richparker Samba Member
Joined: November 24, 2011 Posts: 6981 Location: Durango, CO
Brian Samba Moderator
Posted: Mon Nov 17, 2014 8:31 pm Post subject: |
I understand the theory, but in all practicality wouldn't you really only need this if you don't have the correct oil weight for the season? _________________ Wash your hands
'69 Bug
'68 Baja Truck
'71 Bug
'68 Camper
Only losers litter |
suffecool2 Samba Member
Joined: May 15, 2011 Posts: 355 Location: chambersburg, pa
Posted: Mon Nov 17, 2014 8:45 pm Post subject: |
Brian wrote: |
I understand the theory, but in all practicality wouldn't you really only need this if you don't have the correct oil weight for the season? |
Its not "needed" if like you said, that you have the correct oil for the season. It would still make cold starts easier on your engine/oil pump in the winter. I wanted to do something like this, combined with a battery warmer For the PA winters, been getting colder each winter, damn global warming _________________ '71 Hightop - rolling resto/customization in process
'87 Golf - tranny's toast, but still runs
'70 bone stock Westy - gone |
airschooled Air-Schooled
Joined: April 04, 2012 Posts: 12721 Location: on a bike ride somewhere
In theory, anything you can do to get your engine up to operating temps quickly is going to increase the life of the engine. While our ACVWs don't need block heaters to keep the coolant from freezing, it sure would help the engine to warm the oil first. Thermal expansion rates is usually why we talk about thermostats, but the flap system helps heat the oil quicker to burn off moisture, so why wouldn't pre-heated oil help that system? Personally, I would just put a light bulb touching the sump on a timer to turn on a few hours before I leave in the morning. That way, when I forget to unplug it, I'm only out a 30 cent lightbulb.
Overall I like that warmer; it could come in handy in the really cold season that some people claim they get…… I surfed (no wetsuit yet) yesterday, and still have to run the AC at work…… Keep your regional experiences of climate change off the world-wide internet; not everybody lives in the same place
www.airschooled.com |
Posted: Mon Nov 17, 2014 8:53 pm Post subject: |
asiab3 wrote: |
not everybody lives in the same place |
Yea, but we do _________________ Wash your hands
'69 Bug
'68 Baja Truck
'71 Bug
'68 Camper
Posted: Mon Nov 17, 2014 8:54 pm Post subject: |
Brian wrote: |
asiab3 wrote: |
Yea, but we do |
O.K. we all live on the same planet, but live within different climates on said planet _________________ '71 Hightop - rolling resto/customization in process
Tom Powell Samba Member
Joined: December 01, 2005 Posts: 4855 Location: Kaneohe
Posted: Mon Nov 17, 2014 9:08 pm Post subject: |
I went skiing at Jackson Hole with my '69 camper. The first morning, wrong weight oil, the engine would not turn over. Bought an oil sump heater at a flaps and got the engine started at noon. After skiing the engine was difficult to turn over and would not start, but it was all downhill out of the parking lot. Got the engine started with a combination of starter and bump start in third gear at about twenty. Went back to the flaps and did an oil change on the ice in the parking lot.
There have been other posts regarding these sump heaters. I think bigbore did a reply once and mentioned all the cars he sees trailing extension cords.
Aloha
tp |
merlinj79 Samba Member
Posted: Mon Nov 17, 2014 9:15 pm Post subject: |
Brian wrote: |
Depends on how cold it gets. Much below 0* F, the oil will be very slow to flow and will take a very long time to warm up. My guess is that you'd be damaging your engine at least some until the oil got to a reasonable temp, somewhere above zero F. IMO any oil thin enough to flow good below zero would not protect an AC engine at normal operating temps.
I would use a heater in temps below zero, if I was even going to run an ACVW at all. We used block heaters in Idaho in the winter in water-cooled vehicles...started right up, heater worked faster, and no battery worries. Also in extreme cold it kept the coolant from freezing.
Also without a heater, your battery and starting system would need to be in great shape to even crank the engine.
You'd leave a water-cooler plugged in all the time but that was because the coolant might freeze. You don't need to run an oil heater constantly on a an ACVW, only a few hours, or the night before you plan to start it. Cheap alternative would be to leave a shop light plugged in inside the engine compartment...won't get the oil as warm but would help a bit. _________________ Rick
"Pumpkin II"
Stock 2L FI '77 Westy
CA Smog Stuff |
Posted: Mon Nov 17, 2014 9:25 pm Post subject: |
asiab3 wrote: |
Robbie |
A lot of good stuff there Robbie. Then, bam! What happened? Personally I'd take snowboarding in October over surfing in any winter month. That's just me.
I don't want you guys to think my bus is not starting. This morning it was 5* out when I turned it over. I lowered my oil viscosity from 20/50 to 10/30 for the winter already. I am just looking to get the oil a bit warmer so it's not like syrup when I turn it over. I've dicussed the light bulb idea and a heating pad on the sump idea. But this product is made to heat and it's not that expensive. If it holds up to the winter elements it could be a good product. Regional information here, read at own risk They don't use salt on the roads here so I'm able to drive all winter as long as it's not storming. _________________ __________
’71 Westy build
Adventure thread
’65 Deluxe Build
’63 Deluxe Build |
Posted: Mon Nov 17, 2014 9:27 pm Post subject: |
richparker wrote: |
I don't want you guys to think my bus is not starting. This morning it was 5* out when I turned it over. I lowered my oil viscosity from 20/50 to 10/30 for the winter already. I am just looking to get the oil a bit warmer so it's not like syrup when I turn it over. I've dicussed the light bulb idea and a heating pad on the sump idea. But this product is made to heat and it's not that expensive. If it holds up to the winter elements it could be a good product. |
Want to take the plunge and let everyone else know how it holds up? The plug looks vintage, but even economy products from back then are better than most of what's on the shelves now.
The auction page says "more than 10 available" so these might be a good find for those who have seasons where they live. _________________ Learn how your vintage VW works. And why it doesn't!
Vince Waldon Samba Member
Joined: November 07, 2010 Posts: 451 Location: Edmonton, Alberta
Posted: Mon Nov 17, 2014 10:15 pm Post subject: |
Sump heaters are SOP for my air cooled engines... rarely need 'em but it's nice to know you have it... and we do get some -35C days where it's nice to be able to give the starter a break. _________________ Vince Waldon Edmonton Alberta CANADA
1970 baywindow |
nodrenim Samba Member
Joined: October 06, 2006 Posts: 843 Location: Dobson, North Carolina
Posted: Tue Nov 18, 2014 5:36 am Post subject: |
There is another way to warm your engine. Try the old round reflector work lite with a 100 watt incandescent bulb. Place under engine for however long it takes to warm your engine. Another method is a good round lighted pan of charcoal under the engine, starts up in about 45 minutes. I have user these methods on all kinds of equipment when I lived in NNY, and temps used to drop to minus 40 a bunch. |
madmike Samba Member
Joined: July 11, 2005 Posts: 5292 Location: Atlanta,Michigan
Posted: Tue Nov 18, 2014 6:08 am Post subject: |
Name brand for ACVW I think was 'Kats' I use one on my Kabota tractor _________________ 'Black Ice'Drag Buggy 'Turbo'
Rail Buggy 1915 turbo
Tcash Samba Member
Posted: Tue Nov 18, 2014 6:27 am Post subject: |
Plug it in and drive away.
WP Auto Eject |
my59 Samba Member
Joined: August 13, 2003 Posts: 3790 Location: connecting the dots
Posted: Tue Nov 18, 2014 7:12 am Post subject: |
I used to keep a Benz diesel on the street in Brooklyn NY and the block heater, plugged in an about 1/2 hour before car use did wonders for ease of starting.
Getting a parking spot close enough for my collection of extension cords, that was a challenge. _________________ my59: Well son, my grandfather died before I got to drive it, so does that answer your question?
Other:'12 Jetta, '77 Benz 300D, and a 74 MG Midget. |
Randy in Maine Samba Member
Posted: Tue Nov 18, 2014 7:34 am Post subject: |
If you are running synthetic oil, there is no need to do it. IF you are running 10-30 dino still no need.
You would be better off to trickle charge the battery to keep it warm as at 0º they have about half the power as they do at 32º |
TomWesty Samba Member
Joined: November 23, 2007 Posts: 3482 Location: Wyoming,USA
Posted: Tue Nov 18, 2014 8:08 am Post subject: |
Randy in Maine wrote: |
Randy, I rarely disagree with you, but I run my bus year round and when it is 20 below even with synthetic oil I find using a sump heater would be beneficial.
Or better yet an engine compartment heater to warm everything. I use VR1 by the way. Has proper zddp content. _________________ If you haven't bled on them, you haven't worked on them.
Visit: www.tomcoryell.com and check out my music! |
Posted: Tue Nov 18, 2014 9:17 am Post subject: |
richparker wrote: |
It is 18* this morning. I checked the temp of the sump with the IR gun, 14*. |
Nice! How did it start? _________________ Learn how your vintage VW works. And why it doesn't!
aeromech Samba Member
Joined: January 24, 2006 Posts: 16959 Location: San Diego, California
Posted: Tue Nov 18, 2014 9:37 am Post subject: |
As part of my regular job I operate two turbine engine driven generators. These are each roughly the size of a railroad car and each have oil tanks that hold several hundred gallons of oil. Each unit has an internal oil tank heater which keeps the oil at a constant 80 F. Keeping the oil warm prevents water accumulation and damage. I'd say that for people who plan to moth ball their buses over the winter it would be a great idea to keep the engine warm.
_________________ Lead Mechanic: San Diego Air and Space Museum
Airbus A319,320,321
DC9/MD80
BAe146
Fokker F28/F100
VW type 1 1962,63,65,69,72
VW Jetta
VW Passat
