imtb Samba Member
Posted: Wed May 14, 2014 9:09 am Post subject: |
Coud someone post a pic of the seal installed on the body? |
BulliBill Samba Member
Joined: July 09, 2004 Posts: 4572 Location: St Charles, MO
Posted: Wed May 14, 2014 9:45 am Post subject: |
I did not use an adhesive on the seals attached to the door frame. The flatter side rests against the pop-out frame, the curvier side of the seal faces toward the interior of the cab. I'll look to see if I shot any close-up photos of the installed seal in my build thread.
Bill Bowman _________________ I'm looking for these license plate frames for my fleet:
Mission VW - San Fernando
Thornton VW - Stockton
Thanks for any help! |
Posted: Wed May 14, 2014 9:50 am Post subject: |
Here is the only photo I shot showing that seal on the door frame, perhaps you can see the curved side facing in...
Bill _________________ I'm looking for these license plate frames for my fleet:
otis_bartleh Samba Member
Joined: August 19, 2009 Posts: 1106 Location: Burlington, WA
Posted: Wed May 14, 2014 10:26 am Post subject: |
BulliBill wrote: |
Bill |
What's up with the pop out opening the wrong way? Shouldn't that one be opening forward? _________________ -Adam
'59 Mango Bus - getting buried in it
'69 Bug - sold and highly missed, so it stays in the sig |
mandraks Samba Member
Joined: November 28, 2004 Posts: 7047 Location: Lawrenceville, Ga
Posted: Wed May 14, 2014 10:57 am Post subject: |
otis_bartleh wrote: |
BulliBill wrote: |
Bill |
What's up with the pop out opening the wrong way? Shouldn't that one be opening forward? |
nothing wrong here, this is a crewcab _________________ regards
Uli
Posted: Wed May 14, 2014 10:58 am Post subject: |
mandraks wrote: |
nothing wrong here, this is a crewcab |
Ahh, that explains that. _________________ -Adam
Darth Wolfsburg Samba Member
Joined: August 14, 2012 Posts: 13 Location: Miami Florida
Posted: Wed Nov 26, 2014 5:46 pm Post subject: Pop out measurments |
Does anyone have the accurate measurements for the pop out glass?
I bought glass that was advertised as taken from a pop out bus, but it is about 1/4 inch too big for my pop out frames. |
EDragnDean Samba Member
Joined: July 13, 2005 Posts: 1148 Location: Vancouver, WA
BarryL Samba Member
Joined: November 01, 2004 Posts: 14257 Location: Casa de Oro, California
Posted: Wed Nov 26, 2014 7:39 pm Post subject: Re: Pop out measurments |
Darth Wolfsburg wrote: |
Sounds like you got sold "stationary glass" that got popped out of a bus.
If it is, you should be able to resell it. |
Breckskier Samba Member
Joined: December 16, 2002 Posts: 239 Location: Grand Rapids, MI
Posted: Mon Dec 01, 2014 11:23 pm Post subject: |
Pop out outer frame Rubber needs to bend out towards exterior, so it lays flat when window is pulled closed. So does that mean, long side without the groove faces down / towards interior? I guess a picture would help.. _________________ BreckSkier
67 13w Deluxe-"St. Pete" the Airport Jet Bus
65 13w Deluxe-"St. Nikolas"
67 912(911.5 Outlaw build spring 2015), 90 C4Cab. Formerly: 59 DD, 78 SuperB, 81 911Cab, 82Vanagon, 81Vana & other German / US stuff.. |
Posted: Mon Dec 01, 2014 11:27 pm Post subject: |
jjjjack wrote: |
Can someone confirm for me that this is correct?
Thanks! |
Never mind. I looked back & found this. _________________ BreckSkier
Posted: Tue Dec 09, 2014 9:07 pm Post subject: Re: Pop out measurments |
BarryL wrote: |
BarryL, I'll be posting it for sale soon. They are good pieces of glass |
21-window Samba Member
Joined: March 23, 2004 Posts: 248 Location: out planting
Posted: Sat Dec 13, 2014 1:33 pm Post subject: |
Does the seam (where the rubber is joined) in the seals go at the top (12 clock position) or bottom?
I see bullibill has his outer pop out seams at the top can't tell on the others, is this correct?
do all three seams go in the same spot? |
Posted: Sun Dec 28, 2014 5:48 pm Post subject: |
Ping.... The worst sound.
I believe when the old screw were drilled out, they didn't line up properly. So when I tried to get new screws in, it pulled the frame too tight & ping....
I guess it happens. _________________ BreckSkier
Posted: Sun Dec 28, 2014 9:27 pm Post subject: |
instant privacy glass _________________ regards
Uli
Posted: Sun Dec 28, 2014 10:16 pm Post subject: |
mandraks wrote: |
instant privacy glass |
Ha! For sure. The other 11 went well so far... _________________ BreckSkier
dualport Samba Member
Posted: Sun Mar 15, 2015 3:17 pm Post subject: FWIW West Coast Metric inner glass seals |
I don't know if the WCM inner glass seals I got were in "mid run" but some were very tight (had to stretch all the way around) and some were almost too loose. _________________ Conrad @ Air Coolers VW Gang http://aircoolers.org
Air Coolers Google Map of clubs, services and shops: https://goo.gl/3KM4wm |
Stocknazi Samba Member
Posted: Sun Mar 15, 2015 6:49 pm Post subject: |
Has anyone used the top half of a rusty pop-out to fix the rusty bottom of another? Is is worth the trouble?
You could build a quick wooden jug to keep the window opening the same size. Cleaning out the outter seal channel groove could be difficult.
Any imput appreciated. _________________ WANTED:
"Resistance to tyrants is obedience to God."
Thomas Jefferson |
