Oil sump heater
Page: Previous  1, 2, 3, 4
asiab3
Air-Schooled
asiab3 is offline
PostPosted: Sat Nov 22, 2014 3:41 pm    Post subject: Reply with quote
richparker wrote:
wcfvw69 wrote:
What would be cool RICHIE…
Very Happy
I look forward to the readings.
ROBBIE
Now offering 1-on-1 video tech help!
www.airschooled.com
Knowledge. Confidence. Reliability.
wcfvw69
Samba Purist
wcfvw69 is offline
PostPosted: Sat Nov 22, 2014 4:05 pm    Post subject: Reply with quote
asiab3 wrote:
richparker wrote:
Very Happy
ROBBIE
DOH! Shocked Ok, I fixed it.. I'm getting old! Smile
[email protected]
The Samba member since 2004.
1970 Westfalia Bus
1969 Convertible Bug
1967 Standard Bug
pittwagen
pittwagen is offline
PostPosted: Sat Nov 22, 2014 5:14 pm    Post subject: Reply with quote
I used sump heaters on several vw's back in the 60's and 70's. 6 volts, straight weight oil and -40`F were not a good mix. Never had one fail or get damaged. Oh yes and the in car 110 v heater was also standard equipment. Even the B2 would take a while to blow hot at -40. Don't miss that one bit.
richparker
richparker is offline
PostPosted: Sun Nov 23, 2014 10:57 am    Post subject: Reply with quote
It wasn't that cold out this morning but I decided to try out the heater. I used the IR gun on the sump plate and sump itself, both at 29*. I turned on the heater for 1 hour and this is what I got. Heating element was 220*, sump plate 204* and the side of the sump was 59*. I turned it over with the first hit of the key, there was no starter drag and it sounded much happier as it came to life. Thanks to all who posted. I think this was a good $32.99 investment.
__________
’71 Westy build
Adventure thread
Tom Powell
Tom Powell is offline
PostPosted: Sun Nov 23, 2014 11:11 am    Post subject: Reply with quote
richparker wrote:
It wasn't the foldout this morning but I decided to try out the heater. I used the IR gun on the sump plate and sump itself, both at 29*. I turned on the heater for 1 hour and this is what I got. Heating element was 220*, sump plate 204* and the side of the sump was 59*. I turned it over with the first hit of the key, there was no starter drag and it sounded much happier as it came to life. Thanks to all who posted. I think this was a good $32.99 investment.
Thanks for the definitive report.
If $32.95 makes your VW happy then you're ahead of a lot of us.
Don't forget to remove the extension cord before you leave the house.
Aloha
tp
richparker
PostPosted: Sun Nov 23, 2014 11:20 am    Post subject: Reply with quote
Aloha
tp
I'm looping a bright green extension cord through my driver handle so I don't forget. Smile
__________
’71 Westy build
Adventure thread
Brian
Brian is offline
PostPosted: Sun Nov 23, 2014 11:40 am    Post subject: Reply with quote
Rig up a light that feeds off the line.
Wash your hands
'69 Bug
'68 Baja Truck
'71 Bug
'68 Camper
Only losers litter
wcfvw69
Samba Purist
wcfvw69 is offline
PostPosted: Sun Nov 23, 2014 12:45 pm    Post subject: Reply with quote
Thanks for the follow up Rich. I think it was indeed a GREAT $32 dollar investment.
[email protected]
1970 Westfalia Bus
1967 Standard Bug
pittwagen
PostPosted: Fri Nov 28, 2014 8:20 pm    Post subject: Reply with quote
So I got to digging around in my parts and here's what I found. Top is a T4 heater made by Cdn Gen. Electric and bottom is a Pyroil heater made in Canada and sold through VW dealers. So if it gets really cold (unlikely here) I'm prepared.
johnwan
johnwan is offline
PostPosted: Fri Feb 06, 2015 2:45 pm    Post subject: Reply with quote
This is a 200watt VW type 4-engine oil heater made in Canada by Pryoil.
The instructions say to install on engine case studs and secure with new nuts.
1956 Canadian Standard Horizon Blue
1978 Kombi Pastel White
1978 Westfalia P31 Taigagrun
richparker
PostPosted: Fri Feb 06, 2015 2:58 pm    Post subject: Reply with quote
Looks like kinda similar to the Kats I bought. The mounting is different but overall idea is the same . I like mine, it works well. It wouldn't hurt to try it, I don't think it alone will fix your problem but it will make cold starts easier on the engine. I would use 10/30 in the winter and switch to a better grade gas. It will burn cleaner and leave less water behind to contaminate the oil, I run 91 in my bus.
__________
’71 Westy build
Adventure thread
Wildthings
Wildthings is offline
PostPosted: Thu Dec 15, 2016 8:54 pm    Post subject: Reply with quote
Unless your gas has less hydrogen in it than regular gas it will make the same amount of water.
For people who only need a block heater for one or two nights a year then a magnetic block heater works pretty well. Of course if you have a Type 1 and you have replaced the original steel cover over the pickup screen with an aluminium cover the magnet will not have anything much to adhere to.
Page 4 of 4
