truse Samba Member
Joined: February 10, 2014 Posts: 30 Location: Estherville, IA
Posted: Tue Nov 25, 2014 8:17 am Post subject: Wet sanding base before clear |
I'm 100% new to painting so this may be a stupid question but I was wondering; can I wet sand my base before clear coating? There is some orange peel and dirt in the color coat I want to get out. I just don't know if I should shoot another coat of color before the clear if I did this. If I shoot another coat of color I would be surprised if I didn't end up with the same problem of orange peel and dirt. This leads to another question, can some orange peel be covered by clear without it showing? Like I said, I'm 100% new to this so any input would be great. Thanks a lot! |
beetlenut Samba Member
Posted: Tue Nov 25, 2014 9:01 am Post subject: |
If you have enough base on so you don't sand through to the primer layer, sure you can color sand the base. I wouldn't get too agressive with the grit, maybe 1000 - 1500. The clear will fill-in some of the orange peel of the base, but IMO any work you can do along the way that will take out any imperfections, will only make the final color sanding that much easier and results that much better.
My 2 cents... _________________ scrapyards are for quitters
Wetstuff wrote: |
... I spend more time shaking it than directing it?! I get a pretty decent blast for 8sec. then have to shake it again. |
- Words to live by right there!
My 74 Super rebuild thread: http://www.thesamba.com/vw/forum/viewtopic.php?p=6507104#6507104 |
VintageVulture Samba Member
Joined: May 25, 2003 Posts: 789 Location: Pacific Northwest- USA
Posted: Sun Nov 30, 2014 5:39 pm Post subject: |
Sand it then base over what you sand. Clear magnifies the surface it's over. Sanding it before clear would prove a disaster. _________________ The best things in life aren't Things
(they're Buses) |
Der Speed Shack Samba Member
Joined: April 10, 2010 Posts: 164 Location: Fullerton, Ca 92832
Posted: Thu Dec 18, 2014 9:23 pm Post subject: |
Wet sand with 600, if you burn thru color spot it in and spray clear right over. It will be fine |
kman Samba Member
Joined: November 04, 2005 Posts: 739 Location: Michigan
Posted: Fri Dec 19, 2014 7:33 am Post subject: |
vdubspeedshack wrote: |
As long as its a solid color (not metallic or pearl) this is correct. |
