dave1 Samba Member
Joined: September 12, 2003 Posts: 478 Location: United Kingdom, London
Posted: Sun Dec 14, 2014 7:05 pm Post subject: Peppco charger vacuum gauge |
I have a peppco charger & want to fit a vacuum gauge similar to what I had on my previous bettle with a judson. I have the vac gauge but not sure if it can be fitted
thanks for your help
Dave |
Richard Roth Samba Member
Posted: Mon Dec 15, 2014 8:48 am Post subject: |
Here is a photo of my nos Pepco boost gauge.
Drill and tap a hole in the intake manifold just below the mounting flange.
Use a brass fitting to connect the hose to the manifold and connect the other end to the gauge. _________________ The problem with reality is that there's no background music !
1966 Empi GTV MKIV
1954 Kabriolett Beetle
1953 Porsche 356 1500S
1957 Cable brake standard model
1962 cable brake standard model
1956 23 window Samba
1960 Austin Healey 3000
1961 Corvair Greenbrier |
dave1 Samba Member
Posted: Mon Dec 15, 2014 8:40 pm Post subject: peppco gauge |
Hi Richard,
thank you for your reply. Would it be possible to add a photo on where you put the connection
regards
Dave |
50 split Samba Member
Joined: January 23, 2006 Posts: 102 Location: Skellefteå (Sweden)
Posted: Tue Dec 16, 2014 11:30 am Post subject: |
I put the brass fitting on the metal plate between the supercharger and the manifold. I run a Fageol Pepco on a metalplate (distance) from Ray Schubert.
Sadly I have no picture on the installation.
I run a boost gauge from a ww2 plane.
Good luck! _________________ Insta: 50_split
#Sawmillcollection
Kübel: 43 (Ho 2022)
type 1: 50, 51 (kabrio), 51, 52(zwitter), 56, 57, 58, 60, 60, 61, 63, 63, 64, 65, 72
type 2: 51, 54 Taxi (H-O 2026), 54, 56, 58, 65 (Fridge van), 67(bay) 68, 68, 70, 70 (Burnt westy), 71 (westy) 72, 73, 73, 75, 96 (Kombi)
type 3: variant 62 (october), 66 fasty: 66 (Teak), 67
Tempo: Matador 50(world´s oldest)
DKW: Schnellast 52, E300 29
Porsche: 356 65
Eriba: Puck 65
Alfredo (tent trailer) 59
Wheel´s and part´s |
thomas. Samba Member
Joined: July 31, 2010 Posts: 1291 Location: South West (Pa.)
Posted: Sat Dec 20, 2014 1:46 pm Post subject: |
I was thinking of doing it this way . If I ever get to it. I think this is what 50 split was suggesting also.
dave1 Samba Member
Posted: Sat Dec 20, 2014 3:06 pm Post subject: Pepec vac gauge |
Hi,
in this position, wouldn't the oil lubrication from the charger get in to the vacuum
gauge & give a false reading
thanks
Dave |
Posted: Sun Dec 21, 2014 9:55 am Post subject: |
Are you looking in the right spot. I'm not talking about the blue fitting, that would be the oil drain.The brass fitting on the square plate. The opening to the supercharger is larger than the intake man. gasket so there is a little room there for a fitting.Maybe a 1/4 inch fitting. |
dave1 Samba Member
Posted: Mon Dec 29, 2014 8:49 am Post subject: pepco vac gauge |
Hi Thomas thank you for your help. Can anyone else share any additional info on a vacuum gauge for a pepco super charger prethably with pictures
thanks
Dave |
John Moxon Samba Moderator
Joined: March 07, 2004 Posts: 13952 Location: Southampton U.K.
dave1 Samba Member
Posted: Mon Dec 29, 2014 6:07 pm Post subject: pepco vacuum gauge |
Hi John,
Thank you for the details. I have a vacuum gauge ready to fit, just want to make sure where to fit connector
cheers
Dave |
