1300 Super 36
snowbug
snowbug is offline
PostPosted: Tue Mar 25, 2014 5:02 pm    Post subject: 1300 Super 36 Reply with quote
Back to work on the 1300. Flywheel lightened , eight doweled and balanced as a unit. Type 4 deep sump almost done fitting to the 36 block.
Jim
tobiasax
tobiasax is offline
PostPosted: Wed Mar 26, 2014 1:35 am    Post subject: Reply with quote
Looks great! …and I have to say that as it looks exactly like mine Smile
http://lowlightkaizen.blogspot.se/2014/02/ett-steg-framat-for-de-roterande-delarna.html
snowbug
snowbug is offline
PostPosted: Sun Apr 20, 2014 5:40 pm    Post subject: Re: 1300 Super 36 Reply with quote
Jim
Cam is hitting the rods . That is clearanced now. Next pistons need clearing for crank.
snowbug
snowbug is offline
PostPosted: Tue Apr 22, 2014 1:26 pm    Post subject: Re: 1300 Super 36 Reply with quote
snowbug wrote:
Jim
Machined the skirts to clear the crank.
snowbug
snowbug is offline
PostPosted: Sun Dec 21, 2014 5:25 pm    Post subject: Back to work Reply with quote
Well its cold outside , time to work on the 1300 again. I shaved the piston tops today. Put valve spring .060 shims in. Compared the 40hp and 36hp oil pump gears. Planning on using the 40hp pump.
snowbug
snowbug is offline
PostPosted: Tue Dec 30, 2014 9:39 am    Post subject: Piston clearance Reply with quote
Used plastercene to check clearance of piston to head and valves. Looks like about .100 to the head and .350 to the valves.
gimmesomeshelter
gimmesomeshelter is offline
PostPosted: Tue Dec 30, 2014 2:16 pm    Post subject: Reply with quote
A clean engine is a happy engine. Wink
Cheers,
Paul
"I would rather have questions that can't be answered than answers that can't be questioned."
Richard Feynman
snowbug
snowbug is offline
PostPosted: Thu Jan 01, 2015 11:30 am    Post subject: ultrasonic Reply with quote
Cheers,
Paul
We have an ultrasonic cleaner at work. It is mostly used for copper weld gun parts. I put a VW carb in it and it came out clean but it was copper plated.
Jubilee Kafer 1985
Jubilee Kafer 1985 is offline
PostPosted: Thu Jan 01, 2015 11:49 am    Post subject: Reply with quote
Looks Good ...
You are going to need a Turbo to pump some air into it, then it will fly.
snowbug
snowbug is offline
PostPosted: Mon Mar 23, 2015 8:36 am    Post subject: Carbs Reply with quote
Getting dual type 3 carbs sorted out.
Joey Anchors
Joey Anchors is offline
PostPosted: Sat Mar 28, 2015 1:53 pm    Post subject: Reply with quote
This is coming a long nicely!
snowbug
snowbug is offline
PostPosted: Sun May 29, 2016 5:20 pm    Post subject: Re: 1300 Super 36 Reply with quote
Just got the beast running today . Sounds good and seems to have power. I am using a single carb til the cam is broken in. Just running it on the floor. Have to get the dual carbs sorted out next. How do you guys get your beast started with 6 volts? I might have to carry a 12 volt battery and booster cables just to start it. Jim
tobiasax
tobiasax is offline
PostPosted: Mon May 30, 2016 10:35 pm    Post subject: Re: 1300 Super 36 Reply with quote
Happy to hear that it's running! Congratulations!
I run 1295cc, 8,2:1 and have no problem with a 6V starter. Shouldn't be a problem.
__________________________________________
Erik G
Erik G is offline
PostPosted: Fri Jun 03, 2016 12:19 pm    Post subject: Re: 1300 Super 36 Reply with quote
6v type 3 starter is stronger than the type 2 starter
and - there is a super rare 6v self supporting starter out there - from 6v cars with the saxomat
snowbug
snowbug is offline
PostPosted: Fri Jun 03, 2016 6:42 pm    Post subject: Re: 1300 Super 36 Reply with quote
I did not know there are different 6v output starters.
Old enough to remember THRILLS, the gum that tastes like soap.
Erik G
Erik G is offline
PostPosted: Wed Jun 08, 2016 2:54 pm    Post subject: Re: 1300 Super 36 Reply with quote
type 3 starter part number 311 911 021
it's .6hp vs .5hp and it does help on a type 3 motor. They were higher compression
snowbug
snowbug is offline
PostPosted: Wed Jun 08, 2016 3:47 pm    Post subject: Re: 1300 Super 36 Reply with quote
video , just got it running.
tobiasax
tobiasax is offline
PostPosted: Wed Jun 08, 2016 9:41 pm    Post subject: Re: 1300 Super 36 Reply with quote
snowbug wrote:
video , just got it running. https://www.youtube.com/watch?v=PLgBnnEpbZ0
Congratulations! It's a magic moment when the engine you worked on for a long time comes to life!
snowbug
snowbug is offline
PostPosted: Mon Jun 13, 2016 8:32 am    Post subject: Re: 1300 Super 36 Reply with quote
Geez , another new problem. Had problems with dist., fuel pump, and carb. Now I can`t get the lower shoe boxes on. Interfears with the deep sump. Might have to notch them.
snowbug
snowbug is offline
PostPosted: Thu Jan 05, 2017 9:27 am    Post subject: Re: 1300 Super 36 Reply with quote
Engine in the car now. 6 volt are struggling to start the beast.
