airschooled Air-Schooled
Joined: April 04, 2012 Posts: 12722 Location: on a bike ride somewhere
Posted: Sat Nov 22, 2014 3:41 pm Post subject: |
richparker wrote: |
wcfvw69 wrote: |
What would be cool RICHIE… |
I look forward to the readings.
ROBBIE _________________ Learn how your vintage VW works. And why it doesn't!
www.airschooled.com |
wcfvw69 Samba Purist
Posted: Sat Nov 22, 2014 4:05 pm Post subject: |
asiab3 wrote: |
richparker wrote: |
wcfvw69 wrote: |
ROBBIE |
DOH! Ok, I fixed it.. I'm getting old! _________________ Contact me at [email protected]
The Samba member since 2004.
pittwagen Samba Member
Joined: November 08, 2005 Posts: 766 Location: North of the 49th parallel
Posted: Sat Nov 22, 2014 5:14 pm Post subject: |
I used sump heaters on several vw's back in the 60's and 70's. 6 volts, straight weight oil and -40`F were not a good mix. Never had one fail or get damaged. Oh yes and the in car 110 v heater was also standard equipment. Even the B2 would take a while to blow hot at -40. Don't miss that one bit. |
richparker Samba Member
Joined: November 24, 2011 Posts: 6982 Location: Durango, CO
Posted: Sun Nov 23, 2014 10:57 am Post subject: |
It wasn't that cold out this morning but I decided to try out the heater. I used the IR gun on the sump plate and sump itself, both at 29*. I turned on the heater for 1 hour and this is what I got. Heating element was 220*, sump plate 204* and the side of the sump was 59*. I turned it over with the first hit of the key, there was no starter drag and it sounded much happier as it came to life. Thanks to all who posted. I think this was a good $32.99 investment. _________________ __________
’71 Westy build
Adventure thread
’65 Deluxe Build
’63 Deluxe Build
Tom Powell Samba Member
Joined: December 01, 2005 Posts: 4855 Location: Kaneohe
Posted: Sun Nov 23, 2014 11:11 am Post subject: |
richparker wrote: |
It wasn't the foldout this morning but I decided to try out the heater. I used the IR gun on the sump plate and sump itself, both at 29*. I turned on the heater for 1 hour and this is what I got. Heating element was 220*, sump plate 204* and the side of the sump was 59*. I turned it over with the first hit of the key, there was no starter drag and it sounded much happier as it came to life. Thanks to all who posted. I think this was a good $32.99 investment. |
Thanks for the definitive report.
If $32.95 makes your VW happy then you're ahead of a lot of us.
Don't forget to remove the extension cord before you leave the house.
Aloha
tp |
Posted: Sun Nov 23, 2014 11:20 am Post subject: |
Tom Powell wrote: |
Aloha
tp |
I'm looping a bright green extension cord through my driver handle so I don't forget. _________________ __________
’71 Westy build
Adventure thread
’65 Deluxe Build
’63 Deluxe Build |
Brian Samba Moderator
Posted: Sun Nov 23, 2014 12:45 pm Post subject: |
richparker wrote: |
It wasn't that cold out this morning but I decided to try out the heater. I used the IR gun on the sump plate and sump itself, both at 29*. I turned on the heater for 1 hour and this is what I got. Heating element was 220*, sump plate 204* and the side of the sump was 59*. I turned it over with the first hit of the key, there was no starter drag and it sounded much happier as it came to life. Thanks to all who posted. I think this was a good $32.99 investment. |
Thanks for the follow up Rich. I think it was indeed a GREAT $32 dollar investment. _________________ Contact me at [email protected]
Posted: Fri Nov 28, 2014 8:20 pm Post subject: |
So I got to digging around in my parts and here's what I found. Top is a T4 heater made by Cdn Gen. Electric and bottom is a Pyroil heater made in Canada and sold through VW dealers. So if it gets really cold (unlikely here) I'm prepared.
johnwan Samba Member
Joined: February 14, 2010 Posts: 129 Location: Victoria
Posted: Fri Feb 06, 2015 2:45 pm Post subject: |
This is a 200watt VW type 4-engine oil heater made in Canada by Pryoil.
The instructions say to install on engine case studs and secure with new nuts.
_________________ 1956 Canadian Standard Horizon Blue
1978 Kombi Pastel White
1978 Westfalia P31 Taigagrun |
Posted: Fri Feb 06, 2015 2:58 pm Post subject: |
Looks like kinda similar to the Kats I bought. The mounting is different but overall idea is the same . I like mine, it works well. It wouldn't hurt to try it, I don't think it alone will fix your problem but it will make cold starts easier on the engine. I would use 10/30 in the winter and switch to a better grade gas. It will burn cleaner and leave less water behind to contaminate the oil, I run 91 in my bus. _________________ __________
’71 Westy build
Adventure thread
’65 Deluxe Build
’63 Deluxe Build |
Posted: Thu Dec 15, 2016 8:54 pm Post subject: |
richparker wrote: |
Looks like kinda similar to the Kats I bought. The mounting is different but overall idea is the same . I like mine, it works well. It wouldn't hurt to try it, I don't think it alone will fix your problem but it will make cold starts easier on the engine. I would use 10/30 in the winter and switch to a better grade gas. It will burn cleaner and leave less water behind to contaminate the oil, I run 91 in my bus. |
Unless your gas has less hydrogen in it than regular gas it will make the same amount of water.
For people who only need a block heater for one or two nights a year then a magnetic block heater works pretty well. Of course if you have a Type 1 and you have replaced the original steel cover over the pickup screen with an aluminium cover the magnet will not have anything much to adhere to. |
