Momentai Samba Member
Posted: Thu Nov 27, 2014 6:35 am Post subject: Eastwood Inner Frame Coating on interior body panels? |
Hi everyone,
I'm doing some rustproofing on the Westy. All the camper interior/ panels are currently out and I'm grinding out all remaining surface body rust on the floor and interior frame, treating with POR-15 etc, finishing off with some leftover beautiful ASSUAN BROWN I have in a rattlecan. Once the metal is all done, the plan is to cover in fatmat and closed cell insulation, get the interior panels/ camper stuff back in and move on!
QUESTION: I also have some interior frame coating (green color) from Eastwood and I want to see if anyone's used it as a rust protectant on the inside of the Vanagon body before. I am thinking to spray it inside the cavities on the quarter panels below the windows on as well as inside the of the sliding door cavities and along the inner rocker behind the camper unit etc.
Is this the right product for this area or is it overkill etc? Any feedback on painting over this stuff? Thanks for any recommendations and guidance and happy thanksgiving to all
momentai _________________ 67 Kombi
67 SO42
71 Westy
88 Syncro Doka
88 Syncro Westy
86 944 Turbo |
dobryan Samba Member
Joined: March 24, 2006 Posts: 16505 Location: Brookeville, MD
Terry Kay Banned
Posted: Thu Nov 27, 2014 2:10 pm Post subject: |
Panel wax is your best bet for sealing inner ( and outer) Vanagon body cavities.
I have this available in 20 oz. aerosol cans and works very well--
_________________ T.K. |
Posted: Thu Nov 27, 2014 5:04 pm Post subject: |
Great, thanks both for the tip on the panel/ cavity waxes. These seem more suitable for the interior areas that I am concerned about. I am already using Fluid Film on exterior seams etc. That stuff is amazing. Does the spray wax have a similar consistency? _________________ 67 Kombi
67 SO42
71 Westy
88 Syncro Doka
88 Syncro Westy
86 944 Turbo |
Phishman068 Samba Member
Joined: February 19, 2007 Posts: 1868 Location: Pittsburgh PA (ish)
Posted: Thu Nov 27, 2014 5:51 pm Post subject: |
Noxudol 750 is essentially fluid film but designed to be encapsulated by the 900 or 1600.
So, you spray seams, unions, and cavities, then you can blast over everything with a much more durable and thicker wax (900/1600). They actually even suggest using 750 as a "primer" of sorts, penetrating deep into seams, cavities, and into any rust that may exist, then the thicker stuff sticks right to it.
A spectacular product. _________________ http://www.thesamba.com/vw/forum/viewtopic.php?t=559766&highlight=winter+rust
http://www.thesamba.com/vw/forum/viewtopic.php?t=482402&highlight=sunroof+syncro
http://www.thesamba.com/vw/forum/viewtopic.php?t=569774
http://www.thesamba.com/vw/forum/viewtopic.php?p=6864936#6864936
"Along with the ability to go fast, one looses the desire to hurry." |
