $280 for a new one. I'd like to save $100 but is that a good idea? In the whole scheme of things by the time I get the brakes in good shape $100 isn't going to seem like much. Very Happy
1972 Riviera Camper
1961 Bug (sold)
1966 Fastback TL
merlinj79
PostPosted: Mon Nov 17, 2014 11:59 am    Post subject: Reply with quote
I've been running a rebuild with no trouble for about ten years, but that was all that was available then. Assuming the rebuilder uses quality soft parts, the OEM hardware should last a very long time.
Rick
"Pumpkin II"
CA Smog Stuff
Tcash
Tcash is offline
PostPosted: Mon Nov 17, 2014 12:05 pm    Post subject: Reply with quote
Look around. Can't find it right now, but there is one without the vent boot that is less money.
http://www.wolfsburgwest.com/cart/DetailsList.cfm?ID=211611905
19BUG70
19BUG70 is offline
PostPosted: Mon Nov 17, 2014 1:33 pm    Post subject: Reply with quote
I see the busdepot has two brake boosters. Any thoughts on if the more expensive one is worth it? I see you have to drill some holes on the more expensive one for it to fit.
http://www.busdepot.com/vw/0/0/22/0/1122
They also have a master cylinder for $199. There are lots of hoses/brands to choose from, I would appreciate any feedback on these if some are better than others. I appreciate the responses so far, thanks.
It's always nice to be able to place one order rather than several from different vendors, so far the items I have received from busdepot in the past have worked out ok.
1972 Riviera Camper
1961 Bug (sold)
1966 Fastback TL
jtauxe Premium Member
jtauxe is offline
PostPosted: Mon Nov 17, 2014 1:37 pm    Post subject: Reply with quote
There was a thread about that WW one, finding a lot to be desired.
The one from BusDepot (also available at Just Kampers, where BD imports it from) is a Varga unit, built for VW in Brazil for Brazilian buses. It seems to be the real deal, though it requires modifying the mounting plate on the front beam for a different hole spacing.
http://www.justkampers.com/211-612-103-g-brake-servo-vw-t2-1971-1979.html
Has anyone tried that?
Here are some options from VW Heritage:
Looks like this one is ATE from Germany, and priced to suit:
https://www.vwheritage.com/shop/211612103/brake-servo-68-79-studs-72mm-apart-ate-or-use-103-g/
This looks like the same Varga unit from Brazil sold by JK and BD:
https://www.vwheritage.com/shop/211612103G/brake-servo-vw-brazil-studs-89mm-55mm/
and the same thing with the MC installed, which could be handy:
https://www.vwheritage.com/shop/211612103GC/brake-servo-master-brazil-studs-89mm-55mm/
So, the Brazilian ones require modification of the mounting plate. Has anyone done that?
Does that expensive ATE unit fit on the late bay mounting plate without modification? That is, do these buses have stud holes at 72 mm x 72 mm? If so, it seems like that is the way to go, if money is no object.
John
http://vw.tauxe.net
1979 Champagne Sunroof, 1974 Westfalia Automatic, 1979 Transporter, 1972 Sportsmobile, 1973 Transporter Wild Westerner, 1974 Westfalia parts bus
, 1975 Mexican single cab *FOR SALE*, 1978 Irish 4-door double cab RHD
kreemoweet
PostPosted: Mon Nov 17, 2014 2:51 pm    Post subject: Reply with quote
The ATE part will fit all US bay busses as far as the mounting studs go, but I'm pretty sure its the larger-diameter (9 1/4 in.)
booster used from mid-74 to 79. It will definitely interfere with the parking brake cable on a '71. I don't know about
a '72, or what would be involved in making it fit. The same problem might arise with the Brazilian/Varga unit.
The vendor should be able to tell you the size.
As far as I know, there are only 2 posters in this forum who have shared their experience with the WW booster (and the "aftermarket" booster from Bus Depot may well be the same item): my own not-so-good review and another fellow who said he had
"no problems" with it.
What I would really like to know is where the booster "rebuilders" are getting their parts.
19BUG70
19BUG70 is offline
PostPosted: Mon Nov 17, 2014 6:04 pm    Post subject: Reply with quote
I contacted the seller on this item for the master cylinder.
http://www.thesamba.com/vw/classifieds/detail.php?id=1563576
1972 Riviera Camper
1961 Bug (sold)
1966 Fastback TL
Tcash
Tcash is offline
PostPosted: Mon Nov 17, 2014 6:53 pm    Post subject: Reply with quote
Read the notes.
http://www2.cip1.com/ProductDetails.asp?ProductCode=C24-211-611-021-AAGR
19BUG70
19BUG70 is offline
PostPosted: Mon Nov 17, 2014 8:24 pm    Post subject: Reply with quote
Tcash - thank you. Seems like a simple change although I don't know what the different reservoir does. Maybe it's better to order one that uses the standard reservoir.....
This is new to me so I appreciate the help and advice. I certainly want to buy the correct parts to begin with. That's usually the hardest part.
1972 Riviera Camper
1961 Bug (sold)
1966 Fastback TL
Tcash
Tcash is offline
PostPosted: Mon Nov 17, 2014 8:40 pm    Post subject: Reply with quote
You have a 72, that has some one year only parts. You may need to use the 73-79 master cylinder.
This may be the easiest site to use.
http://www.wolfsburgwest.com/wolfsburg_new/brakes/bus_brake/brakes_bus.cfm?type=2
Good Luck
Tcash
1967250s
1967250s is offline
PostPosted: Mon Nov 17, 2014 8:49 pm    Post subject: Reply with quote
Looked at usual suspects, BD, GS, CIP, can't find MC repair kit, anyone know of one?
'72 Elm Green Deluxe
Wasted youth
Wasted youth is offline
PostPosted: Tue Nov 18, 2014 12:12 am    Post subject: Reply with quote
FWIW, I had my 1977 bus brake servo/booster unit sent out to Karp's Power Brake last spring, and they did an excellent job. Totally worth it, and have great customer service.
19BUG70
19BUG70 is offline
PostPosted: Tue Nov 18, 2014 9:15 am    Post subject: Reply with quote
Tcash - great info as usual, what a great chart for reference. My initial thought is to send the booster to Karps for a rebuild, however buying parts from WW is really easy and I could order it all including the master cylinder at one time.
As far as the actual work of taking apart and installing the new pieces does anyone have any suggestions or things to look out for from their past experience? I do have the Bentley book...
1972 Riviera Camper
1961 Bug (sold)
1966 Fastback TL
kreemoweet
PostPosted: Tue Nov 18, 2014 10:31 am    Post subject: Reply with quote
That note from CIP1 about the reservoirs makes absolutely no sense, and is surely incorrect. There is only a single master
cylinder for all 71-79 busses with boosters. The main reservoir is different depending on where the upper refill reservoir is located
and how the feed line is routed, but they all fit into the M/C the same way.
Page: 1, 2, 3  Next
